Like Tree352Likes
NOVAROSSI Engine thread....
Old 08-03-2014 | 08:18 PM
  #6976
Just wanted to give an update, the hotter plug did the trick, I was even able to richen up the low end a bit. Another question though... How long should a tank of fuel last with these rich break in setting doing about 50% throttle runs of about 40-50 feet with idling in between to keep temps in the 200-220 range?
rjkotzur is offline
Old 08-03-2014 | 09:09 PM
  #6977
HomicidalBunny's Avatar
From what I experienced in my first break-in, during the latter stages, each tank seemed to last anywhere between 5-10 minutes, depending on how long each "run" is.
HomicidalBunny is offline
Old 08-04-2014 | 06:22 AM
  #6978
jpz_67's Avatar
Can anyone confirm how many head shims or what the factory clearance should be on a stock Btta should be?
jpz_67 is offline
Old 08-04-2014 | 07:10 AM
  #6979
beidle99's Avatar
should be 2 - at .3 and 1 at .2 to give a total of .8
beidle99 is offline
Old 08-04-2014 | 09:39 AM
  #6980
jpz_67's Avatar
Thank you my friend.
jpz_67 is offline
Old 08-04-2014 | 02:22 PM
  #6981
I Wheelie A LOT's Avatar
What kind of glow plug would you guys recommend for me to run on a P5 XLT? I'm running 30% VP Pro fuel, and also live in CA where the weather is blazing hot. Thanks
Edit : anyone know the factory settings for this engine? Sorry if its been asked before
I Wheelie A LOT is offline
Old 08-04-2014 | 05:48 PM
  #6982
Jerm13's Avatar
Just got off the NR site and they have all the stock settings for just about every motor they made. Check there.
On to my question....
I have a chance to buy a BNIB PLUS.21-4BTTS for a great price, but I have absolutly no experiance with NR and cant find any write up about the this engine. Need to know about power curve, use in a buggy or truggy, what pipes and is it even for off road?
Thinking of getting onboard with these motors, as I see great results from the top pro to our local guys.
Jerm13 is offline
Old 08-04-2014 | 05:59 PM
  #6983
It is a great engine. Adam Drake runs 9901SS/41021.
Chris Reilly is offline
Old 08-05-2014 | 03:40 AM
  #6984
beidle99's Avatar
I like the 41021 and 2096 pipe combo on the plus 4 engines or a werks 2058 pipe/header if you have that. The plus 4 is a great buggy engine, very smooth and good top end and great runt time.
beidle99 is offline
Old 08-05-2014 | 03:41 AM
  #6985
beidle99's Avatar
I like the 41021 and 2096 pipe combo on the plus 4 engines or a werks 2058 pipe/header if you have that. The plus 4 is a great buggy engine, very smooth and good top end and great run time.
beidle99 is offline
Old 08-09-2014 | 06:09 PM
  #6986
Lille-bror's Avatar
What pipe is this on Teemu Leinos HB / Keep Off 21 4?
Lille-bror is offline
  #6987
Lille-bror's Avatar
Old 08-09-2014 | 07:59 PM
  #6988
I think its a O.S. pipe maybe a 2090
evolution03 is offline
Old 08-10-2014 | 06:31 PM
  #6989
aussies1129's Avatar
Try O'Donnell 97t or 99t factory setting hs 3.5 out ls 5 out or best to just go both out slightly 1/2 turn from flush
aussies1129 is offline
Old 08-11-2014 | 05:08 AM
  #6990
Lille-bror's Avatar
Remember 0,8 mm is for break-in and 30% nitro. Go down to 0,7 mm if you run 25% nitro.
