Houstons Engine Service H.E.S.
#2986
any damage caused by the engine in your buggy i am not responsible for
jk , hope it lasts you a long time Donnie , let me know if you need anything bro
#2987
Monty
As i know you to be the engine guru that you are i got a question for you...
What is the best way to know when your Midrange needle is set where it should be on a three needle carb and can i tune the Mid needle after my LSN or before it?
Thanks for your help!!!
#2988
If needed to be reset , they are usually all exactly flush with outside body of carburetor .
Just fyi there is a reason that our offroad carbs are not made with a mid needle anymore
I have noticed on the vspecs that I have tuned for people that they like to have the mid needle adjusted in 2 hrs .
#2989
Thats what everyone local here has been telling me as far as dont fool with it much just leave it at factory spec!
Ill see what i can do with LSN and HSN to set the tune and if all else fails ill swap it for my friends 2 needle carb!!
Thanks again
Thanks again
#2991
Monty, that 2084 pipe was awesome on my p5 this weekend!
It had the power of a 9853 with the runtime of a 9901. I liked it with the 41005 header. I can't wait to try it on my other novas
Thanks, Mike
Thanks, Mike
#2993
Next time out I will try with a 41005 and see if there is any power difference in comparison to the 9853ss , I didn't notice any power difference if there was any
#2994
#2997
Those damn hex screws drives me crasy!
If you have the right flathead screwdriver, you will tighten and unscrew the head screw without any problem. Hex screws will become worn out after a shorter time.
Donīt you guys in use torx screws? They are so much better than hex.
#2998
As with anything you do mechanically , you should have the proper tools
Why they use flathead ,that is a query for novarossi
I would venture to guess it has to do with not applying too much torque and warping the engineblock
#3000
All I can do is hope the things I type get taken the right way
Anybody that actually knows me knows what I say and how I say it does not mean any ill feelings , disrespect or making people feel like a dumbass.
If anybody ever thinks I would do so intentionally , you have me way wrong
Happy motorin',
Monty
Happy motorin',
Monty
22Likes
Lots of fun when you learn how to tune one.
