RB Concept Engine Thread..
#317
Well a buddy has a jp4 and a 2045 for sale cheap. Would one of those work?
#318
I tried jp4 a month ago for a couple tanks and it ran strong but hot. 2045 is the ticket. with the s5 2045 lacked top end just a little at end of straights. id say your gaurenteed 11 minutes. I used a 2045 for second half of 1st gallon on break in. 2045 or 086 are the only pipes iv liked on my s5. wish i still had my 2045 being that my rb is pipe limited...
#321
only thing different is your ws7 would put my s5 in the dirt lol. id see parts of the track(or off track) thats unchartered with a ws7. do your temps go over 235?
#322
THanks for the info. SHould I run the #7 on my new S5, during break in and after break in. Thanks for the response, atleast there is one person out there showing love. I also run odonnell 30% after break in. I run 20% sidewinder during break in. Also, where did you order that new Hobby 5? I wanted to wait for these but got to jonesing after I ran that s3 last weekend.
I ordered them directly from the RB importer in Texas. I work at my local hobbyshop and I do the RB orders for him. I was told they should be on their way from France very soon. I got four on order. I will let everybody know when we get them in.
#323
Thanks bro.
#326
when i ran my s5 with jp4 it was rockin. i ran it for 3 tanks at crcrc about a month ago. i got off the stand after a 7 minute heat and several minutes of practice so tank was about empty and temp was 260 exactly. i walked out of pits and another guy running a couple c6's said it smelled hot and to put a jp1 on it. well the jp1 was crap. it could make jumps but no top end and i didnt have time to tune so i switched to jp4 for main. last weekend i ran a re11 and it was pushing 270+ degrees. the smooth powerband on an rb is hard to get used to after running vspec type engines.
#327
How much difference in run time would I get with a 6.5mm restrictor instead of a 8.mm one in a WS7 II ? I have the 8.mm now and only get a little over 6 min. I know my pipe is a gas hog (JP-3) and will be changed soon to a 2045, but I need runtime now? I am going to add another filter and some fuel line, but need to make a 7 min heat, so I am looking to gain another min. or so.
Thanks Joe
Thanks Joe
#328
Well, after chasing a tune for over a week I decided I'd go to the track today anyway. I had some good guys helping try to find the tune. We would find what we thought to be a good idle, and good bottom end, put it down on the ground for a few minutes and it would start to lean out and struggle to move at all. After about 30 seconds, it would get this horrible lean bog at half throttle or more. It would spit tons of smoke for those 30 seconds, then there would be a lot less, and the temps would soar up above 260. Same problems I've been having for a long time now. It got to the point that the bottom end was out so far that it just didn't make any sense to keep going. Then one of the guys noticed that the o-ring that sits at the top of the carb neck had been pushed out and was no longer seated in between the case and the carb. I couldn't explain this as the engine had never been taken apart. At that point we just assumed that was the problem, an air leak at that point. I packed everything up and spectated for a few hours.
On the way home I stopped at Canadian Tire(Department store specializing in automotive, outdoors and tools/hardware) and picked up some gasket sealer. I began to take the engine apart and quickly realized that there was in fact, still an intact o-ring on the carb neck. The o-ring wrapped around the case below the carb is beyond me. I noticed as I took the engine off the chassis that there was a puddle of raw fuel under the engine mounts, and a steady stream of it coming from the front bearing/crank area.
I guess the big question is, could my bearing be leaking THAT BAD as to render my engine completely and utterly un-tunable and incapable of holding a tune/not leaning out regardless of settings? It's weird, the engine is not very old, and has not seen much fuel. Less than a gallon, still.
#330
Did you turn the fuel inlet where the main needle is? If yes you gotta be careful to turn the whole assembly. If you turn it and mis-align one of the soft gaskets it will leak. This will look like a front bearing leaking but it is really the main needle assembly. This is very common.
2Likes
