Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 09-26-2015 | 09:44 AM
  #8686
jeromerc's Avatar
Monty can you try to get me another 2096 coated combo. He never replies back. Also want another truggy header. Gonna see if it livens up Binhs bonitto. The last two engines you did for me are sick. The x5r is running down the speeds like no other and that damn x7 is a rocket. Almost like a red dot nova lol. Also shoot me a link to next years races. Binh wants to go to one
jeromerc is offline
Old 09-27-2015 | 05:49 PM
  #8687
houston's Avatar
Originally Posted by Excalibur0428
Alright. If this is how you all represent yourselves, then I'll buy an engine elsewhere. Sorry for be unclear on which motor is truggy specific.
no , i didnt notice the truggy part , my fault
9853 41005 would be my suggestion
i dont get on rctech alot anymore , i probably should but there are alot of things going on
houston is offline
Old 09-28-2015 | 01:23 PM
  #8688
thanks houston. No worries I just read those two comments completely wrong and took them the wrong way.
Excalibur0428 is offline
Old 09-30-2015 | 11:20 AM
  #8689
tysonsk's Avatar
Quick question about engine tuning and the carb:
Is the carb the only thing that affects how an engine tunes or are there other factors that affect how an engine tunes? For example. If I put a werks carb on a p5, would the process of tuning it be very similar to tuning a werks b6 with a werks carb on it? If I wanted all engines to tune like a novarossi would all I have to do is put a novarossi carb on the select engine to make it tune like a novarossi?
tysonsk is offline
Old 09-30-2015 | 12:54 PM
  #8690
Suspended
Think of an engine like an air pump. Fuel is metered by the carb, and metered to control the ratio of fuel to air.
Socket is offline
Old 09-30-2015 | 01:00 PM
  #8691
beidle99's Avatar
I wouldnt put a werks carb on a Nova. IMHO Nova carbs (at least 2 needle ones) are easy to tune and I have never been a fan of swapping manufactures parts on engines. If the tolerances are just slightly different between brands you open yourself up to air leaks at the base of the carb.
beidle99 is offline
Old 09-30-2015 | 04:44 PM
  #8692
bash bros's Avatar
Aren't the Werks carbs also short needle lsn?
If you're thinking of swapping them because you find a short needle easier to tune, I'd suggest just sticking with the nova carb. Long needle carbs like the novas can be tricky to tune, but it's almost always from a lean hsn and rich lsn and too much idle gap.
bash bros is offline
Old 09-30-2015 | 06:26 PM
  #8693
tysonsk's Avatar
Thanks everyone for the responses. I'm not going to put a werks carb on a nova or vice versa. I was just using that as an example. I plan to put a spare werks carb I have on my LRP 28. So will the LRP tune like a werks with the new carb?
tysonsk is offline
Old 10-01-2015 | 02:41 AM
  #8694
LRP is an SH base engine, I don't think a Werks carb would fit. You should try a Losi 454 or a Dynamite carb. On the other hand you can put a Z.30 or Z.32 carb which is better but still has no insulation. The ZZ.21 has a wonderful carb but is expensive, same price tag as the LRP .28 whole engine .
danyvw is offline
Old 10-01-2015 | 06:02 AM
  #8695
Maximo's Avatar
Originally Posted by danyvw
LRP is an SH base engine, I don't think a Werks carb would fit. You should try a Losi 454 or a Dynamite carb. On the other hand you can put a Z.30 or Z.32 carb which is better but still has no insulation. The ZZ.21 has a wonderful carb but is expensive, same price tag as the Z.28 whole engine .
Picco or Reds carb will work nicely in a LRP 28 ! Or a slightly lathed down Nova carb
Maximo is offline
Old 10-11-2015 | 12:05 PM
  #8696
houston's Avatar
houston is offline
Old 10-11-2015 | 12:09 PM
  #8697
houston's Avatar
Carb is one very important part of how the engines tune n run but more importantly is metallurgy ,the expansion/contraction rates of the engine block are HUGE ,the material the pistons are made of r HUGE , so many things to consider
houston is offline
Old 11-03-2015 | 07:21 AM
  #8698
tysonsk's Avatar
What is happening in this video?
+ YouTube Video
Is the guy really taking a new engine and breaking it in like this?
tysonsk is offline
Old 11-03-2015 | 07:53 AM
  #8699
Suspended
I can't watch the video, but is that the method where they make it super rich, and then run it wide open?
See ya rod...
Socket is offline
Old 11-03-2015 | 08:05 AM
  #8700
tysonsk's Avatar
See ya rod...
Here's the link for you: https://www.youtube.com/watch?v=Ciwj2Nyz85U
I'm not sure what method they used, but they leaned the engine out and were revving it on the box.
tysonsk is offline
