Like Tree2Likes
RB Concept Engine Thread..
Old 02-28-2011 | 05:47 AM
  #1831
Chris Peralta's Avatar
Originally Posted by TIX
Has anyone run the B11 yet?
How is it compared to the B10 in terms of power?
The B11 should be a little more mellow compared to the B10. The timing is not quite as aggressive and and will get better fuel economy. I will get mine this week I hope and be able to start the break-in over the weekend.
Chris Peralta is offline
Old 02-28-2011 | 07:22 AM
  #1832
Lochii's Avatar
I won 2 brand new piston/sleeve sets on ebay last night, 15 UK pounds each, hah! A S3 and S5 set. I read they both fit in the s7 case, and my dad happens to have one of those. I guess I'll try the S5 first, for my truggy.
Lochii is offline
Old 02-28-2011 | 07:39 AM
  #1833
aznitronut's Avatar
Originally Posted by itsAUG
Anyone have problems starting a gallon old ws7? I just got a used one and the pinch is so tight at tdc that I have trouble getting it "unstuck" with a pair of padded vice grips on the flywheel. I have it preheated and I backed the plug out a little and it still locks at tdc and burns up my starter box wheel. Any input would be appreciated.
You may also try to add a 1mm or 2mm head shim under the head button, that wil releive some of the pinch/compression, to make it easier to turn over the engine, after you have put more fuel through the engine, it will.get easier to turn over, you can remove the shim you.installed.
aznitronut is offline
Old 02-28-2011 | 11:10 AM
  #1834
Those will fit any of the S7, WS7, or WS9's as well as the S5 and S3's they were made for. They are all square stroke engines tho so your not going to have a ton of bottom end right off the bat, you will have to play around with gearing and clutch setup to get the bottom end just right.
Old 03-03-2011 | 03:49 AM
  #1835
Default RB C10
Dear all,
can you confirm that the C10 comes with cermaic bearings as i just broke in this engine dismantled it to check that everything is fine and the rear bearings seems like a normal steel bearing, is this right?
speed6 is offline
Old 03-03-2011 | 04:20 AM
  #1836
Grinder's Avatar
Originally Posted by speed6
Dear all,
It comes from the factory with steel bearings front, and rear.
Grinder is offline
Old 03-03-2011 | 10:30 PM
  #1837
Default 1997-2007 10th Anniversary RB??
I posted in the wanted section but thought that it may be helpful here also...I am looking for just the case (or whole engine)...had a head screw break off in it!!!...It is the 1997-2007 RB Concepts 10th Anniversary engine...Please help if you have one or have a buddy???!!! Thank you.
rpmhobbies is offline
Old 03-04-2011 | 08:38 AM
  #1838
Anyone who knows if the rb usa edition is taiwan made or nova made?
jubibamse is offline
Old 03-04-2011 | 09:03 AM
  #1839
Can you post a link? There is a C6 USA that is one of my favorite engines. There is also a USA combo they had recently had that was an S3 USA combo, I also think there was a USA version of the S5. All of them are Nova produced engines tho. The K10/K11 and the Sport10/Sport11 are the Taiwan engines.
Old 03-05-2011 | 06:03 AM
  #1840
Rick57's Avatar
Anybody have a C6 USA they might be willing to sell? Or know anybody?
Rick57 is offline
Old 03-06-2011 | 11:45 AM
  #1841
what pipe would you run on a w7 worlds ? thank you !
rc racer 103 is offline
Old 03-06-2011 | 12:20 PM
  #1842
aznitronut's Avatar
RB 2045/192 header
Old 03-06-2011 | 05:46 PM
  #1843
Originally Posted by aznitronut
RB 2045/192 header
thank you !!
Old 03-06-2011 | 06:03 PM
  #1844
aznitronut's Avatar
Anytime.
Old 03-07-2011 | 07:50 AM
  #1845
That is not an easy engine to find!!! If you do find one make sure you grab it up, they were a limited production from about 3 years ago so it could be tough.
