Like Tree352Likes
NOVAROSSI Engine thread....
Old 10-22-2011 | 12:08 PM
  #1621
megasaxon's Avatar
Originally Posted by NitroXray80809
What life span are you guys gettin out of the older plus 4 buggy team ceramic edition mill? As far as gallons and racing hard not running rich... Nor lean...
i have no doubt that over 6gal should be easily attainable. I've seen some racers get 10+ out of an engine. I'm a relatively new Novarossi owner, so i havent gotten enough race time on my engines to tell you my personal experiences, however my brother got 5 gallons on his N21BF before he replaced the front bearing. Even the 'cheap' N21 rod and crank were in great condition and still well within spec.
megasaxon is offline
Old 10-22-2011 | 02:34 PM
  #1622
Maximo's Avatar
A little modified P5XLT action.....Engine is very strong, especially considering it is nowhere near dropping its nuts.....
+ YouTube Video
Maximo is offline
Old 10-22-2011 | 03:04 PM
  #1623
PERROTTO's Avatar
Got 10 gallons out of mine before the rod went. After replacing the rod it went another 2 gallons before the wrist pin pulled itself out of the cast piston. I was really beating the piss out of it those last 2 gallons though. Ran very consistent throughout the 12 gallons as well.
PERROTTO is offline
Old 10-22-2011 | 04:02 PM
  #1624
megasaxon's Avatar
Neal, what's your aproach when modding engines? just to get the absolute most power possible?
Old 10-22-2011 | 04:11 PM
  #1625
Maximo's Avatar
every engine is different.... I determine an engines strengths and weaknesses, then I modify them to correct the weaknesses without hurting any of the strengths.... The P5XLT for example was modified to have a broader RPM range and better mileage without sacrificing any of the bottom end..... The engine did gain power across the board and has substantially more useable RPM over stock....But as I say every engine is different... some I modify to increase bottom end like the Bonito...
Maximo is offline
Old 10-23-2011 | 12:17 AM
  #1626
NitroXray80809's Avatar
Sound's great to me, thanks.
Also how are the P5XL (Turbo Plug) engines? I just seen they are pretty cheap and have great reviews.. But i see they advise 25% fuel, what do you think 30% will do and how long do these last?
NitroXray80809 is offline
Old 10-23-2011 | 01:19 AM
  #1627
Lille-bror's Avatar
Novarossi engines are the best!!! No other brands can beat them in both durability, power, value for the money, materials, tuneability and runtime... and close to no other brands can beat them in just one category!!!!
Lille-bror is offline
Old 10-23-2011 | 01:58 AM
  #1628
merdith6's Avatar
Default Yep
So true...also the least leaky of all the engines....I see so many other brand engines with oil seeping out of weird places.....
My p5's last about 6 hard race gallons although they still run...I can pinch them and put a new rod and get more....Bearings are fine...but mine need new rods at 6 gallons no question...
merdith6 is offline
Old 10-23-2011 | 02:29 AM
  #1629
aussies1129's Avatar
a friend of mine is running the p5xlt in his xray truggy its modded by powerhouse and it has awesome power for the price its a winner for sure I have run all the +4, btt and toros and the p5xlt is outstanding.
I use to run 30% but went back to 25% as the extra power and not to mention wear on your engine wasnt worth it so am now running 25%
cheers
aussies1129 is offline
Old 10-23-2011 | 05:52 AM
  #1630
megasaxon's Avatar
the P5XLT is an AWESOME engine. My brother has one modded by PowerHouse in his RC8B, he let me borrow it one weekend to try in my RC8T, it was AWESOME in my truggy. 2 weeks later i had one of my own. Stock ones are great too, seen a few around and they haul the mail.
Novarossi recommends 25% for all of their engine. You can run 30% without any problem in them. Some like to shim the head more during breakin, but the stock .70mm should be just fine afterword
Old 10-23-2011 | 06:05 AM
  #1631
Lille-bror's Avatar
Don't all Novarossi engines comes with 2 alu (0,3 mm) and 1 cobber (0,2 mm) head shims? . After the break in you should run 0,7 mm if you are running 25% nitro.
... and a hotter plug after 2 or 3 gallons if you run 25% nitro
Old 10-23-2011 | 08:24 AM
  #1632
ABN Hoosier's Avatar
every Novarossi engine I have purchased came with a .pdf. Here's an example. The shims are .3 x2 & .2 totaling .8mm out of the box for the Bonito.
http://www.mashshop.com/home/downloa...ITO21-7XLB.pdf
ABN Hoosier is offline
Old 10-23-2011 | 08:48 AM
  #1633
Suspended
I had a regular P5 last right at 10 gallons with only a rod change years ago. Here lately I don't own any motor long enough to wear them out.
I have a nova plus 21-4C now that had 3 gallons on it and was resized and rod changed. Hoping to get at least 4-5 more gallons out of it.
MattP is offline
  #1634
megasaxon's Avatar
you're right, some like to drop down to the .70 after breakin, but not really necessary
Old 10-23-2011 | 10:19 AM
  #1635
P5XLT action...dropping its nuts.....
what a colorful and descriptive metaphor Mr. Smith
