JL Racing .12
Old 02-21-2008, 08:10 AM
  #1216
badKarma's Avatar
can anyone tell me a good high temp silicone sealer for the carb??
badKarma is offline
Old 02-21-2008, 10:05 AM
  #1217
Im currently running 16% nitro with .40 shim,can anyone tell me wat is the different if i i took off .10 shim to make it total of .30 shim in engine? does it increase the torque of the engine? wat is the best shimming for 25% nitro? thank u
barry is offline
Old 02-22-2008, 07:44 PM
  #1218
Team Kamikaze's Avatar
Originally Posted by jscamry View Post
Team Kamikaze-sam
How was the Nats? I called your shop, but you and your team was at the race. How did your drivers end up?
Thanks Jason.
We did pretty good, but we run 8th scale only and of course with our trusted PICCO engines.
Any Oxygen sensor safe silicone gasket from an automotive store will work.
your question: if i i took off .10 shim to make it total of .30 shim in engine? it will increase the Torque of the engine, the best shimming for 25% nitro will be a total of .50mm shims.
Team Kamikaze is offline
Old 02-22-2008, 07:56 PM
  #1219
Originally Posted by corney_01 View Post
hey thinking of getting an JL evo3 and wondering if you guys are modding these engines or running them out of the box
cheers steve
Talk to ABMODS, pm him he does a good job modifying this engine.
Old 02-22-2008, 08:22 PM
  #1220
badKarma's Avatar
can anyone explain to me the NT1 fly wheel collar for this engine? i was told to buy this with the engine...can someone explain why this is needed? i was also told that the Skyline V12 pipe was not compatible with the NT1, is this true? thanks
badKarma is offline
Old 02-22-2008, 10:49 PM
  #1221
According to Xray, the NT 1 Flywheel is thinner than most flywheel, that is the reason why Xray have the NT 1 collet specifically made for PICCO engine, just to make sure it tightens correctly, and I don't understand who told you that the Skyline VR 12 pipe is not compatible with the NT 1, I don't see why will it not be compatible, I think who ever told you that will need to explain why he said it is not compatible.
Old 02-23-2008, 06:35 AM
  #1222
badKarma's Avatar
can anyone explain the Oxygen sensor safe silcone gasket? im kinda new to this...does it come in sizes? should i not use a tube based silcone sealer?
badKarma is offline
Old 02-23-2008, 09:27 AM
  #1223
Oxygen sensor safe silicone gasket does come in a tube.
Old 02-24-2008, 07:52 PM
  #1224
Trader Rating: 14 (94%+)
Default picco 2607 pipe touching the body
guys ive put on the picco 2607 but im havng problems with the manifold hitting the body. ive grinded down the collar on the back of the manifold to make it better but its still rubbing
has anyone found any other mods to fix this? the engine is on a rrr evo
thanks
john
mrgsr is online now
Old 02-24-2008, 08:16 PM
  #1225
Trader Rating: 28 (100%+)
thanks
john
That is how it is. The manifold is straighter than most others and because of that the manifold is going to rub the body.
Scott Fisher is offline
Old 02-24-2008, 08:17 PM
  #1226
Thanks scott
so put up with it?
mrgsr is online now
Old 02-24-2008, 08:38 PM
  #1227
Thanks scott
so put up with it?
It's not going to hurt anything, a little rubbing is okay.
Old 02-24-2008, 08:56 PM
  #1228
nitrodude's Avatar
Been running that way for a while, and dont have any problems.
nitrodude is offline
Old 02-24-2008, 09:12 PM
  #1229
thanks for that i just noticed the body sticks out a bit
mrgsr is online now
Old 02-24-2008, 09:47 PM
  #1230
jscamry's Avatar
Which body are you running?
jscamry is offline
