OS Speed B2101 engine
#286
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Still likely too lean on top if it sounds like it is hanging at the end of the straight. Engine is starving for fuel at top speed. Richen an hour and readjust idle if needed. Temps between 215-270 are normal. What is more important is the engine should sound correctly tuned from bottom to top with a healthy idle and good smoke trail.
#287
#288
see that quite often.
check if it stucks and lined up properly.
#289
As an aside, if you are running any venturi insert, the throttle should not open wider.
#290
how does the B2101 run with the 2060 pipe? About what should I start with as far as needle settings with 7.0 insert?
#291
Why 7.0mm?, start with 6mm. Needle settings are in the instruction manual, have a read.
#292
I got what I needed in my records from when I ran an xz-b.
lsn=flush and hsn=2mm in. plus I looked at a few top drivers photos of there cars to confirm.
#293
This might be useful, Gord Tessman's running method ![Smilie](https://www.rctech.net/forum/classic_images/smilies/smile.gif)
https://youtu.be/oViIFCYKA1s
in my opinion for breakin, 7.00mm buy's nothing, heating before start much more....
In use less run time ....
#294
Hey guys, how many gallons before changing piston and sleeve ?
I am already in my 4th gallon and engine still running great
#295
#296
Usually I get a strong 8 gallons out of my speed mills before I even think about pinching or changing the rod. Around 4 gallons I would listen to the bearings and think about replacing them if you haven't already. These engines run best on less compression that most other engines ever see. Unless performance is an issue change the bearings soon and let it run another 4 gallons.
#297
I have a Samurai OS 321B with 2090 pipe combo. Tune is good. Idle fluctuates and takes time to come down. Run time of 6 minutes. Not good. Tried another carb. Nothing. Changed fuel tank. Nothing.??.?.?.?.?.?.?.
#298
