Like Tree352Likes
NOVAROSSI Engine thread....
Old 03-26-2012 | 09:53 AM
  #2386
I recently switched from the RC8.2 standard clutch to a Werks (Heavy) clutch system. Would this affect my tune much? The car ran fine but seemed to idle a bit irregular (faster). Almost sounded a bit lean. This is on a Plus 21-4.
Eastside777 is offline
Old 03-26-2012 | 04:07 PM
  #2387
houston's Avatar
i dont know anyone who uses the heavy flywheel from werks or any other manufacturer for that matter
i would recommend getting at the heaviest the medium weight flywheel
the heavy flywheel will make your engine feel as if it is doing some weird sheeit
houston is offline
Old 03-26-2012 | 05:52 PM
  #2388
Thanks, like I said the car ran fine just idled a bit weird.
Old 03-26-2012 | 09:10 PM
  #2389
houston's Avatar
the weight of the flywheel is probably keeping the engine rotating even after it wants to come down to idle after the fuel has been spent out of the crankcase
houston is offline
Old 03-27-2012 | 03:47 AM
  #2390
Makes sense. I figured it was something like that so i didn't want to start twisting needles for nothing. I need to geet my hands on a medium flywheel as I like the feel but the idle is bothering me.
Old 03-27-2012 | 12:33 PM
  #2391
I spoke to the people at Werks and have been told that the Heavy clutch should actually cause the engine too idle better. So now I'm a bit confused. One person saying it's no good and the other saying it should be better.
Old 03-27-2012 | 01:49 PM
  #2392
houston's Avatar
i think you are misunderstanding what i am sayin , the heavy flywheel will keep the engine idling through rotation of mass and in turn will allow you to lower the idling of the engine . i was trying to tell you that the heavy weight of the flywheel will keep momentum for a longer duration and force the engine to rotate after the fuel in the crankcase is spent , hope that is clear , sorry for any confusion
houston is offline
Old 03-27-2012 | 02:28 PM
  #2393
What you told me was what I was thinking but the Werks tech said it should idle better that's what's confusing.
Old 03-29-2012 | 07:27 PM
  #2394
Seattlelife22's Avatar
I can tell you who is excited about the Roma .25 truggy engine!!!
This guy!!!
Seattlelife22 is offline
Old 03-29-2012 | 07:37 PM
  #2395
houston's Avatar
This guy!!!
Soon so i am told
houston is offline
Old 03-29-2012 | 08:45 PM
  #2396
This guy!!!
Already pre-ordered mine from Monty.
colby233 is offline
Old 03-30-2012 | 01:35 AM
  #2397
houston's Avatar
kinda
houston is offline
Old 03-31-2012 | 05:30 AM
  #2398
Diff Balls's Avatar
Hey guys, I need some input.....I am having a bit of problems with the idle on a 21-4BTT. It only has a gallon, maybe a bit less on it. The idle is rich and when I lean it out, it goes from rich to pinging. I can't get it just right. I have a 21-4C Team, and I can get it perfect.
I have replaced the glow plug and went that route....I don't think that is the issue.
Any ideas? Do i just need to run it rich and let it break in more maybe?
Diff Balls is offline
Old 03-31-2012 | 06:17 AM
  #2399
FUSIONX AUS/NZ's Avatar
Are you dropping the idle gap when you lean it out? Sounds to me like its too big
Dave
FUSIONX AUS/NZ is offline
Old 03-31-2012 | 08:02 AM
  #2400
psr's Avatar
psr
hey guys i dont have a issue but a questern i have two btta motors one i brought a few months ago and one i broughts this week for a big race they are both identical part numbers but the older one has a nova branded bearing and the other has some random bearing the one that can be view from out side the engine
is this normal alos could this be a fix for the dodgy nova bearing issue ?
psr is offline
