Like Tree2Likes
Go-Tech Engines Thread
Old 11-12-2010 | 03:30 PM
  #12691
69mustangbjs's Avatar
New local indoor track opening up by me this weekend, most of the guys there run the OS and Mugen power plants from what i'm told, i'm gonna have to show them guys what the GO's are all about
69mustangbjs is offline
Old 11-12-2010 | 04:56 PM
  #12692
deadmancourt's Avatar
yes sir! GO get em! lol
deadmancourt is offline
Old 11-12-2010 | 05:08 PM
  #12693
motomatt's Avatar
Where is this new facility? Chicago area isn't "right out my back door" , but might be do-able
motomatt is offline
Old 11-12-2010 | 05:12 PM
  #12694
That's what I'm thinking too. Where at?
dayglo33 is offline
Old 11-12-2010 | 07:10 PM
  #12695
jwm2's Avatar
I was running my go engine the other day at leisure hours in joliet. Seemed to keep up with the werks and ninjas just fine and then i realized it was too rich, so i leaned it out and was pulling away from them in the straights with ease
jwm2 is offline
Old 11-12-2010 | 09:18 PM
  #12696
MAGPIE-121's Avatar
didn't we tell ya theres r killer engine
MAGPIE-121 is offline
Old 11-13-2010 | 01:31 AM
  #12697
grizz1's Avatar
Oh yeah !! The 7 Ports will make most motors look pretty average down the straights The look on their faces is priceless - just like in the Mastercard adverts
grizz1 is offline
Old 11-13-2010 | 06:31 AM
  #12698
Guys,
the new track is in Griffith, Indiana 1347 main street i believe is the address
the track opens up today and nitro is today and electric is tomorrow, there sayin racing this weekend is 50/50 but next weekend for sure
Old 11-13-2010 | 08:39 AM
  #12699
motomatt's Avatar
Dang, I was hoping it'd be northwest of Chi Town. Griffith is 300 miles.
motomatt is offline
Old 11-13-2010 | 08:45 AM
  #12700
sriley's Avatar
Ok GO guys I need some advice. I just took apart my engine for a good cleaning and to replace the con rod. Here are my questions.
1. I can't seem to get the carb off (yes I took the screw out). It wiggles a little but not much.
2. What is the best way to get those little ring clips out of the piston? So I can change the rod.
3. What is the best stuff to use to clean the entire engine inside and outside. It has a lot of gunk built up on the outside and was wondering what I could soak it in.
sriley is offline
Old 11-13-2010 | 10:26 AM
  #12701
motomatt's Avatar
1. Try installing the screw in from the other side of the "carb wedge", then gently tap on the screw. This will drive the wedge out of the crankcase. The second wedge is then easily accessed and removed.
2. A small Hemostat or micro electrical pliers makes working with the clips much easier. Be very careful when installing them, they are spring steel and love to fly to invisible places.
3. I have a small "bench" I made. Large enough to put a small coffee can on. It's on legs and has a 540 size motor fastened underneath. I installed a large pinion gear with all the teeth ground off on one side to cause an imbalance.
When I switch on the motor it vibrates, causing my coffee can to agitate the cleaning solution in the can. I use chlorine free brake cleaner. Some cleaning fluids may cause O-rings to swell.
motomatt is offline
Old 11-13-2010 | 10:30 AM
  #12702
sriley's Avatar
Okay thanks for the help.
sriley is offline
Old 11-13-2010 | 10:34 AM
  #12703
Suspended
i hate those little spring steel clips!!!!
inferno13 is offline
Old 11-13-2010 | 11:40 AM
  #12704
MAGPIE-121's Avatar
do the piston clips inside a plastic bag, unless you have lots of them
i use motor spray to clean out my motors, then flush with water, then blow dry & re-oil straight after
Old 11-13-2010 | 12:08 PM
  #12705
sriley's Avatar
Thanks for the tips guys. Now I can't get the rear bearing out. I was trying to use my wife's hair dryer but I don't think is getting it hot enough to tap it out. I can only get the block up to 175*. I think we have a heat gun at work. I'll have to try that.
sriley is offline
