Like Tree352Likes
NOVAROSSI Engine thread....
Old 07-22-2011 | 07:42 PM
  #1306
houston's Avatar
Originally Posted by nitroburnt
Thanks for the input. I've heard good things about the 2013, may be my next investment (investment?). Is this the BEST choice for this engine in a buggy?
the 9901ss works very good also , afterall it is a novarossi
Im thinking 2096ss is another KILLER option
houston is offline
Old 07-23-2011 | 05:16 AM
  #1307
scrapsz's Avatar
Originally Posted by houston
Call me 5035446624
Trust me you can get insane mileage with a p5xlt
Monty - I will give you a call next week. Thanks
scrapsz is offline
Old 07-23-2011 | 10:32 PM
  #1308
simoranga's Avatar
Hey, Houston
I have a Nova P3XS and was reading about the front bearing in the P5 being no good. The P3XS has the same front bearing, would you also recommend changing it to the #17011 front bearing.
Cheers
simoranga is offline
Old 07-23-2011 | 10:41 PM
  #1309
houston's Avatar
Originally Posted by simoranga
Hey, Houston
Cheers
Yes I would, entirely up to you when but it should b done inside 2 gallonsish
houston is offline
Old 07-24-2011 | 04:57 AM
  #1310
hate to say it but the re11 is not that good on novarossi engines
many guys have been using the orion 2013 on the nitrotec with great success , the same pipes that are recommended for novarossi engines would be the same for the (novarossi 3 port) nitrotec
You hit the nail on the head! I threw on old JP1 and it really woke it up! Can't wait to try a 2013 or the Novas you listed. THANKS!
nitroburnt is offline
Old 07-24-2011 | 05:29 AM
  #1311
jin2803's Avatar
Hi ..Itz fine to use other brand of plugs on the BTTS???
jin2803 is offline
Old 07-24-2011 | 09:53 AM
  #1312
houston's Avatar
Such as?
If you put an os plug in there then stick with os
houston is offline
Old 07-25-2011 | 03:21 AM
  #1313
jin2803's Avatar
Such as?
Ok...Noted tks...I m using 97T..
jin2803 is offline
Old 07-25-2011 | 08:06 AM
  #1314
houston's Avatar
You can switch back and forth between odo and nova
houston is offline
Old 07-25-2011 | 05:33 PM
  #1315
Mohd Zailani's Avatar
My P5 is about 16 liters old.Havent change the front bearing yet.Just wonder what is the indicator when the front bearing starting to become bad.So far i cant really tell is there any different compare when its was new.Very minimal leaks aswell(compare to my alpha and pr21c).What to look for?Thanks
Mohd Zailani is offline
Old 07-26-2011 | 10:38 AM
  #1316
houston's Avatar
Its not so much that the bearing leaks as it sucks in dirt , not so good
Trust me I wish the bearing was not used
houston is offline
Old 07-26-2011 | 04:06 PM
  #1317
Do you have to worry about that same front bearing issue in the FMS?
nick64merc is offline
Old 07-26-2011 | 04:13 PM
  #1318
So to be save just change them eventhough there is no sign its gone bad?Thanks
Old 07-26-2011 | 05:44 PM
  #1319
tobamiester's Avatar
Hey guys, got a question.
I run an FMS in my 1/8 Late Model. Its just mental fast, sounds crazy, love it. (Brought it from a seller on here and have no complaints at all.)
One thing I notice is if it idles, it seems to load up, and when i get on the gas it will splutter and stall if I don't get on the gas pretty hard to clear it out. Doesn't take alot of time to load up either.
This past weekend, I ran maybe 7-8 warm up laps (after pre-heating the motor with a comp heater in the pits). Pulled over to be top'd up;
Pit guy was holding it up, and I was revving it to not load it up, and when the race started, I squeezed harder on the gas and it "popped" and flamed out. Any ideas why this happened and if could be avoided in the future ?
Thanks in advance.
tobamiester is offline
Old 07-26-2011 | 06:08 PM
  #1320
Thanks in advance.
Its probably too rich on the low speed needle causing it to foul the plug.Try leaning it until it only loads up a little.After getting the low speed where it needs to be you may have to richen the top a little.
xxxntwv is offline
