Like Tree352Likes
NOVAROSSI Engine thread....
Old 02-15-2010 | 12:18 PM
  #391
houston's Avatar
Originally Posted by the_winner
thanks for the infos but the 03003 is .20mm shim... My plus 4 have 3 shims 2 silver and one brass you said me to change the one brass with a 0.15?You know the part no?03002?
thanks
http://www.novarossiusa.com/product_...roducts_id=193
sorry 03002
my mistake winner
you should have two .30mm aluminum and one .20mm copper shim in there
houston is offline
Old 02-17-2010 | 02:57 PM
  #392
Hey Houston I just picked up a p5 a friend of mine let me have it has about 2 gallons now on it and it works great! it has a jp2 pipe with a nova 6 plug and to my surprize it was a standard plug. I want to no if this pipe is decent enough to run or if I should go another way? Also do I need to buy a 9$ nova plug or will my odonnell plug work as well? As I said it was free it had about half gallon on it when I got it and the drake the kind enough to tune it for me last week and ever since iv put 2 gallons on it and it runs great but I think the plugs gonna go soon so b4 it does I wanna no if od plugs r good.
Matt Piva is offline
Old 02-17-2010 | 03:03 PM
  #393
9853/41021 header for truck or serious power in buggy
9901/41021 header for buggy for linear smooth awesome power
the odonells plugs are on th espot for these motors
99cold
97med-cold
77hot
100 in standard hotter
zixxer is offline
Old 02-17-2010 | 04:37 PM
  #394
Are the Nova plugs as really a problem? I just bought 6 c5t's and am worried about using them cause of all the bad hype I've read about them.
Miniracer23 is offline
Old 02-17-2010 | 05:33 PM
  #395
i personally had a problem with my nova plug that came in my p5xlt ..not saying all nova plugs are bad ..i just prefer to use odonells plugs ..they work great last long and cost much less ..next time you re-up give em a try
zixxer is offline
Old 02-17-2010 | 07:52 PM
  #396
r1harper's Avatar
it took me a while to admit it but the O'Donnell plugs are the shiznit....97 and 97t...is what is in my box...they tune very well and last a long time
r1harper is offline
Old 02-17-2010 | 07:53 PM
  #397
r1harper's Avatar
is this the same zixxer that went to work for some nascar crew
r1harper is offline
Old 02-17-2010 | 07:55 PM
  #398
do what you so crazy ..must be the water over there
zixxer is offline
Old 02-17-2010 | 08:16 PM
  #399
r1harper's Avatar
shit son it was one of you pimps from bama...met him at flowood i think last year..anyway rock on..LOL
r1harper is offline
Old 02-17-2010 | 08:31 PM
  #400
Nope no nascar here. Lol but yeh I was at flowwod. It was Great.
zixxer is offline
Old 02-17-2010 | 11:42 PM
  #401
mblgjr's Avatar
Zixxer drives like he's in Nascar.
Better watch out when he gets up on the wheel
mblgjr is offline
Old 02-18-2010 | 11:22 AM
  #402
Default 9901 vs 9853
Tell me the difference in them on a +4?
Last time out I felt my car was struggling with mid to top speed with a 9901. Please share you're views as most of the tracks i run has long straight/sweeping corners and very little jumps.
or recommend other pipes..
Sleepstream is offline
Old 02-18-2010 | 11:32 AM
  #403
Torian4000's Avatar
+1... I didn't have good luck with Novarossi plugs on my P5XS so I started using odonnell plugs and they work great. They last long and give good performance.
Torian4000 is offline
Old 02-18-2010 | 08:26 PM
  #404
pickle311's Avatar
What's the difference between the P5XS and the P5XLT?
pickle311 is offline
Old 02-19-2010 | 01:24 AM
  #405
Default Need help
I wonder what was wrong with my +4 motor
Well I don't know how to explain this but it like full tank lean bog problem.
but it flamed which is very bad for racing when you flamed after every pit stop.
It just happen lately. Right now I have to richen my lsn almost 3/4 of a turn to compensate which is really bad for milleage from 10 min drop to 7:30
I use OD 97T plug 25% nitro
80 degree air temp with 80+% humidity sea level
lsn is quarter of a turn out from flush (as rich as possible set without flooding the motor)
hsn is almost flush
my motor temp around 220-230 when tank empty.
cargo is offline
