IDM Products?
#395
hi,
my idm 12evo3 can't hold a stable idle...the moment i let off the throttle; it'll just die off. if i throttle from about 1/4 to max, it's ok.
however, if i adjust the idle screw to have a 2-3mm gap; it seems ok but isn't 2-3mm idle gap too much?
is it caused by the lsn being too rich or too lean? how to tell?
#396
hi,
Your needle settings are what seem to be wrong. Also check to see if everything else is ok as well. Make sure no air leaks in the fuel line as well and then just reset the needles and start over. You may be chasing the needles at this point. Turn the HSN to flush with the needle housing and then turn the LSN to around 3mm out of the housing as well. With the adapter for the servo connection on. This is where it will protrude from. These are rich settings so work from there with the HSN first get that set so the engine pulls strong down the straight then move to the LSN and work with the idle. Raise the idle so it runs and then make sure the engine has good smoke of the corner for about 1/4 of the length from the turn to the next turn this will me slightly rich but then you can set the idle and work on fine tuning it. If you need some more help PM me.
#400
so it's ok for the idle gap to be large as to get the engine to idle without stalling and work on the hsn 1st?
what's the supposed/stock idle gap for yr above mentioned stock lsn and hsn settings?
#401
I have never seen a set gap. We can get close with the size but all engines are different. I will get some more info and post it. It can be a little large not excessive if this is the case there is another issue. But do not be afraid to turn the idle speed up a little. And yes it is ok to get the idle going and work with the HSN. But keep in mind that you want to get that set as quick as you can or as close to being set. The key to this is to get the engine running on the starter and then get the idle somewhat decent. Not sceaming high. Get the engine warm then run the car on the track. 2 laps fast as you can drive do not wreck the car. Set the needle with these laps 2 at a time slow down in the infield you are working only with the HSN. The work with the LSN after you have to good power. Then when you work with the LSN work with the idle this will also change as you change the LSN. Remember that the engine does not tune like a Nova it runs a little leaner on top and richer on bottom.
#402
hi xs,
something about the carb 'neck' which goes into the engine...
there's a gasket at the neck; will this gasket be visible after installing the carb into the engine? or this gasket shld actually goes 'into' the engine and not visible at all?
i discovered that there're oil around the 'neck' area.
#403
You should see the gasket but nothing more. It should be compressed. The carb fits tight into the engine. If there is a leak this will also make your needle settings all off. Make sure the carb is seated in. If the carb body does not go in all the way take some real fine sand paper wet/dry maube 600 grit or higher. And clean up the small aluminum area on the bottom then the carb will go into the engine a little smother also use some light oil for the neck when installing. So it will work past the oring in the engine case.
#405
If you set the needles with low speed to lean you will end up with a lean engine at about 2 min into a race or qual. if you are pushing the car. The engine has to be rich on the bottom to keep the engine cool. If you richen the top in a effort to make a large change in engine temp to the engine you will slow the engine down as the top now will be to lean. The engines do not tun like a Nova engine or Sirio's They use the low speed needle to keep the engine cool. The engines normally will have a larger idle gap then any others due to the rich low speed. This does not at all mean that the engine should be stumbling rich of the corner it should be crisp and smooth with alot of smoke like I said earlier. If you are stumbling rich on the bottom then do as Sean stated above and lean bottom and very slightly richen the top. And I mean small amount for the top needle.
