Old 04-22-2008, 03:22 PM   #1381
rankev11's Avatar
Have any of you guys drilled an extra set of holes in the 2607 manifold for an extra manifold spring? If so, what's the best way to do it. There isn't much meat there and it will take a steady hand and a good bit I suspect. Due to the fact the manifold sticks out so far I feel this is going to be a must do to finish a long main. I ran the engine for the first time and really liked it but after post-race teardown I noticed the manifold was hit sometime during the day and the gasket barely made it. I also noticed a nice melted spot in the side of my body where the manifold was touching. I guess some aluminium tape is also needed.
rankev11 is offline   Reply With Quote
Old 04-22-2008, 04:05 PM   #1382
gearhead13's Avatar
I have been drilling extra holes in my manifolds lately. One smack on the side and your race could be over.
I put an extra hole in the top and ran an extra spring around the top. That keeps it from being pulled down off the gasket.
Serpent
Xray T2
OFNA/Picco red dot
Picco 2607 pipe
Dynamite race 20%
gearhead13 is offline   Reply With Quote
Old 04-23-2008, 08:18 PM   #1383
gearhead13's Avatar
I tore down my EVO3 after a few tanks and it had 3x.2mm and 1x.1mm (0.7 total) I then measured the piston to top of liner and head button with no shims and with no shims there would be zero clearance.
I am running 20% so I was thinking of 0.4 mm shims. If the clearance is too tight, I would suppose it will blow plugs a lot?
BTW: Thanks to Kamikaze for the fast shipping (less than a week to Canada) and no duty or tax. In time for next sunday raceday
Serpent
Xray T2
OFNA/Picco red dot
Picco 2607 pipe
Dynamite race 20%
Old 04-24-2008, 01:43 PM   #1384
hi gearhead...
I've also found .7mm in total 2x.2 and 3x.1 in my evo3. Everybody else's seems to have 0.6mm but maybe it was an evo2 rather than evo3.
my engine ran fine (not exeptionally good) with .7mm and 20% nitro. As soon as I dropped to 16% it started to cut out at wide open throttle and run too hot. If i richened, the performance would be so low it would not change to 2nd gear.
no i dropped to .5mm and the temperature and performance is fine but i beleive it could be better. I saw no damage to the glow plug wire until now either.
I'm using a 2017 pipe..It's old, it's 3 chamber and it's designed for .21 engine. I don't know how it fits in my X-ray, but I got it without checking. Now I'm waiting for 2607 pipe ... I'll see how the engine performs with this pipe.. and then next thing will be to try 0.4mm
g
gortan is offline   Reply With Quote
Old 04-24-2008, 02:40 PM   #1385
It seems to me your running the wrong pipe on the engine. The chamber is way,way big and also it is a 3 chamber. The pipe will make the engine run terrible with no questions asked. I would get a pipe that is made for the size engine and reset the head clearance and then run again. We use standard head clearance with the 16-20% and no issues. You leaning it out and loosing the power and such is telling me the pipe is killing the engine. Please remember that the pipe resonates and this is part of the engine making power.
Originally Posted by gortan View Post
hi gearhead...
g
xspower is offline   Reply With Quote
Old 04-24-2008, 02:46 PM   #1386
gearhead13's Avatar
My EVO2 came with 0.6mm shims and i went to 0.4 mm on 20% I ran it for testing but not any racing. No signs of detonation. Made lots of power with the 2607 pipe. I am at or near sea level here.
Serpent
Xray T2
OFNA/Picco red dot
Picco 2607 pipe
Dynamite race 20%
Old 04-24-2008, 02:48 PM   #1387
i'm very confident the pipe has a big affect and that I've got the wrong one.
i won't go less than 0.5mm before I get the 2607 pipe, which so far has been the best match for this engine according to 100s of posts on various forums.
thanks.
Old 04-24-2008, 02:57 PM   #1388
sea level here.. highest point in this country is around 250m, and the track is close to the sea
thanks ever1.. i find this feedback very encouraging, as i though the something was wrong with my engine. my 2607 is due soon now
i hope to come back with positive results
g
Old 04-27-2008, 02:05 PM   #1389
LOW ET's Avatar
Trader Rating: 97 (100%+)
i hear the red dots like a rich bottom end, if using the tuning tips here
http://www.youtube.com/watch?v=wfAOq4jR2Y8
http://www.youtube.com/watch?v=4UyyOnYwHPM
should the engine idle longer than the 20 seconds and with the pinch test should the car run for more than 5 seconds? maybe that engine uses 20 and 5 seconds and the red dot uses 25 and 10 seconds, etc...???
LOW ET is offline   Reply With Quote
Old 04-28-2008, 08:18 AM   #1390
bugnet's Avatar
JL Racing .12 accept novarossi turbo glow plugs ? wich ones are best option to use with ?
thanks
Ir ur coming bring me some
bugnet is offline   Reply With Quote
Old 04-28-2008, 08:24 AM   #1391
thanks
No they will not. The taper of the turbo seat is different, they will thread in and damage the combustion chamber seat. They will run but they will leak. The best plugs that are for those engines are the Picco plugs or the IDM. There are othes that share the same taper but I do not have any info about the others performance.
Old 04-28-2008, 11:09 AM   #1392
JRGTR's Avatar
Send a message via MSN to JRGTR
I have 2 IDM piccos, the powerfull Evo3 and the all mighty Evo2, I run both with O.S. plugs(7 medium) I use the 2 for short tracks with IDM2607 and the 3 for long tracks with IDM2617 and they run perfectly, once I put the OEM plug again and there's no leak and runs the same way. exept that the O.S. plugs have e longer live than the OEM plug. both plugs works fine with my engines.
MTX5/Novarossi engines!
Byron's Racing Fuels/Airtronics
Matrix tires
www.pitlanehobby.com
JRGTR is offline   Reply With Quote
Old 05-04-2008, 11:22 AM   #1393
fire929's Avatar
Default Glow Plug
Originally Posted by Team Kamikaze View Post
When breaking in the JL EVO 3 engine all you need is one tank at idle just to break in the connecting rod, on the the second tank you can already race tune the engine, don't have to do the WOT, it is not necessary for JL EVO 3 engine, you do the WOT only if it is a Nova Rossi.
What is a good plug to use for cool, warm and hot days for this motor? Also what is a good pipe for the jl evo 3
Trex 450
Trex 600
EFL Heli's
Futaba 8fg
Align 3gx
fire929 is offline   Reply With Quote
Old 05-04-2008, 01:45 PM   #1394
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
As said over a million times on this thread the Picco 2607 pipe is the best pipe for max performance. Team Kamikaze is a great site to get them from.
HarKonnenD is offline   Reply With Quote
Old 05-04-2008, 06:52 PM   #1395
Team Kamikaze's Avatar
The only plug that runs the best with the any JL engines is the PICCO P6TC.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Misc Stuff Much More, Xray, GS Racing,Peak Racing Pro Models R/C Items: For Sale/Trade 2 05-27-2007 09:41 AM
FS: Savage hop-ups.THS.Trinity.Hardcore Racing.Robinson Racing.HPI.Hitec factory racer R/C Items: For Sale/Trade 10 06-23-2006 05:17 AM
2006 Hobbytown Oshkosh Off Road Racing Season Opener FREE RACING!!! Zac R Wisconsin & Illinois Racing 18 05-23-2006 11:37 PM
HMS Racing - Sole distributor Nova TOP, REX & JP Racing engines hmsracing Malaysian R/C Racers 58 03-15-2005 09:40 PM
Racing Model Sailboats - Strategy and Racing at its Finest rcinsight Web Links 0 01-08-2005 01:49 PM
