Like Tree352Likes
NOVAROSSI Engine thread....
Old 02-13-2010 | 09:20 AM
  #376
houston's Avatar
Originally Posted by mbx5rcr34
please i need help here ,its my friends nova p5s i think, i heard its a old motor ?? anyway whats the base or factory setting .........or race tune if possible ,currently hes using 20% & its for hes 6T truggy, thks
3.75 turns high and low will get you close , adjust idle accordingly and pull slide barrel out when setting the low
houston is offline
Old 02-13-2010 | 09:47 AM
  #377
badjams's Avatar
Originally Posted by houston
just remember you actually have to tune a novarossi engine , OS engines will run no matter what you do to the carb
i see it quite frequently , racers who switch from OS engines try nova engines and they give up because they try to tune (or not tune) them like an OS , doesnt work
read the tuning guide or read up on a few posts .
+1 on that , big difference from tuning my plus 4 to my jx ninja!!
badjams is offline
Old 02-13-2010 | 01:33 PM
  #378
Originally Posted by bigguyrc8
No thanks i can handle it.
So can most, but Monty has probably forgotten more about these novarossi engines than I will ever learn. His R2R motors are the real deal...
WideOpenThrottle RC is offline
Old 02-13-2010 | 10:34 PM
  #379
mblgjr's Avatar
Originally Posted by r1harper
i know on my stock plus4 once i set the needles all i do is fine tune the HSN....and it is good
For 99% of the time on any give race day; I agree.
Once set, it's pretty rare I have to rock my LSN more than a blade width.
mblgjr is offline
Old 02-14-2010 | 12:00 AM
  #380
houston's Avatar
Try that at the nitro pit in october ! Will not get you through the race , hell your engine changes tune during the race , sucks!!
houston is offline
Old 02-14-2010 | 12:09 AM
  #381
houston's Avatar
Thanks Q
houston is offline
Old 02-14-2010 | 04:20 AM
  #382
Hi guys i run my novarossi plus4 engine with Byron Gen2 2500 fuel i need to change the shimming ?The manual and at the novarossi site said to run 25%...
I need to remove shim?
the_winner is offline
Old 02-14-2010 | 08:45 AM
  #383
houston's Avatar
Ideally you should replace the .20mm copper shim with a .15mm brass shim part# 03003 I believe but it will not hurt a thing running it like it is . 30% is the way IMO
houston is offline
Old 02-14-2010 | 02:41 PM
  #384
Hey Monty
What are some of the advantages of runnig 30% nitro over the lower percentage fuels ie; 20% or 25%. I know you get more power from 30%, but
alot of the on-road guys are now runnig the lower percentage fuel, is it more mileage? I talked to a famous engine tuner/modder awhile ago and he said
he uses the lower percentage fuels. I plan to move from 25% nitro to 30% and was just curious.
topcat-lll is offline
Old 02-14-2010 | 02:46 PM
  #385
houston's Avatar
Originally Posted by topcat-lll
Hey Monty
i prefer the performance of the 30% over lower nitro , thats the advantage , some have been running 35 and 40%
lower nitro fuels will be easier on your engine for sure provided its a good quality fuel with proper lubrication and you properly maintain all components that go with your engine . the onroad guys are probably switching so they dont have to maintain there engines every other run with new rods and bearings , i want to run 8th scale onroad but wouldnt wanna pay for it
houston is offline
Old 02-14-2010 | 03:51 PM
  #386
streetfreek's Avatar
Default houston.....help...!!!!!!
on the .12 rossi I got in my crt.5....I got the mid flush like you said...and reset the lsn at 2.5 turns out and still cant stop the huge hesitation when you punch it......am I wrong on 2.5 out on the lsn....???
streetfreek is offline
Old 02-14-2010 | 03:59 PM
  #387
houston's Avatar
i really couldnt tell ya exact needle settings on the .12 engines but i believe its around 1.5 but dont quote me on that .
houston is offline
Old 02-14-2010 | 06:05 PM
  #388
Smile
The tires are the killers in 1/8 scale Nitro on-road, one 20 minute main
and they are through ($50+). The sound and speeds are out of this world, plus you need good reflexes.
Old 02-15-2010 | 12:01 PM
  #389
thanks for the infos but the 03003 is .20mm shim... My plus 4 have 3 shims 2 silver and one brass you said me to change the one brass with a 0.15?You know the part no?03002?
thanks
Old 02-15-2010 | 12:16 PM
  #390
houston's Avatar
i have raced 8th onroad and was actually driving with guys that you see in the spotlight , not too far behind
i love the sh!t !!! very addicting and i wish i could afford to do that . i would not want to have to support the engine bill though
houston is offline
