STS engines
Old 05-21-2004 | 12:51 PM
  #781
dino.tw's Avatar
Nitro Tech
Default Re: Re: Re: Dino:
Originally posted by jscamry
Dino, I was looking on the boca site for the front bearing for the D3. I just had a few questions. What is the difference between the ceramic bearings and phenolic plastic bearings? also what is the C3 class?
thanks Jason
You should ask them. They are PRO....
Hint...MR607-2RU TH9/C3 or MR607C-2RU TH9/C3 (ceramic)
dino.tw is offline
Old 05-21-2004 | 01:20 PM
  #782
EdwardN's Avatar
thanks Jason
I am not Dino, but may be can help you.
Ceramic bearuing is with ceramic balls ( most advanced techology in bearings today) and phenolic plastic means the cage , which holding balls on their place made out of phenolic plastic. Tehre are couple different type of cage-plastic, pressed steel, machined brass etc. For our aplication is most suitble phenolic plastic cage.
C3-it is description of internal clearance between balls and rings in bearings-there are 5 types from C0 to C5. C0 is tightest and C5 is loosest clerance. I personaly preferd to use C5 clearnance, but it is realy difficult to find.
EdwardN is offline
Old 05-21-2004 | 06:06 PM
  #783
tallyrc's Avatar
aren't ceramic bearing illegal in motors?
tallyrc is offline
Old 05-21-2004 | 07:52 PM
  #784
dino.tw's Avatar
Nitro Tech
Default Re: Re: Re: Re: Dino:
You prefer C5 clearance
You must be joking?
http://www.bocabearings.com/industrial/indentify.htm
#9 RADIAL PLAY (MC3)
Symbol MC3 followed by numbers indicates the range of radial play.
Example: MC3=0.005-0.013mm (0.0002 to 0.0005 inch)
Example: MC4=0.013-0.020mm (0.0005 to 0.0008 inch)
Symbol C designates larger size metric bearings.
dino.tw is offline
Old 05-21-2004 | 07:59 PM
  #785
dino.tw's Avatar
Nitro Tech
http://www.roarracing.com/rules/pdfs/2004rules.pdf
On page 33;
rule #6-29 Ceramic bearings are allowed no other ceramic parts will be allowed in any engine raced in ROAR events.
So ceramic coating piston is illegal?
dino.tw is offline
Old 05-22-2004 | 08:00 AM
  #786
EdwardN's Avatar
Default Re: Re: Re: Re: Re: Dino:
You must be joking?
Hi Dino. Yes I preferd C5. This is one of the reasons why we use rear bearing with no inner ring-we calibrate balls and we do that clearance which we think is best for us.
I sugest you try one, I mean try use C4 or C5 instead of C3 ( I am sure on your company you can put one bearing together for trial)
EdwardN is offline
Old 05-23-2004 | 09:12 PM
  #787
jscamry's Avatar
Talking Re: Re: Re: Re: Dino:
thanks for the hint.... Dino..
I was also wondering if it is recommended to replace teh rear bearing also while changing the front? if so, what are the sepcs on the rear beareing for the D3?
thanks Jason
jscamry is offline
Old 05-23-2004 | 09:23 PM
  #788
dino.tw's Avatar
Nitro Tech
thanks Jason
HINT AGAIN! Hope your eyesight is good....
MR6801 TH9/C3 or MR6801C TH9/C3 (ceramic)
It depend on the bearing condition. And the bearing life depend on the fuel that you using.
dino.tw is offline
Old 05-25-2004 | 06:24 PM
  #789
Dino....not sure if ya ( or any others )remember me. I had posted probably several pages back. Having problems breaking in my D5 , specifically getting it to run smooth. I always thought it was a problem with the carb but never was sure. I ended up ordering a new one which I finally received,no fault of the company I ordered from.Anyway, I have yet to try the new carb on the engine, but I have moved the slide by hand and it is much smoother.I will let you all know how things go when I get a chance to run it.
NitroOB4You is offline
Old 05-25-2004 | 07:48 PM
  #790
jscamry's Avatar
Default Re: Re: Re: Re: Re: Re: Dino:
how do I tell if the rear beaing needs replacing? what are the signs? also is there anyway to tell with out taking out the bearing from the engine??
thanks Jason
jscamry is offline
Old 05-26-2004 | 09:01 AM
  #791
dino.tw's Avatar
Nitro Tech
Default Re: Re: Re: Re: Re: Re: Re: Dino:
thanks Jason
http://www.rctech.net/forum/showthre...threadid=29443
http://www.rctech.net/forum/showthre...threadid=29963
dino.tw is offline
Old 05-26-2004 | 10:45 AM
  #792
jscamry's Avatar
thanks for the links DIno!!!
jscamry is offline
Old 06-02-2004 | 04:32 AM
  #793
After changing from a .15 manifold to a .12, smoke and fuel are coming up the lid of my tank, seems like there is too much pressure?? i have tryed longer pressure tube, but no better.
My tank isnt that old, 6 months?
Any suggestions??
Finken is offline
Old 06-02-2004 | 07:18 AM
  #794
dameetz's Avatar
Default D5R
I just got my self a D5R, the one with the black heat sink. I ve seen this beast performing at the recent FEMCA race in Thailand and it is on par if not better that most of the modded high cost engine. From there on I knew I just have to get one. Now I just need to wait for the upcoming V1RRR to put the beast in.
dameetz is offline
Old 06-02-2004 | 09:35 AM
  #795
dino.tw's Avatar
Nitro Tech
Any suggestions??
Change your fuel lid immediately. A leaking lid will let your engine overheat.
dino.tw is offline
