Old 12-23-2008, 05:24 PM   #406
NitroWD's Avatar
Default problem solved?
did a quick idle test for leakage (about half tank) after applying some rtv (previous nite) to the carb 'neck' where it goes into the engine.
idle gap about 1+mm to keep it idling.
seems to be ok at temps of about 80+degC.
will go to the track to re-tune and do some high temps check.
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
NitroWD is offline   Reply With Quote
Old 12-23-2008, 09:23 PM   #407
entitymugenmtx's Avatar
Trader Rating: 81 (100%+)
Send a message via AIM to entitymugenmtx
Can someone help me I just bought a IDM EVO3 .21 I need to shim it for 30%.
the engine only came with one shim .20 how many do I need to run 30% fuel.
Thanks allot
SPONSORS.....MY CHECKBOOK....
entitymugenmtx is offline   Reply With Quote
Old 12-24-2008, 07:17 PM   #408
Thanks allot
DOES ANYONE KNOW
Old 12-24-2008, 07:39 PM   #409
DOES ANYONE KNOW
I though that I answered the question. You should use 2 .2mm shims for 25% and you can add .1mm more if you would like to be on the safe side. I would recommend using 25% you will have some better milage as well as easier on the engine with no real power loss.
xspower is offline   Reply With Quote
Old 12-25-2008, 02:57 PM   #410
VIPMOTORSPORTS's Avatar
Default shims
I'm running .3 on mine w/ 25%nitro
Motonica-USA // Novarossi // TKO Bearings // Airtronics // Protoform
VIP Auto Group Inc.
VIPMOTORSPORTS is offline   Reply With Quote
Old 12-29-2008, 03:01 AM   #411
keavze's Avatar
Default evo2 and evo3 rods
hi,
are the conrods for .12evo2 and .12evo3 interchangable?
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 12-29-2008, 04:45 AM   #412
Originally Posted by keavze View Post
hi,
yes they are
Old 12-29-2008, 11:43 PM   #413
keavze's Avatar
thanks xs.
is my LSN or HSN still too rich if there's abit of oil 'spitting' out of the carb inlet? (filter is removed).
however temp my .12evo3 and is running at 120+degC.
Old 12-30-2008, 05:03 AM   #414
No that is a bit normal as the engine is at a low speed then speeds up as long as the engine is producing good power and running at a good temp you are good to go!!!!
Old 12-30-2008, 10:42 PM   #415
NitroWD's Avatar
Default oil leak or too rich?
hi,
previously encountered unstable idle and found oil leaking from the carb 'neck' fitting into the engine.
upon close inspection after removing the carb; found a small tear on the carb neck O ring, replaced with a new O ring and refitted carb to try again.
now there's no oil seen at the carb neck area after a few hard runs and idle is ok now. temps at about 270F.
however noticed that there's oil on the LSN rubber sleeve. what's the possible cause?
Old 12-31-2008, 03:19 PM   #416
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
you have the carb bellow circled, i would replace it or take it off and clean it
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 12-31-2008, 03:49 PM   #417
Yes other wise it will leak air into the slide. Not good replace it.
Old 01-15-2009, 12:39 PM   #418
T-ROY22's Avatar
Does the IDM .12 engines have stronger internal materials than the JL Red Dot? What advantages are there of IDM over the JL Red Dot if any? I love my Red Dots just want to step up!
T-ROY!
Mugen Seiki USA,Enneti Tyres, Murnan Modifieds, Airtronics USA
T-ROY22 is offline   Reply With Quote
Old 01-15-2009, 01:09 PM   #419
Same SH!T
ich wei
hello is offline   Reply With Quote
Old 01-15-2009, 03:30 PM   #420
The engines have a smaller crankshaft intake track then the JL. And the sleeve is slightly different.
CEN Products SCOOTER29 Rookie Zone 9 09-22-2005 01:57 AM
cen products chifan26 Nitro On-Road 7 09-19-2005 02:50 PM
