RB Concept Engine Thread..
#331
Anyone know if the S3 L2G runs well with a Dyn 086 pipe? I know the 3 port Nova does and thought the S3 might be similar. I don't have the 2045 pipe I've seen recommended for the engine. I need to go through my pipes, but I have a couple of old RB's and I think one of them is similar to the 2045 (2020 maybe?). Thanks.
#332
#333
Did you turn the fuel inlet where the main needle is? If yes you gotta be careful to turn the whole assembly. If you turn it and mis-align one of the soft gaskets it will leak. This will look like a front bearing leaking but it is really the main needle assembly. This is very common.
Am I on the right track here?
I don't recall ever taking it apart, but it certainly seems a possibility for the source of my leak. Especially considering the amount of fuel there was under the engine mounts.
I think I've got it adjusted so there's no possibility for a leak from the inlet now. Should I reassemble and reinstall my engine and try it out, see if my problem is solved?
#334
Yes, it is a pretty common problem if you turn the fuel inlet. It looks like a front bearing is leaking, but since the inlet is right over the bearing this can be missed. Those little washers can be filed smooth again or get new ones. After reassembling put some of that black airseal stuff all the way around those two areas.
#337
My JP-3 is only getting 6 1/2 min. a tank, and my JP-1 is about 7 1/2.
That's with a 8mm carb restrictor and running at 235-240*
I am selling them and getting a RB2045 with a 192 header, from what I have heard that will get me over 10min a tank and run about 225* with the same needle settings!
IMO a JP-4 on a WS7II would not have any bottom end!
#338
I don't think the JP-4 would kill the bottom end of the WS7.
It already has tons on its own and would just calm it down a little and give you more top. Depending on the track size the JP-4 can be a great pipe and helps with fuel mileage as well.
#340
hi,
i'm thinking of switching to 16% nitro for my ws7 and c6, anyone tried?
i gotta remove 0.1mm head shim right?
seems like nobody uses 16% for .21 and above engines, any reasons?
#342
I got my c6 usa broke in.It toke a while and last i was at the track i started to race tune it.Im running it with the jp4 and the thing runs like a raped ape but im thinking the jp4 may be hurting it more then anything.Does anyone know if i can/should run the jp4 manifold with the rb 2045 or is there anymore recomendations?
#343
#345
2Likes
