Like Tree352Likes
NOVAROSSI Engine thread....
Old 02-07-2017 | 11:03 AM
  #9376
Ran fine for the first 2 gallons then went to shit real fast. Everyone around here got rid of them before the 4 gallon mark.
rotor head33 is offline
Old 02-07-2017 | 01:40 PM
  #9377
Have never seen a Nova Rossi go bad that soon in 20 years.
Chris Reilly is offline
Old 02-07-2017 | 03:46 PM
  #9378
MugenDrew's Avatar
What fuel were you using? Would you happen to know what fuel the others were using?
MugenDrew is offline
Old 02-07-2017 | 04:31 PM
  #9379
i was running byrons 30/11 one other guy was running the same thing and 2 others were running nitro pro. last guy was running flashpoint.
it was awesome when it was running strong though thats for sure.
Old 02-07-2017 | 04:39 PM
  #9380
mourinho's Avatar
out of curiosity, how where these motors broke-in?
regular fuel or break-in fuel?
mourinho is offline
Old 02-07-2017 | 05:12 PM
  #9381
i cant speak for them but i know in my 14 years i have only used breakin fuel once. and it was on the very last motor i broke in. wont do it ever again either. never had any issues in all my years so dont intend to start using it.
one guy used a hudy bench. i did the EXACT method on the the page that comes with the motor, 2 on nitro pro heat cycled for 4 tanks then ran rich for 4 tanks if i remember correctly, last guy who was also on byrons did his own personal breakin.
mine just lost any and all compression and needed a repinch at 3 gallons and by 4 (without getting one) i was chasing the tune all over trying to keep it but it didnt happen.
two had rear bearing failures the others just lost their gusto around the 4 gallon mark. iv never had one go that fast...
Old 02-07-2017 | 05:25 PM
  #9382
BigInJapan's Avatar
Yeah used break in fuel on a Mito 4 and a Roma .25
The Mito went great for about 4 to 5 gallons, but has massive crank pin/rod bushing wear which caused the rod to crack, this happened right about the time it started to not hold a tune. I discovered that right on about 3 laps it would heat soak and then lose all compression.
The Roma went bad after 3 maybe 4 gallons. Same story cant hold a tune and loses power/compression when hot. I would only use break in fuel for an emergency /big event type situation
BigInJapan is offline
Old 02-07-2017 | 06:00 PM
  #9383
patrick lsp's Avatar
Would a mito 4 be good in a truggy? 9901 pipe?
patrick lsp is offline
Old 02-07-2017 | 06:20 PM
  #9384
HaulinBass's Avatar
I would think it would be a little too corked up stock, its soft on bottom and doesnt really scream until its modified.
HaulinBass is offline
Old 02-07-2017 | 08:24 PM
  #9385
Cant drive's Avatar
Mito 4 is more of a buggy engine. The 7 port will do better in truggy. Mito 7 with 9901/41001 would be a leathal combo
Cant drive is offline
Old 02-07-2017 | 09:07 PM
  #9386
BigInJapan's Avatar
I ran the Mito 4 in an ST-RR which is one of the heavier trucks out there. With a 9901/41019 and 8mm venturi combo it was more than capable. The 7 with same combo would also do very well. But if you have the 4 already i would give it a go
Old 02-08-2017 | 04:41 AM
  #9387
MugenDrew's Avatar
I honestly expect to see 4 gallons out of a nova
The off road engines get a new air filter at the start of everyday of racin or testin&tunin. I always run the fuel out (byrons) and will add after ruin oil if it will not be used for a week.
When there is a large build up of carbon under the position dome (little end of rod side) and it eats a plug or won't idle she is done.
Scavenge the usable parts and throw the rest away.
On road I would maintain the engine. Replacing the rod and bearings quite frequently.
The off road engines it's a waste of money.
Run it till it blows,lol
Old 02-08-2017 | 06:33 AM
  #9388
keithw11's Avatar
are you talking a drake 5 port?
keithw11 is offline
Old 02-08-2017 | 07:15 AM
  #9389
keithw11's Avatar
whats a good nova motor for truggy
keithw11 is offline
Old 02-08-2017 | 07:33 AM
  #9390
Yep
