Like Tree2Likes
Go-Tech Engines Thread
Old 11-09-2010 | 04:46 AM
  #12661
Default New to Go
Just picked up a 5th gen 5 port any advise on tuning and would a 2035 pipe work for a truggy?
rsmith569 is offline
Old 11-09-2010 | 09:37 AM
  #12662
MAGPIE-121's Avatar
2072 pipe is the best all round pipe for this motor, IMO
MAGPIE-121 is offline
Old 11-09-2010 | 10:54 AM
  #12663
grizz1's Avatar
Go to www.go-racing.co.nz and click on "Tech Tips" from the homepage menu.
This will take you to run-in, tuning and maintenance tips for the GO motors.
Being an older motor, check and see what sort of low speed needle you have fitted - long or short, as this will make a big difference to the tuning.
Open the throttle slide fully. If the lsn has come out of the receiver jet on the right hand side of the throat, you have the short needle. If the tip of the lsn is still in the receiver jet with the slide fully open, then you have the long needle.
Short needle will tune like any other motor, but the long needle you will need to follow the instructions on the web site (especially regarding the high speed needle settings).
Any problems send me a PM or email me at [email protected]
grizz1 is offline
Old 11-09-2010 | 02:29 PM
  #12664
Flanno's Avatar
Also being the older gen, make sure to heat it well before each start to releave the metal pinch. The new GX has metal pinch too, and still needs heat, just that it's not as tight as the older models.
Flanno is offline
Old 11-09-2010 | 05:04 PM
  #12665
deadmancourt's Avatar
ALWAYS PREHEAT UNTIL PINCH IS GONE WHEN ITS HOT!.....is it new?
deadmancourt is offline
Old 11-09-2010 | 05:09 PM
  #12666
No used but still has good pinch
Old 11-09-2010 | 05:15 PM
  #12667
ok cool...yea if you are able to ALWAYS PREHEAT THAT MOTOR!....it will DOUBLE its lifetime pretty much cause those motors have LOTS of pinch
Old 11-10-2010 | 09:38 AM
  #12668
here are pics a Go GX series motor @ the Worlds in Pattaya Thailand!
Attached Thumbnails Go-Tech Engines Thread-go-%40-worlds.jpg   Go-Tech Engines Thread-go-%40-worlds2.jpg
Old 11-10-2010 | 09:48 AM
  #12669
69mustangbjs's Avatar
any idea who's buggy that is?
69mustangbjs is offline
Old 11-10-2010 | 10:00 AM
  #12670
no, i tried to research it but found noone ....there is a couple more there cause i seen on rc live they showed a clip of the buggies fueling and running out of pit lane and they showed a buggy that had a GO motor for sure and wasnt the 1 in the pics!
Old 11-10-2010 | 10:03 AM
  #12671
dead, are you a premium member on live?
Old 11-10-2010 | 10:21 AM
  #12672
no
Old 11-10-2010 | 11:02 AM
  #12673
newuserlosi8t's Avatar
isnt that the sh buggy
newuserlosi8t is offline
Old 11-10-2010 | 11:11 AM
  #12674
yup!
Old 11-10-2010 | 01:48 PM
  #12675
Default GX 5R in onroad car
Hiya...
was looking for a engine with alot of torque for a serpent 966....hence decided and got a gx 5r. Want to know what manifold would suit the 2072 pipe that came in the combo as the manifold came with it is suitable for rear mounted not for onroad configuration ? Anyone tried this engine with suitable on road manifold and pipe ? What carb have u used in this engine as with the engine carb i cannot access the idle screw !!!!!!
thanks
xtreme888 is offline
