Like Tree352Likes
NOVAROSSI Engine thread....
Old 12-04-2015 | 05:17 PM
  #8521
Originally Posted by nick m
the silicon that is fitited inside the crank its an other story has nothing to do with the silicon oil like we are using for shocks .for iner use inside use its not good for the engine and its nit a temperature product also .for the silicon ruber at pipes in line and for gasket special product is parker silicon ,its protecting all kind off orings and gaskets to last 3 times more,but still we sould avoid in general that silicon oils are entering inside the combustion chamber,i hope you will not misunterstood my thouths
Got no idea what you are talking about.
wreckingball is offline
Old 12-04-2015 | 08:10 PM
  #8522
we where having a conversation about putting silicon oil on gaskets and i said in previous post that silicon oil its not good for loobrication at pipe gaskets because its not good to enter the engine ,its better to use sometimes after run oil if its necessary.
nick m is offline
Old 12-04-2015 | 08:38 PM
  #8523
Suspended
Your English is better than my Greek, however your posts are a little hard to follow.
Socket is offline
Old 12-04-2015 | 09:09 PM
  #8524
sorry for the complicated posts .After all its full fun hobby and we have to suport and help each other
nick m is offline
Old 12-05-2015 | 01:21 AM
  #8525
You are taking my answer out of context.
I did not say that silicone oil and silicone sealant was the same, I was answering one who did compare them.
NitroVein is offline
Old 12-07-2015 | 09:01 AM
  #8526
Guys, speedlinehobby.com have 15% OFF on all Novarossi products plus the coupon code. Great saving.....
IVAN RM is offline
Old 12-07-2015 | 09:28 AM
  #8527
No Rex 25 in stock.. Who's got the best deal on an Elite 8 or blue Paloma at the mo?
Herrsavage is offline
Old 12-07-2015 | 02:02 PM
  #8528
Novarossi direct has the Rex .25 after 15% coupon is 152.00 minus shipping ! Insane deal ! Might have to pick one up myself
travertini is offline
Old 12-07-2015 | 02:14 PM
  #8529
What's the coupon?..
Old 12-07-2015 | 02:31 PM
  #8530
15off
Old 12-07-2015 | 03:15 PM
  #8531
Suspended
Good god. Novarossi direct went to $105 for the Elite 5.
Socket is offline
Old 12-07-2015 | 06:03 PM
  #8532
jeromerc's Avatar
shows 124
jeromerc is offline
Old 12-07-2015 | 06:42 PM
  #8533
bash bros's Avatar
Originally Posted by jeromerc
shows 124
15% off = $105
bash bros is offline
Old 12-07-2015 | 08:13 PM
  #8534
Default 41032 manifold
hey can anyone tell me the difference between the nova 41019 and the new 41032 manifolds.to me the look the same in pictures.reason i ask is i have a modified reds r5r and it makes its most power with a 9886/41032 and all i have is the 9886/41019 at the moment.what if any gains can i expect from the 41032 manifold.or should i just stick to the 41019 manifold.thanks for your help
Mfavor is offline
Old 12-07-2015 | 08:25 PM
  #8535
Maximo's Avatar
41032 is conical.... meaning its shaped like a big cone...narrower at the engine and wider at the pipe inlet.... the 41019 is smooth and has the same diameter across the length....
Maximo is offline
