NOVAROSSI Engine thread....
#2536
nice to see a quick response!
Engine has about 1 1/2 gallons through it. ton of pinch on it.
i had 3 flame outs... all after jumps.
I changed the line, bearings and even the plug, fuel tank, gaskets and the car was very free. Here are my current needle setting...
4 turns out on LSN
1/2 in from flush on HSN.
Keep ideas flowing...
4 turns out on LSN
#2537
How about the pipe? I read on the clockwork thread about someone that changed motors, clutches, fuel lines, tanks, etc. Only to find out that at about the 3 min mark, the gumed up oil inside the pipe was heating up and closing down the pressure outlet. not allowing the tank to pressurize and the motor to run lean and flame out. Just a thought.
Maybe time for some crock pot antifreeze boiling.
#2539
Mugen MBX6r with BCE X3 chasis ( short rear brace installed. Spur Gear meshing is pretty good so there is room for chasis flex. Maybe I'm landing on the flywheel? That would be pretty unlucky to do this 3 times in 1 day though. it is possible.... I'll look into that.
What about tuning... At what temps should I perform the tuning? 200? My engines usually run about 235-250 but I tune at 190ish. Would it make ha much of a difference?
#2545
#2548
What's the best way to temp the Nova? what is max temp from the top of the cooling head? Can you offer any advice on this? When things started to really feel and sound good I temped the motor at 260. I richened it to be safe but then started having some issues. Thoughts?
#2549
#2550
drivers run their novas with the new LOWWWWWWWWWWWWWWWW head upwards of 270°=290°
352Likes
