Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 12-21-2014 | 06:06 PM
  #8506
HomicidalBunny's Avatar
Originally Posted by beidle99
for buggy, I love my X5 Race "FM" paired to a 41021/2096 combo and Buku clutch.
I have the exact same setup except for the Full-Monty part, I can say the stock X5 race certainly has balls, I can't imagine what a FM would feel like.
HomicidalBunny is offline
Old 12-22-2014 | 02:42 PM
  #8507
houston's Avatar
Xlnt buggy engine
X5 race 2096 41021
houston is offline
Old 12-23-2014 | 11:13 AM
  #8508
Jaz240's Avatar
are you coming to Arizona in February? I need help tuning my Pinch Bolt and my idle screw. Oh Yeah, you know that little set screw at the end of the pipe that holds it to the wire thingy?, Can you tune that for me also?
Jaz240 is offline
Old 12-23-2014 | 11:29 AM
  #8509
houston's Avatar
Oh boii ,here we go
You know i wont miss a DNC bro
houston is offline
Old 12-23-2014 | 03:25 PM
  #8510
Jaz240's Avatar
no seriously I'm panicking over here! There are 4 screws under the engine that seem to go through the chassis but when I tune them all it does is make my engine loose. I cant get anymore power out of those 4 screws no matter how lean I make them and if I richen them up the engine just slides around on the chassis!
Jaz240 is offline
Old 12-23-2014 | 04:35 PM
  #8511
Retired09's Avatar
James. Your supposed to leave 2 of them tight, diagonally across from each other and tune with the other 2. Only use those screws for mid range tuning thou. I'll help you out next time I see you at the track.
Merry Xmas
Retired09 is offline
Old 12-23-2014 | 04:42 PM
  #8512
Jaz240's Avatar
Merry Xmas
Thank you Bill! Merry Christmas to you also. Do you how to tune the pipe exhaust springs also? I was told the little springs tune top end and the big spring that goes around the entire engine tune the low end, of course this is only possible with a 7mm idle gap but I'm not sure what that means
Jaz240 is offline
Old 12-23-2014 | 07:14 PM
  #8513
Frank L's Avatar
Merry Xmas
3 needle carbs use the carb to do that.....
But tuning that pinch bolt can be very tricky. I leave it to he professionals.
Frank L is offline
Old 12-23-2014 | 10:45 PM
  #8514
houston's Avatar
Lightbulb
You guys are sooooo offbase , its alllll in the idle screw ,get it right , sheesh ,amateurs
houston is offline
Old 12-24-2014 | 01:54 AM
  #8515
you're confusing me, someone on here told me the idle screw only works if you've sealed the vacuum port
Eivind E is offline
Old 12-24-2014 | 04:12 AM
  #8516
kgombe's Avatar
Oh boy.... And who gave it the name vacuum port anyway... Lol..
I always tune my engine after I replace the muffler bearing, but I tune with the 4 bolts that hold the engine to the chassis
kgombe is offline
Old 12-24-2014 | 07:10 AM
  #8517
What is the benefit of the turbo muffler bearing? Which color powerband are you using and where/when? What color screwdriver do you use to the the idle?
Be careful tuning using the pinch bolt to tune your engine. It takes great skill.
Merry Christmas and Happy New Year !
Chris Reilly is offline
Old 12-24-2014 | 07:43 AM
  #8518
kgombe's Avatar
never used the Turbo muffler bearing... and i use yellow for everything..
Merry Christmas and have an awesome racing New Year
BRAAAAAAAAPPPPPPPPPPP!!!!!
kgombe is offline
Old 12-24-2014 | 08:24 AM
  #8519
houston's Avatar
Smile
HO HO HO MEEEEEERRRRRRY CHRISTMAS !!!
or happy quanzika or wtvr you celebrate guys
Heres to an awesome 2015!!
houston is offline
Old 12-24-2014 | 08:33 AM
  #8520
Happy Christmas and Merry New Year Monty!
Bottoms up!
3DRCRACER is offline
