OS Speed B2101 engine
#317
I ran Reds last year, Picco abit until now, and going to run in an OS B2101 tomorrow if the wether holds up. I let you know.
#319
Not trying to jack your question but If you don't like instantaneous power you will really like the B2101. It has the same top end as the speed spec 2 but the bottom is super smooth. I as well tried the spec 2 in buggy and didn't care for the explosive power it had.
#321
Started break-in of mine 2101 yesterday, and overprimed carb a lot (didn't see fuel level in fuel lines). Didn't realized whats happening, so there were several attempts to start flooded engine (maybe 6-8 total, half of them with untighted plug), engine was preheated to 180F. Of course it didn't start until i took plug and filter off and removed all excessive fuel. Now i'm worrying about any possible damage made to engine.
Oh, and after all that i've fired it up, now it has 4 total tanks of breakin, no any noticeable sings of something awful, only sweating oil from fr.bearing.
#323
#324
Only got abaout 1.5 liters through it today. Very linear engine. It is still very very tight and a noob smashed my brand new OS 2090 pipe :-(
I ran with 7mm venturie and it has almoast the same amount of top end as my Boost 5TR ceramic with 2099 pipe.
I need to get atleast a gallon though the 2101 before i can make a good comparison. I tried lapping the piston in the OS but my tool was abit to small, so i stopped. I would not damage the piston.
#325
That sounds good. Actually i haven't ever turned engine with plug tightened, just burned some rubber on st.box' wheel=) Seems that not-so-grippy tekno flywheel made a good job at this time
What is reasonable temp range for this mill? I'm already at 0.8L mark, so it gonna be race-ready in next 1.5L (i hope), and curious about temps. P4 plug when 70F and above.
#327
I just finished my 10 tanks of break in and from the 6th-10th tank, with the cooling head wrapped with foil and the needles being around 1.5-2 turns too rich, temps were around 85-90*C (200*F)
#328
Update for my engine, ran another 3 tanks in, and on the 3rd tank, I did a run time test. Tune is still rich on the LSN, maybe a little rich on the HSN, doing 3 second bursts of full throttle where possible on the track.
The results: 12 Minutes, 4 seconds.
This engine sure is promising.
#329
What is balleye average racetune for 25% with this engine/carb?
#330
I have no idea what my needle settings are from open or fully closed, I don't tune that way. I tune by sight and sound and how the engine acts.
