Like Tree2Likes
Go-Tech Engines Thread
Old 11-15-2010 | 12:00 AM
  #12721
MAGPIE-121's Avatar
answer usa have the losi clutch set up & a lot of losi upgrade parts : http://answer-rcusa.com/zencart/inde...ex&cPath=28_13
if you get the optional engine mount for the losi 2.0 you can run the 3 shoe clutch
MAGPIE-121 is offline
Old 11-15-2010 | 06:47 AM
  #12722
Have got the Go GX 7 Port and have had a bit of as problem,
Got the tune to stop at 7 sec on the pinch test and the idle at 0.7mm.
Ran the car hot and tried tuning the HSN, Ran great at settings Grizz Gave me and then went to pot,Very high idle on going down from Wot and then settled, looked and found the LSN 2 turns out from flush, reset this and ran again and the damn thing unscrewed again, fitted new black seals from Answer about half a gallon ago, can not see problem with seals but screw is loose to turn so presume U/S.
Is there any other seals I can use as i am running out of time to get some new or is there a fix i.e ptfe tape round them or similar, presume its seals but have put the engine on a new car today and wonder if ive set anything up wrong?
Hope you can help
Kevin
kevinjh is offline
Old 11-15-2010 | 06:54 AM
  #12723
Suspended
Hope you can help
Kevin
i would try alittle sealent on the threads, same as you would use to seal back plate or carb with, will still allow you to tune but will make it alittle tighter, ive done this on a high speed needle at worked great.
inferno13 is offline
Old 11-15-2010 | 07:09 AM
  #12724
brilliant - will give this a try,
Kevin
kevinjh is offline
Old 11-15-2010 | 07:12 AM
  #12725
Suspended
Kevin
after you apply set needle close to where you think it should be and let sit for a couple hours, or untill dry, should be good to go!!!
Old 11-15-2010 | 09:58 AM
  #12726
MAGPIE-121's Avatar
Hope you can help
Kevin
cut off some fuel tube, slightly longer than the o'ring groove, & use that for now!
grizz will chime in as i think this is one of his fixs
Old 11-15-2010 | 12:02 PM
  #12727
grizz1's Avatar
+1 - the fuel tubing works a treat.
As Magpie said, cut the tubing a little wider than the O ring groove and fit the tubing into the O ring groove with the excess tubing facing the top of the needle assembly (ie the adjusting end not the needle tip).
Now gently screw the needle into place. The excess tubing will be cut away by the needle housing and will shred out the top as you screw the needle home. Back the needle out a little to remove the shredded excess tubing and you are racing.
The fuel tubing will last for yonks, and provides a nice tension on the needles which is easy to adjust but will hold itīs position.
Give it a try and see if it works for you
grizz1 is offline
Old 11-15-2010 | 12:07 PM
  #12728
Maximo's Avatar
I tried and tried to get this method to work, but I didn't have any luck at all.....I wonder if some brands of fuel tubing work better then others ?
Maximo is offline
Old 11-15-2010 | 01:05 PM
  #12729
grizz1's Avatar
Fuel tubing does come in different sizes, so itīs possible this is the problem.
Thatīs a bummer Neal, everyone I know that has used this method as a temporary fix has found it very successful.
You donīt want the tubing too much wider than the O ring seat, just a smidge.
grizz1 is offline
Old 11-15-2010 | 01:10 PM
  #12730
jwm2's Avatar
I've noticed some fuel tubing is much softer than others. Might want to try the softest you can find.
jwm2 is offline
Old 11-15-2010 | 01:45 PM
  #12731
have got some small dia tubing so if the sealant fails will give this a try,
Thanks for the info
Kevin
kevinjh is offline
Old 11-16-2010 | 01:52 AM
  #12732
Gizmatron's Avatar
you need the stuff with the thinner walls.I have 2 types..same internal diameter but I think the thin is 5mm and the thick is 6mm and is usually sold as "reinforced"..at least it is over here...the thin stuff works fine..
Gizmatron is offline
Old 11-17-2010 | 07:14 AM
  #12733
MAGPIE-121's Avatar
GX 5 port wins first Annual Turkey race at the all new HCRCR in McDonough, Ga.
http://www.neobuggy.net/modules/news...p?storyid=9322
Old 11-17-2010 | 07:42 AM
  #12734
motomatt's Avatar
This reminds me of when Caster named their engine the grenade.
Does this make GO Engine the top turkey??
I couldn't help posting this .......................just the way my twisted mind works.
motomatt is offline
Old 11-17-2010 | 09:01 AM
  #12735
Suspended
LMAO!!!
