OS Speed B2101 engine
#347
Hi all, I recently moved from Nova to Os, and decided to go for the b2101 I also bought a box of byrons 40% nitro so I have a few question
-Do I have to shim the head?
-I normally use 97t plugs on novas but I heard they're too hot for that nitro percentage so do I have to go for the P5 or the RP8?
-Do you recommend to make the break in using the 40% nitro?
Any help is really appreciated
#348
There is nothing about 'optimized for 30% in manual', it just says 'breaki procedure actions with 30% fuel'. Along with widely used 25% in Asia i highly doubt about 30% optimization out of box. Yes, it's 30% ready with 0.25 total shimming, but it isn't something like Werks engines built for 30% fuel OOB.
#349
#350
#351
#353
i just have to say this enigne is truly awsome. ALOT better than my Picco 5TR team ceramic. Just as fast as a REDS 5port V2, but better on fuel and smoother to drive. On this track i "only" could manage abaout 9:30 of runtime, as i used a Novarossi 2096 for the first day of quals. A seriously stupid dession.... Well, i did get help destroing my 2090 the 3rd tank when someone punted me very hard throwing 140 bucks out the window:-(
I got a new pipe, putting it in for the semi practice and my engines was a tad fat on LSN and HSn as my engine was at 89 degrees celsius, still making 9:15. I did lean the HSN a bit but not LSN, and this was the right way but not enough.
A friend made over 11 minutes running in semi practice and he made only one pitstop in the semifinale. This engine smooth, altough has more than enough power and has a screeming top end. This is one of the best engines i have ever had!
#354
9:30 here too...
#357
#358
If you absolutely need to make 10 mins, try limiting your throttle throw to get extra mileage.
Instead of the carb opening it to the full size of the venturi, try 10-15% less to start and retune (meaning lean) the engine, so it sounds and behaves about the same again on the bench. On the track, you'll notice that you're not going any slower, have a more usable powerband and you're using less fuel.
#360
Nope, totally unnecessary ...
