Like Tree2Likes
GRP... Engine... Thread...
Old 08-16-2009 | 02:59 AM
  #1786
badrun's Avatar
Thumbs up
Jarrod. bad habit hobbies in bendigo vic has grp plugs this is there number 03 54435505. i have run os plugs but i my self think grp work better but thats my thought but each to there own
cherss jason
badrun is offline
Old 08-16-2009 | 11:15 AM
  #1787
Cory Kerber's Avatar
Has anyone had a pulsating idle? It idled beautifully yesterday, i took the needles out and greased the orings, now it will not stay consistent. If i give it throttle then let off it'll idle high, then drop, then go high again, then drop and die. Could this be an air leak somewhere?
I tried Leaning the LSN, but then it would stay running. So i richened it and it still pulses.
Cory Kerber is offline
Old 08-16-2009 | 11:58 AM
  #1788
I richened the LSN and it will run strong now holding a nice tune, but it still pulses at idle. It will idle for a long time, but just inconsistently.
I set the needles back to factory and tuned from there. The idle still inconsistent.
I took the engine part and checked for leaks. The only leak i could find was coming from my ceramic front bearing when the carb was open. I'm guessing if i can hear air coming out that i should replace it?
If no one has a fix for this problem, i'm going to order a new front bearing and try that. If that doesn't work, i'll get some new fuel.
Old 08-16-2009 | 04:05 PM
  #1789
khudzik's Avatar
We at overdriverc.com still have some GRP turbo plugs in stock and we do ship to Australia.
khudzik is offline
Old 08-19-2009 | 12:07 PM
  #1790
Tickle's Avatar
Questions?? Parts..
Does anyone have or know where I can get a ConRod (losr2043) for a .28 GRP? The .21 and .28 are the same. I would even take a good used one.
Drop me a PM if you have one to sell here in the US.
Tickle is offline
Old 08-19-2009 | 12:14 PM
  #1791
khudzik's Avatar
Unfortunately, we are out of those. We just have a few engines left, some glow plugs and we have some GRP gaskets and o-rings coming in next week.
khudzik is offline
Old 08-19-2009 | 12:25 PM
  #1792
Tickle's Avatar
Default You and everyone else...
Thanks. I can't find one anywhere...
Tickle is offline
Old 08-19-2009 | 12:47 PM
  #1793
Try typing in grp in an ebay search in all catagories isolate that to radio control line. I will try and post a link but I'm on my phone. I was able to get new p/s and standard rod fairly cheap. The stuff is out there you just gotta hunt for it.
zixxer is offline
Old 08-19-2009 | 02:00 PM
  #1794
Tickle's Avatar
Thumbs down None
Did that and found everything but the con rod.
Tickle is offline
Old 08-19-2009 | 03:06 PM
  #1795
Keep trying. From day to day and I bet some pop up. Rumor is horizon may actually have some stuff. But I'm sure the price will be super retail horizon price. Lol
zixxer is offline
Old 08-19-2009 | 03:25 PM
  #1796
Tickle's Avatar
Thumbs up Thanks...
Thanks...I think I found one at a local hobby shop. A friend is looking into it for me.
Tickle is offline
Old 08-19-2009 | 03:36 PM
  #1797
FYI
You can use Boss and Falcon parts as well, the Boss setup is slightly wider, but its a easy fix with sanding/dremel.
Conrod is exact match.
casevac is offline
Old 08-19-2009 | 04:00 PM
  #1798
http://www.rcdeal.com/modules/stores...m.php?item=103
http://www.rcdeal.com/modules/stores...m.php?item=104
and yes its legit i got my last sport promo kit there ...takes about 10 days shipping
zixxer is offline
Old 08-19-2009 | 04:02 PM
  #1799
HaulinBass's Avatar
the parts are up on horizon but no piston and sleeve sets
HaulinBass is offline
Old 08-19-2009 | 04:03 PM
  #1800
Links don't work Zixxer.
