Like Tree50Likes
Triton RC new engine...
Old 04-08-2017, 08:05 PM
  #826
YANMAN's Avatar
Trader Rating: 41 (100%+)
Hey guys. Can we get this back on task and talk about Triton Engines. Sorry I said something but I know both Neal and Lance. If you have questions about your Nitro Shop engine head over to that thread or contact Neal. Thanks everyone.
YANMAN is offline
Old 04-09-2017, 06:05 AM
  #827
Maximo's Avatar
Originally Posted by kyosho28
That makes no sense. He said this was the first he heard of this.
I now know who this is and last I was told everything was working great !!
sorry to disrupt the thread !!!
Maximo is offline
Old 04-09-2017, 06:42 AM
  #828
ROSCOE's Avatar
Trader Rating: 130 (100%+)
Wrong thread guys! Handle your personal problems somewhere else.
Post em if you got em! Lol
Maximo, ArronRC and go4broke like this.
ROSCOE is offline
Old 04-09-2017, 06:56 PM
  #829
Default TNS
Hey Neal thanks for getting in contact with me today and I'm glad I got to talk to you , And once again thanks for all the info that you given me about Nitro racing
Trubbs is offline
Old 04-16-2017, 07:54 PM
  #830
Default L4 Elite
Damn I wish I knew this new motor was coming out just bought my Triton L4 a few weeks ago and just broke it in three days before I seen the the new engine I would have gladly spent the extra 40 bucks for the DLC coated crankshaft and all the other new stuff on the new engine . SHIT !!!!
brokenmoto likes this.
Trubbs is offline
Old 04-17-2017, 03:05 PM
  #831
Panic09's Avatar
Hey guys, 2 stage idle on an l4 ...I just need to keep leaning the lsn needle till it's gone and then adjust idle through the idle screw ?
Panic09 is offline
Old 04-18-2017, 10:44 AM
  #832
Rcrenew's Avatar
Start with backing out the idle screw an hour or so.
Rcrenew is offline
Old 04-18-2017, 11:01 AM
  #833
am
You do not need the DLC when the enine is made from Picco:-) Yes, it will hold up better, but the high quality Picco crank will lst many many gallons as long as you use good fuel and change your airfilters often.
am is offline
Old 04-20-2017, 05:58 PM
  #834
Trader Rating: 32 (100%+)
Default 6mm venturi
I have just purchased a L4 with about a gallon on it for my sons buggy. Looking forward to firing it up. Anyone have an extra 6mm venturi they don't need? Please PM me.. Thanks
Brandon Powell is offline
Old 04-20-2017, 06:12 PM
  #835
Rcrenew's Avatar
Fingers crossed the seller took proper care of it. Buying used engines rarely work out well.
I would stick with the 7mm venturi, going smaller will narrow the tuning window and really wont gain any mileage.
Rcrenew is offline
Old 04-20-2017, 11:42 PM
  #836
Wow. Just ran my 1st idle tank threw this girl. I don't even want to say how long this thing idled. Just say out of the 8 engines i've broke in this thing idled 3 times as long as anything else i've touched. Hopefully tomorrow will be the end of break in.
brokenmoto is offline
Old 04-21-2017, 03:56 AM
  #837
Mikeand22's Avatar
Trader Rating: 30 (100%+)
I've seen a number of posts talk about 10 minute run times, what carb insert are you running to get that kind of run time? Thanks
Mikeand22 is offline
Old 04-21-2017, 04:44 AM
  #838
ROSCOE's Avatar
Pretty amazing how well they run even on the very first start up!?! Same case here, expected to babysit them on the first idle tank but basically walked away with very little for hiccups.
ROSCOE is offline
Old 04-21-2017, 05:58 AM
  #839
Rcrenew's Avatar
Most of the guys are running the stock 7mm venturi or the Triton Duo venturi. On the L4/L5 you don't gain much if any mileage going smaller than a 7mm venturi.
Rcrenew is offline
Old 04-21-2017, 07:59 PM
  #840
Jwcole's Avatar
I run mine with the 7mm Venturi and a #5 plug most of the time. I use 30% fuel from either bones or byrons and I get consistent 12 minute tanks out of my buggy. In race trim with the race trigger finger I pit at 10 to 10:30 with fuel to spare. There's no magic science behind what you have to do as a user. These engines just perform that well. If it's not getting the mileage then it's more than likely not running at peak performance yet. Lean that puppy!! If there's smoke and good power it's fine! Power will suffer as smoke diminishes when getting too lean and it will begin to sound flat right before you start getting to the danger zone........these things are incredible little mills! Also there is a plethora of knowledge here on this forum and we are all willing to help! Good luck and happy racing!!
Jwcole is offline
