Like Tree352Likes
NOVAROSSI Engine thread....
Old 05-28-2014 | 02:11 PM
  #6781
Fatal1ty......Nice user name
RockStar_199 is offline
Old 06-04-2014 | 05:54 AM
  #6782
sn47som1's Avatar
What will be an optimal temp for a modded Keep Off 7 ripping hard? about 260F? I heard the newer heads read quite a bit hotter.
sn47som1 is offline
Old 06-04-2014 | 06:54 AM
  #6783
I don't know about that, but from memory Novarossi state on their information that you should be looking to run at ambient temp + 90 degrees celsius, which 90C is around 200F. So you're looking at ambient temp +200F.
Eivind E is offline
Old 06-04-2014 | 09:08 AM
  #6784
SEF's Avatar
SEF
Not sure how much difference in temp modded makes, but my keep off runs great with good smoke, good power, and a great sounding engine, and when I happen to temp it, the engine is anywhere from 255-265F.
SEF is offline
Old 06-04-2014 | 10:49 AM
  #6785
Houston!
http://www.redrc.net/2014/06/rex-on-...ntent=FaceBook
What I see there it says the Plus5 has a 14.5mm crankshaft.
I asked a guy "in the know" and he said that this would be 15033.
What would that do to a P5 when it comes to performance?
Eivind E is offline
Old 06-04-2014 | 10:58 AM
  #6786
It't 85067; http://www.novarossi.it/2012/images/...-PALOMA-21.pdf
Actually just noticed that NR has the same exploded view for both "R-Plus 5" and "Paloma"...
But the Paloma and the first Toro Nero shares most parts; http://www.novarossi.it/2012/images/...ORONERO-21.pdf
Are they getting rid of parts..?
NitroVein is offline
Old 06-04-2014 | 01:15 PM
  #6787
houston's Avatar
The engines are built by novarossi , great quality
Im sure the engines are good runners
houston is offline
Old 06-04-2014 | 02:51 PM
  #6788
scrapsz's Avatar
Houston!
That crankshaft will not fit the P5. The P5x/P5XLT/P5Clio has 14mm crank using 14x25.8mm main bearing in the crankcase. The 14.5mm crank listed above requires 14.5x26mm main bearing in the crankcase.
scrapsz is offline
Old 06-04-2014 | 03:04 PM
  #6789
Yes. And why would Novarossi have any problem machining the case 0.2mm more to accept a 26mm bearing? I'm not sure I follow your logic.
The webpage clearly states that it uses a 14.5mm crankshaft. My source says it's one numbered 15033.
Eivind E is offline
Old 06-04-2014 | 03:19 PM
  #6790
kgombe's Avatar
they would also have to machine they inner part of the block to take a 14.5 mm crankshaft...
kgombe is offline
Old 06-04-2014 | 03:22 PM
  #6791
they've already done that for the Top Plus5 which was recently sold in the US..
http://www.serpentamerica.com/shop/p...cat=132&page=1
Eivind E is offline
Old 06-04-2014 | 03:51 PM
  #6792
kgombe's Avatar
ok
kgombe is offline
Old 06-04-2014 | 04:08 PM
  #6793
Default Novarossi Roma.25 Tuning and Heating Question
I have a Losi 8 T 3.0 with a Novarossi Roma .25 trugy engine. The engine has an 8mm Venturi, 9886/41001 nova pipe and short manifold combo. I also have 4 aluminum clutch shoes with stiff springs.
I have about 1 1/4 gallon of fuel through the motor and cant get a good tune. It keeps running hot - 260 - 290. Also I cant get a nice clean sound on the straightaway, it sounds rich or fat, but If I lean it out the engine runs too hot.
Is it normal for the roma to run hot? Do I need to break it in more?
Is there a chance that I have the wrong pipe/manifold pipe combo? The combo I have I pulled off this forum, but when I look on NR website neither option is recommended for this motor?
Any recommendations or info on your experience with roma's will be a huge help
chrisjwhitney is offline
Old 06-04-2014 | 04:10 PM
  #6794
kgombe's Avatar
drop a 7mm in that thing maybe try a 9901 pipe.. .but i think the 7mm will help you out
kgombe is offline
Old 06-04-2014 | 04:58 PM
  #6795
buchanan88's Avatar
Just wondering what the runtime comparison between the keepoff 21-4s and the 21-4 world champion would be? Has anyone ran both?
buchanan88 is offline
