Like Tree2Likes
RB Concept Engine Thread..
Old 05-04-2009 | 03:59 AM
  #346
buggydad's Avatar
Originally Posted by rallyebmx
What kind of run times are you starting to get with your USA? Buggy or truggy? I know its still new but......
About 7 min take it for what its worth the as she is not race tuned yet still spiting a little gas on bottom.Its supose to get more the regular c6 but ill see whenever it stops raining here.Rained for like a week allready
buggydad is offline
Old 05-12-2009 | 07:52 AM
  #347
vti-chris's Avatar
Anyone knows whether RB will open up the forum section?
Tried emailing them with no reply.
vti-chris is offline
Old 05-12-2009 | 09:08 AM
  #348
aaron joy's Avatar
Originally Posted by Big Daddy05
What is a good pipe for the RB WS7??
You might want to try a Dynamite 007 HT, I am running a modded S7 with
WS7 crank ( basically a WS7 ), Bryons RACE 25% Gen 2 and I am easily getting 10+ minutes on different tracks I have raced at. This is in my
Losi 8ight 2.0 buggy. Temps from 200-230f
aaron joy is offline
Old 05-16-2009 | 04:17 AM
  #349
TIX's Avatar
TIX
has anyone compaired the the RB 3001 pipe to the 2045 pipe
i want to get a new pipe andim wondering if its worth getting the new pipe to keep in line with the EFRA rules we run here
TIX is offline
Old 05-18-2009 | 12:09 AM
  #350
I own a RB C6 BB L2G with a 192 and 2045Exhaust, but I'm having trouble finding the right carb settings.
When I use the stock settings (HSN : 3.5 turns from closed, Idle : 5 turns from closed), I don't know which setting for the LSN to use. Should it be flush ?
Or could someone post their carb settings, So i can see where I have to 'aim' at.. I'm desperate
Sorry for my crap english, it's not my mother tongue ;-)
enginez is offline
Old 05-18-2009 | 02:12 AM
  #351
keavze's Avatar
if you look at the c6 manual carefully, RB refers to the LSN when they say idle...
adjust yr LSN to 5 and yr idle gap to about 0.7-1mm...
and tune from there.
keavze is offline
Old 05-18-2009 | 02:17 AM
  #352
BSC's Avatar
BSC
I have a WS7 and have done a full rebuild on it .
The engine is really sluggish down low and then hits a power band at half revs .
It flames out all the time .
It has new bearings and the carbi and back plate is sealed .
Plenty of pinch and compression as it is new .
WHAT IS WRONG , PLEASE HELP
BSC is offline
Old 05-18-2009 | 02:51 AM
  #353
Ok, thanks. Will try
enginez is offline
Old 05-18-2009 | 03:32 AM
  #354
Try a hot plug too. Nova's C5 or O'Donnel's 77
cheapskate.brok is offline
Old 05-18-2009 | 04:06 AM
  #355
buggydad's Avatar
Update on my c6 usa spec got the thing tuned to run at 225-230 and im getting about 11 Min of run time.Thats with a jp4 pipe im going to try to get the 2045 to see if it gets better Thing is sweet
buggydad is offline
Old 05-18-2009 | 06:12 AM
  #356
keavze's Avatar
what pipe set you're using? when does it flame out?
maybe yr LSN is not tune right?
lastly, could be yr clutch setup too...
keavze is offline
Old 05-18-2009 | 06:32 AM
  #357
Glowplug. As stated, try anything hot.
Semple is offline
Old 05-18-2009 | 01:58 PM
  #358
BSC's Avatar
BSC
I'm using the RB 2045 pipe with the 198 header combination
I tried an OS P3 plug , it helped a lot but still the same end result
It can flame out at any time , mainly in the pits . to get it running and keep it running when it is cold is a nightmare .
BSC is offline
Old 05-18-2009 | 04:36 PM
  #359
diamondracing's Avatar
OS P3 plug is not a good choice for any RB engine. Try turbo Odonnell 97 or RB 5.
If it flames out during pit stop 99% of the time with ws7 or C6 the bottom end is to lean. Really have to run RB's on rich side on Bottom end. When you say it was hard to keep running when it is cold. The C6 & ws7 should get up to temp of 180 or so very quickly if they do not they are not tuned right. I have ran C6's at the Nitro Pit in AZ when it was 110 degrees in the summer and ran the same C6 in So Cal when it was 55 degrees and tuning was changed an hour or 2 on top and temps where exactly the same. Just have to find the sweet spot on the Carb.
diamondracing is offline
Old 05-19-2009 | 12:44 PM
  #360
aaron joy's Avatar
I just got a phone call from my LHS, 09's have come in!!! Im going to pick up my "Hobby" 5 port after I am done work.
