Old 04-12-2008, 06:52 PM   #1366
RayJ's Avatar
Originally Posted by gortan View Post
dear all,
i'm in need of advice. I've got myself an ofna jl3 engine. I've done the break-in without issues.. comfortable running temperature.. good smoke trail, nice sound while accelerating, etc. After the break-in I was happy with the performance although I knew the motor could be pushed further. So far I was using 20% nitro.
After I changed to 16% I've started seeing some issues. To get the same performance and get the car to shift at same spot on the track, I had to lean a bit the hsn. Now the temperature runs higher...260F with less performance then I've had with 20%. any leaner and the engines gets too hot. Also when gradually accelerating the car off the ground, it starts fine but at a point in time, the revs start dropping rather than increasing, but there's still alot of smoke coming out...
I've read somewhere that this engine is shimed already for 30% nitro. Should I remove a shim and see if it helps?
I may blame the pipe as well. I'm running a copy of an efra 2017 pipe.
I ordered a picco 2607 now but it's still a month away to get it. Would the tuned pipe make the difference I'm looking for?
thanks.. sorry for the long post.
g
In your case, I would remove one of the copper shims and richen the HSN out from the leaner settings you tried above. Then I would retune the motor. If you have to much head clearance with low percentage nitro............the fuel mixture is not being compressed enough for optimal burn. The motor will produce lots of smoke, create lots of heat as a result of over leaning... ...........and not make alot of power. Don't blame the pipe......maybe it's not the optimal pipe........but if the motor ran good with the 20% ...it will do fine with the 16% ....if it's shimmed properly. I would have removed a shim with even the 20%.
RayJ is offline   Reply With Quote
Old 04-12-2008, 06:59 PM   #1367
Team Kamikaze's Avatar
Gortan,
RayJ is right, you will need to remove shims if running lower percentage nitro, other than 30%, I would suggest a total of .30mm shim, right now out of the box the engine had a total of .60mm shim=(3 x 20mm shims) you will need to remove 2 x .20mm shims and add 1 x .10mm shim = total of .30mm.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 04-12-2008, 11:43 PM   #1368
thanks RayJ and Kamikaze. You've put my mind at rest....
Thanks again! Very helpful...
gortan is offline   Reply With Quote
Old 04-13-2008, 12:48 AM   #1369
where would it be possible to get parts for jl3 online, such shims, conrod etc?
preferably based in europe...
do shims have to specific for a motor or would it be possible to use shims from other manufacturers?
thanks...
Old 04-13-2008, 12:56 AM   #1370
Colt4g63's Avatar
Originally Posted by Team Kamikaze View Post
The 2607 is amazing isn't it? if you compare it to other pipe it's just a night and day difference.
My X-Dyno says the same exact thing about this pipe on the JLR. It's the perfect match for the JLR IMO. The JLRs have some very high timing profiles which will make an engine picky on pipe selection.. Especially the EVO2 and the new EVO 3 Tuned versions as there sleeve timing is identical. The EVO 3 is a little lower on timing profile so its a little more forgiving. But matched with the 2607 they make great power from bottom to top with AMAZING TQ and HP for a .12
Adam Blevins Owner/Operator of AB Mods X-Dyno equipped and World Record holding engines!
www.ABMods.com
Colt4g63 is offline   Reply With Quote
Old 04-14-2008, 10:43 AM   #1371
i just removed the head.. and found 3x0.1 and 2x0.2 for a total of 0.7mm!
i guess i'll test with 1x0.2 and 2x0.1 for a total of 0.4mm...
bad/good?
please let me know... thanks for your valuable help so far.!
Old 04-14-2008, 06:54 PM   #1372
keavze's Avatar
bad/good?
0.4mm will be good for up to 20%nitro...
for 16%nitro, 0.3mm will be enuff.
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 04-15-2008, 02:05 AM   #1373
Don't just look at the shims and assume it's your head clearance, it's not in most cases. Take off the button, turn the piston into uppermost position (make sure the liner does not lift) and measure the distance between piston and upper edge of the liner. This will be your measurement A.
Then remove all shims from the head button and measure the height of the button part that goes into the liner. This is your measurement B.
Now do A-B, this equals your head clearance with no shims. Can be both positive and negative (although I've only seen positive, but I haven't seen too many of them ). If the result is, lets say 0.3 mm, this means you should only use a 0.1mm shim to get a 0.4mm head clearance. Around 0.4-0.45 is what I've often seen suggested for 0.12 engines and 16% fuel.
In real life things can be a bit more complicated, if the piston has a dome or cavity, the button is not cut straight, but at an angle, different volume of the button cavity etc... they all affect compression. So it's not 0.4mm set in stone, but depends on the engine, application and environment.
olev is offline   Reply With Quote
Old 04-15-2008, 03:11 AM   #1374
keavze's Avatar
yup, actual head clearance...not shims.
you could also use the 'solder test' to check actual head clearance.
Old 04-16-2008, 05:41 PM   #1375
Sam, Will the 2607 pipe fit without issue on my CRT .5?
morati is offline   Reply With Quote
Old 04-17-2008, 12:44 AM   #1376
The 2607 pipe will NOT fit the CRT.5 at all.
Old 04-17-2008, 03:20 AM   #1377
Uga
Uga's Avatar
Hi, guys!
I just ordered an evo3 for my Mugen MTX4R, just wanted to know the recommended gearing/clutch/transmission settings for this beast.
-=Xray XB4=-
-=Xray XB8E=-
-=Schumacher Cougar KF2=-
-=Awesomatix A800X=-
Racing in Latvia
Uga is offline   Reply With Quote
Old 04-18-2008, 06:11 PM   #1378
I was just wondering if anyone has purchased this engine from Tower Hobbies and if they got the evo3 or if it is one of the older ones. On their website it doesnt say which version, it just says jlr red dot and has a picture of what looks to be the older one. Since newer versions have been out for awhile, I didnt know if it was possible for them to still have the older ones.
robzzz is offline   Reply With Quote
Old 04-18-2008, 06:22 PM   #1379
My friend bought one from Tower hobbies and it was the old JL Red Dot, he end up returning it.
hello is offline   Reply With Quote
Old 04-18-2008, 06:30 PM   #1380
quietstorm76's Avatar
I ran a Stock EVO3 at the Kyosho US Open champs and it ran great. Awesome bottom and mid torque. I geared for the straight and I had plenty. It lacked the power of my Murnan Reddot but it is a very very strong engine. With the IDM 2617 it flat out hauls azz.
Guys I'm telling you there's not a better bang for the buck out there.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Misc Stuff Much More, Xray, GS Racing,Peak Racing Pro Models R/C Items: For Sale/Trade 2 05-27-2007 09:41 AM
FS: Savage hop-ups.THS.Trinity.Hardcore Racing.Robinson Racing.HPI.Hitec factory racer R/C Items: For Sale/Trade 10 06-23-2006 05:17 AM
2006 Hobbytown Oshkosh Off Road Racing Season Opener FREE RACING!!! Zac R Wisconsin & Illinois Racing 18 05-23-2006 11:37 PM
HMS Racing - Sole distributor Nova TOP, REX & JP Racing engines hmsracing Malaysian R/C Racers 58 03-15-2005 09:40 PM
Racing Model Sailboats - Strategy and Racing at its Finest rcinsight Web Links 0 01-08-2005 01:49 PM
