Old 05-20-2004, 03:49 AM   #766
Nitro Tech
dino.tw's Avatar
Default Re: Re: SWEEEEEET
Originally posted by jscamry
racecar85-how do you like the D3 with the sts pipe? i have a D3 also, and I need to get better pipe. I am using an old paris turbo ring pipe.
thanks Jason
There is a news. The ZEN .12 pipe is coming soon. Adjustable pipe's length is this time characteristic. Last time was adjustable tail pipe internal diameter....
dino.tw is offline   Reply With Quote
Old 05-20-2004, 04:15 AM   #767
Nice pipes..
When is the STS pipe coming out for LD3/NTC3? lol.. only kidding, I know that will never happen (fair enough - not enough market, though id love to see one <grin>)
Go the DRAGON!!
au_Nightmare is offline   Reply With Quote
Old 05-20-2004, 10:52 AM   #768
jscamry's Avatar
Send a message via AIM to jscamry Send a message via MSN to jscamry Send a message via Yahoo to jscamry Send a message via Skype™ to jscamry
Default Dino
Dino-how does the Adjustable pipe's length work?
jscamry is offline   Reply With Quote
Old 05-20-2004, 10:55 AM   #769
Nitro Tech
dino.tw's Avatar
Default Re: Dino
Put on shims behind the gasket.
Old 05-20-2004, 11:01 AM   #770
jscamry's Avatar
that is a neat design. how long untill the new pipe hits the streets? also Dino, I was wondering if you have any pics of the moded projectzen piston/sleeves? I emailed them but new response...
thanks again Jason
Old 05-20-2004, 11:12 AM   #771
Nitro Tech
dino.tw's Avatar
thanks again Jason
I have seen some samples but I haven't get mine...
All send to Zen for testing...So I don't know how much distance it adjustable.
No,I don't have pics fo Zen mod. p/s. You better call them,I think Geoff is very busy now.
Old 05-20-2004, 04:50 PM   #772
bballer's Avatar
Dino, I'm not sure if my rs3 is giving out on me. I have had the engine for one month and have run a little more than half a gallon through it. during break-in, i ran it really rich (fuel coming out of exhaust) and was just starting to lean it out some more today (still a little fuel coming out of exhaust). The engine was running terribly . So i called it a day, and brought in my engine and took out the glow plug. There is absoutely no pinch whatsoever!! After 1/2 a gallon, i am pretty sure that my engine is losing compression!! Now i kept it rich whenever i ran it and was very tedious during break in and cleaned it every few runs. So please don't tell me my motor is going on me already!!!
bballer is offline   Reply With Quote
Old 05-20-2004, 05:13 PM   #773
Nitro Tech
dino.tw's Avatar
terrible fast or terrible slow???
How you know your engine is losing compression? Can't keep idle or you need to higher the idle? Have you try another new plug? Or is there any leaking?
Old 05-20-2004, 05:17 PM   #774
bballer's Avatar
terribly slow, i just put in a brand new nova #4, where would the most likely place for an air leak be?
P.S. When an engine doesn't have a pinch at the tdc, the piston/sleeve is dead, right
thanks
Old 05-20-2004, 05:28 PM   #775
Nitro Tech
dino.tw's Avatar
thanks
Just check if the plug has air leaking.
Also,When an engine doesn't have a pinch at the tdc, the piston/sleeve is dead, right???
NO! Every brand's engine has each own characteristic. So you should said when the engine can't keep idling then the engine is going to die.
To STS engine,the engine is just awake form now. Check all moving parts if it still at good condition. Take out 0.1mm shims and lean it now. And kick other's ass.......
Old 05-20-2004, 06:03 PM   #776
bballer's Avatar
lol!!! All right, thanks for the info. I just replaced the conrad as recommended, and everything else is good. Are you saying to take out the stock shim and run the engine with no shims when im running byrons 20% and am about to lean it out?
Thanks for the help, when i could turn the piston i was scared, but i guess i was overreacting
Old 05-20-2004, 06:11 PM   #777
Nitro Tech
dino.tw's Avatar
byrons 20% is good. The 0.3mm alu. shim is ok just lean it.
And you can try 0.2mm brass shim at small track for better low end punch.
P.S : Above statement is for normal plug...
Old 05-20-2004, 06:21 PM   #778
bballer's Avatar
thanks, one last thing, i was told that when you have the glow plug in and the engine mounted in the car, you shouldn't be able to turn the flywheel w/ one finger, and i can. Is that ok for my rs3 b/c it has different characteristics??
Thanks, and btw it isn't turbo head
Old 05-20-2004, 06:40 PM   #779
Nitro Tech
dino.tw's Avatar
If your engine can't keep idling then the engine is going to die.
Drop some fuel to lubricate your piston from the plug hole. Then screw up the plug and try again. Also maybe your finger is too strong or you eat too much spinach.
Old 05-21-2004, 12:50 AM   #780
jscamry's Avatar
Default Re: Re: Dino:
Jason,
The front bearing is ISO #607 (7x19x6). To buy one "double rubber seals bearing(2RS)" from Boca,make sure it is "C3" class.
Dino
Dino, I was looking on the boca site for the front bearing for the D3. I just had a few questions. What is the difference between the ceramic bearings and phenolic plastic bearings? also what is the C3 class?
thanks Jason
.:Go Engines vs. Jammin Engines:. lanerbrainer205 Nitro Off-Road 20 12-23-2007 04:46 PM
.12 Engines sale all new pipes too. 6 engines ericsp2 R/C Items: For Sale/Trade 1 08-06-2007 02:19 PM
os engines compared to rb engines rhymster Onroad Nitro Engine Zone 4 08-03-2007 05:13 PM
IDM engines and picco engines foampervert Onroad Nitro Engine Zone 5 11-23-2006 05:36 AM
SH engines crazyjr Onroad Nitro Engine Zone 7 01-20-2006 03:13 PM
