Like Tree352Likes
NOVAROSSI Engine thread....
Old 03-15-2012 | 05:59 PM
  #2326
Wenbiao's Avatar
Originally Posted by beidle99
since it seems your 140 to 150 is celcius, you are way to hot and probably lean bogging comming off the bottom end. Sounds like the needles are way out of balance. I would go back to factory and then retune. What pipe and header are you using? How is the clutch? Tank have a air leak below half tank? How are the fuel and pressure lines? Any filters or coolers in place?
Yes you should replace the head button if you want to use a nova or OD plug.
Originally Posted by houston
You didnt post that it was celcius excuse me
Yes on the head button
Thanks all
Last question
We have problem to restart a Nero after the engine stalls and this happen a few laps on the track.
After cooling down it starts without difficulties.
Some told us was the overheating of the carb
True ?
Some even water nitro and apply compressed air on the carb, and this works
What caused the carb overheat ? And how do we solve.
Wenbiao is offline
Old 03-15-2012 | 09:49 PM
  #2327
Pipe question for the Bonito...between a 9901 and a 2096, what pipe does what? Which will rev out more with this motor?
kaotickc is offline
Old 03-15-2012 | 10:54 PM
  #2328
Lille-bror's Avatar
Originally Posted by Wenbiao
Thanks all
Last question
True ?
Hi.
The experts from Novarossi suggested the Danish Team Drivers at the Euro '11 not to run their BTT engines hotter than 115º C with an ambient temp of 20º C. Of course that engine temp is relative. But that should be a nice starting point for you when you set the HSN and you are close to the right setting af the LSN.
Lille-bror is offline
Old 03-16-2012 | 06:52 AM
  #2329
Well guys, I blew up my first motor last night. I had a three year old PTM Toro Nero, motor probably had 10-12 gallons on it though. Still had a ton of pinch/compression when I took it apart after blowing it up. The brass bushing that is inside the connecting rod where it attaches to the crank basically disintegrated. It was a great motor, my first real "race" engine. Anyhoo, I guess its time to buy a new engine. Has anyone run the maxpower thunder (5 port w/ boosters)? This motor will go in my MBX-6T. I also have a HotMod .821 nova that I absolutely love in my other Mugen. Is there a motor that is comparable to this? Any opinions are appreciated guys, just let me know.
Thanks, Mike
mikal is offline
Old 03-16-2012 | 07:22 AM
  #2330
t8rtot's Avatar
Thanks, Mike
i've seen the 8pt Max Power engine (absolute hobbyz) and it is an ANIMAL in a truggy. it'll rev to the moon too.
t8rtot is offline
Old 03-16-2012 | 07:42 AM
  #2331
My racing buddy has that exact motor (maxpower 8 port), and it is a screamer. I am trying to be a little different though and that is why I was asking about the 5 port w/ boosters.
Thanks, Mike
mikal is offline
Old 03-16-2012 | 08:02 AM
  #2332
Maximo's Avatar
Thanks, Mike
My Clocked Bonito would probably be faster and more powerful !
Maximo is offline
Old 03-16-2012 | 09:05 AM
  #2333
Neil, you've got me thinking. Just went to your website (very nice by the way) and I saw that you recommend Werks or Nova plugs. I have always run the O'Donnel 97T's in my Novas, would this plug not work? Also, what is the usual turn around time between ordering (most likely 2-3 weeks) and when I actually get the motor. I am on the east coast (DC metro area) and I know that customs can be a pain, but what is the usual transit time.
Thanks, Mike
mikal is offline
Old 03-16-2012 | 09:10 AM
  #2334
Default Novarossi BONITO.21
I am looking for a Novarossi Bonito .21 used but in good condition. Let me know if you have one. I know it is a shot in the dark.
Thanks, Nick
nwjones76 is offline
Old 03-16-2012 | 09:25 AM
  #2335
J.Sears's Avatar
Thanks, Mike
I'm not neal but it only takes 1 to 2 days to get your motor. I live in Ky. And I got mine in 2 days. They use DHL next day shipping. Can't beat that. The customer service is outstanding too.
J.Sears is offline
Old 03-16-2012 | 10:28 AM
  #2336
PERROTTO's Avatar
Thanks, Mike
This happened to me after gallons and gallons of use on my plus4c...I was actually able to replace the rod and clean out the mill and no scratches on piston or sleeve. Ran fine after new new rod and cleaning. This may b an option for you
PERROTTO is offline
Old 03-16-2012 | 11:21 AM
  #2337
smittyusmc's Avatar
Hey guys I was thinking of buying the P5 what plugs do they come with and could I use the OS plugs in it because I can get them alot easiers thanks.
smittyusmc is offline
Old 03-16-2012 | 11:40 AM
  #2338
Maximo's Avatar
Thanks, Mike
order today and I will have the engine there on Tuesday !
OD plugs are too fragile for a engine like this tho..... they are too hot and the coil is too thin.......on a stock engine with average RPM capabilities a OD 97 works fine, but on one of my screamers the OD plug will not last more then a tank or two
Maximo is offline
Old 03-16-2012 | 03:26 PM
  #2339
bigjayjay1's Avatar
Thanks, Mike
Try the bonito CRE OMG best motor ive used starting breaking in my P5's these feel awesome also hard to tell the difference thou since the P5 is still very tight. My bonitos started to drop its balls OMG what a motor Neil is the man for sure he did his homework for sure.
bigjayjay1 is offline
Old 03-16-2012 | 07:06 PM
  #2340
bigjayjay1's Avatar
BTT what other cases fit the piston and sleeve will work in a bonito or P5 case
