OS Speed B2101 engine
#166
So what pipe is recommended to use in a buggy with this engine? 2090?
What are the characteristics of the 2090 and the 2060?
#167
I prefer the 2090 on this engine as it already has an extreme top end and could use a little bit of bottom end at Fear Farm. For some smaller tracks with a loose surface, the 2060 would be prefered, but with a higher bite surface, you really can't go wrong with the 2090.
#168
I have been running the 2090 on my B2101 for the past few weeks. Basically the 2060 is a top end pipe with a very smooth bottom end, while the 2090 helps make the bottom end response more crisp and not providing quite the top end power the 2060 does.
#169
Hard to say, I still don't have enough time on the engine to get the best mileage yet. Also haven't ran the 2060 long enough to go for mileage. You know what I mean? I basically just go for the power output, and as long as I can make 7:30 to 8 at my local track I'm fine. Will know more in the coming weeks.
#171
#172
Yeah, not a bad effort at all.
http://www.youtube.com/watch?v=rpCoh...ature=youtu.be
This is our track . . .
#173
#174
I've found the new b2101 to be a very aggressive engine. Personally the 2090 is too much pipe in a buggy as it makes you be very careful on the gas, the 2060 i find is better suited on a buggy as it smooths out the power and makes it easier to drive. Unfortunately it's not a 10+min buggy engine and is marginal in truggy. The reds engines i ran previous were much better on fuel but lacked the brute power of the new os.
#175
I saw your post a couple pages back, and you shouldn't be making this claim. You said you were running the smallest Nitro-mizer insert, these inserts get their mileage from eliminating the torque of the engine so that even heavy-finger guys can get better mileage. Comparing the small nitro mizer to a standard 6mm insert is like comparing a 5mm insert to no insert at all and then being surprised that having no insert makes more power.
I have ran the Reds Team Edition like you have, and this is the only stock engine I have ran the will blow the doors off of a speed long stroke, both bottom and top end. I have never before seen an engine pull as hard on the bottom end as the Reds does.
A more apt comparison of the bottom end of this engine is that the Protek short stroke engine with the 2060 top end pipe has a more explosive bottom than the B2101 does. I will stand by my claim that the B21 is the most tame speed in years.
#176
That is also the statment from Os. The b2101 is not ment to replace the Xz-B speed, but to be used were the XZ-B is to much of an engine.
#177
Keeping that in mind, would it then be better to run an Speed XZ-B Spec II or the B2101 on a medium sized, moderately technical track with a mix of low-speed and high-speed corners, and large jumps with short run-ups that can (in some cases) need decent low-end torque to clear?
My understanding is that if the B2101 has "less" torque, it is therefore a smoother engine on power delivery, and may need some more time to spool up?
#178
And it's hard to explain in those terms, its not that the b21 takes longer to spool up, it's that it makes more power at a higher rpm and a smooth growth of power. The XZ-B just makes more power at a much lower rpm.
#179
I guess the point you were making is that the type of track and driving style has much to do with fuel consumption; which is the reason I showed our track - the short stroke 2101/6mm/2090, with its' torque/HP higher in the RPM band was able to push a truggy around a tight, twisty track (with short ramps) and still had decent mileage.
. . . you were running the smallest Nitro-mizer insert, these inserts get their mileage from eliminating the torque of the engine so that even heavy-finger guys can get better mileage. Comparing the small nitro mizer to a standard 6mm insert is like comparing a 5mm insert to no insert at all and then being surprised that having no insert makes more power. .
I suggest that it's not just size that matters (she said ) - it is to do with efficiency of the carb and the venturi affect.
IMO - effectively the mizer does two things - it detrimentally affects the efficiency of the carb lower in the RPM range and limits the total of CFM (CIM?!) that the carb can flow higher in the RPM range.
IMO - The Nitro-Mizer detrimentally affects the efficiency of the carb lower in the RPM range as it lacks the contour/shape of a venturi (one side of a mizer insert is not a "venturi" at all - it is a flat face; thus reducing the beneficial 'venturi affect'. (Carbs only work because of the venturi affect) - IMO - the mizer is a "restrictor insert", not a "venturi insert" . . .
FYI - Last race meet I replaced my 5.4mm (purple) mizer with a 6mm OS venturi, and I was required to lean my HSN by 2+ hours - this is because the change in airspeed / venturi effect. (The 6mm OS venturi insert actually increased the airspeed/draw through the carb - thus I could limit the fuel flow)
A shorter stroke engine compared to a longer stroke engine:-
- they might produce the same amount of HP, however the shorter stroke engine will start to produce more significant amounts of HP higher in the RPM range, compared to a long stroke motor, which will start to produce the HP it is going to make lower in the RPM range.
- the air speed through the carb of a long stroke engine turning at 10,000rpm will be higher than the air speed through the same carb fitted to a short stroke engine turning at 10,000rpm.
The same size venturi, or a mizer fitted to a long stroke vs a short stroke engine will affect the engine's differently.
A long stroke engine with a small mizer fitted might be acceptable on a short, tight track. (Longer stroke keeps up air speed through the mizer restrictor at lower rpm / limited high RPM is of little consequence on the short tight track and the long stroke has already delivered its' best power earlier in the RPM range)
A short stroke engine with a small mizer fitted will feel horrible on a short tight track, and worse on a flowing fast track (more limited bottom-end where HP was low anyway / limited top-end where it want to make it's power)
This also explains why the mizers are more suited to modded engines - as the RPMs of a modded engine may increase more quickly, and/or air speed through the carb may increase more quickly.
#180
Ya I believe that this is mostly due to the track. I watched the video of your track, and I would run 12 minute pits all day if I were on that track.
http://www.rctech.net/forum/13602121-post142.html
