Like Tree2Likes
Go-Tech Engines Thread
Old 01-14-2008 | 05:19 PM
  #1291
Originally Posted by Rocket42
Hey Colin thanks man I really like running the Hyper 8.5 it justs suits my driving style. Its great to be back running the car but I still have a few new car bugs to work out of it.
DVP where did you purchase the engine? The older engines came with that setup one .2mm shim and one .1mm shim. It really works fine and my current engine is one out of the same batch. Everything about the engine is the same as the newer batch except the head shimming. You may want to pressure test the carb for the air leak issue. I will shoot you a pm
Satoch the newer versions of the engine include a slightly higher deck ht. This was done to make the engines easier to tune and improve reliability. they feature one .2mm alumn. shim and two .1mms shims.
tmizzle +1
Russell,
I have been noticing a lot more of the 8.5's winning races lately. Might be time to take a closer look.
Colin
C Branch is offline
Old 01-14-2008 | 05:29 PM
  #1292
Rocket42's Avatar
Colin next time I see you at the track I will let you take it for a spin, its a lot of fun to drive, it accelerates like the Losi but can be pushed harder.
Rocket42 is offline
Old 01-14-2008 | 05:31 PM
  #1293
free2day77's Avatar
I will second that, I started running an 8.5 from a losi and I can accelerate away from anyone (with a stock 3prt).. car is very stable and can be driven easy or hard
free2day77 is offline
Old 01-14-2008 | 05:33 PM
  #1294
Must be that Go Tech power!
C Branch is offline
Old 01-14-2008 | 08:17 PM
  #1295
so russ Mine just came with one shim installed and 1 shim in a bag in the box. That is correct right?
GRudinger is offline
Old 01-14-2008 | 10:11 PM
  #1296
Rocket42's Avatar
Grudinger there should be 2-3 shims installed and 1 in a bag in the box. It should have .3-.4mm of shims included, if you need some shims please let me know.
Rocket42 is offline
Old 01-15-2008 | 01:20 AM
  #1297
vti-chris's Avatar
Originally Posted by satoch
Russell, what is the thickness of the shim included as mentioned above? My Race 3 port was packed the same way.
Russel it seems that GO has some issues on quality control on these engines.
Although they do seem to correct issues like carb leaks and such but i have read all posts for these engines and i never found a post that backs up the previous one.
Opinions on head clearance fly everywhere and i believe we need a post with GO engines line up and their correct head shims and clearance no matter what shims the engine has in the box because i believe the number of shims might be a wrong from the engine assembly and packaging.
vti-chris is offline
Old 01-15-2008 | 07:20 AM
  #1298
will g's Avatar
RUSSELL
thanks for the help this weekend with motor and letting me borrow a motor to run since mine didnt want to race this weekend. i will be placing an order with you soon for a new motor. for my truggy/buggy i will let you know more soon on what one. thnx again will g
will g is offline
Old 01-15-2008 | 03:54 PM
  #1299
Jason Halvorson's Avatar
holy cows the 3port race is one of the sickest engines ive ever seen!!!!!!!
Jason Halvorson is offline
Old 01-15-2008 | 04:43 PM
  #1300
Vigilante212's Avatar
Come on jason a little more info
Vigilante212 is offline
Old 01-15-2008 | 06:24 PM
  #1301
rltanner's Avatar
is it awsome Jason
rltanner is offline
Old 01-15-2008 | 06:34 PM
  #1302
Originally Posted by rltanner
is it awsome Jason
Old 01-15-2008 | 07:16 PM
  #1303
mugenb46's Avatar
Originally Posted by Jason Halvorson
Here is what i can tell you from looking at the motor apart. The exaust is done the way i was hoping, it's not closed off like a stock 3 sport motor. The crank is cut very clean, the inside of the case is very nice as well. The machine work resembles trhe 5 and 7, releived boost port in the case, and the sleeve is very nice as well, nice big transfers and boost with the 2 bypass ports, the cooling head is very nice, and the cuts in it look just like the 7 ports, the 5 ports will have the same cuts as the 7 as well. if i get a chance i will be breaking this bad little red head in this weekend. And of course it's a TURBO This is what i will start off with for breakin and testing.
GO 3 port RACE SPEC 8mm insert, STOCK
GO 2047
Rocket Science 30%
OS P3
RC8, with all 1.0 and M2C Hard Standard shoes
mugenb46 is offline
Old 01-15-2008 | 07:53 PM
  #1304
MassiveMods's Avatar
Just to let you Go Lovers know that there is now a Go Engine thread in the Australian racing for all Ozzy Go Engine lovers !
Cheers MM
http://rctech.net/forum/showthread.php?t=199789
MassiveMods is offline
Old 01-15-2008 | 10:35 PM
  #1305
Rocket42's Avatar
Vti-chris, I am not sure what you mean. The factory has made a few changes to the heads and deck ht. reccomendations do vary from location to location. Since I have been importing the engines there have been only 3 deck ht. changes. The first batch included 3 shims with a total width of .5mm, They then added .2mm into the button and removed 1 shim. so the overall squish was the same but the engine only had 2 shims with a width of .3mm. The final change is recent and they added 1 shim so the shim width is now .4mm and they include a extra shim for break in, but that is up to you if you wish to use it. The last change was to increase reliability by making the engines easier to tune and also lowering the risk of detonation because they were at the min. deck ht. for 30% nitro.
There were very few of the original deck ht. engines sold in the U.S. and all of them had the original alumn. carb. I currently run the middle deck ht. engines and have never had a problem, but a few people had experienced blowing an few plugs during break in because of the deck ht. I haven't had a single complaint from the latest batch.
Rocket42 is offline
