Go-Tech Engines Thread
I know it's a drag, but scan back over the last 30 or so pages on here and you will find all the info you need.
Run in, tuning, different needles, tuning methods etc. It's either written out or has a link to a site with the info.
If you have any concerns send me a PM anytime.
The hotter plugs don't necessarily perform better. They tend to fail more often because of the thinner filament, and on 30% can be a little fragile due to the raised compression the higher % nitro creates.
I have run OS P3 in the past, but find the 97T a better option - for me anyway.
For plug the 97t o'donnell is whats recommended and what most of us use. As far as shims, take a look at the go engine usa website. For tuning you need to find which needle you have. If its the short needle you just tune as normal. For the long needle you need to tune the LSN first and then tweak the HSN as needed. Use the guide on massivemods website as a guide. For tuned pipe, the dynamite 086 is cost effective, good looking and does a great job. The smallest reducer i'd mess with is the 7mm, but thats me, you can try the 6mm if you want.
http://www.massivemods.com.au/index....5237dc97b55454
it will run pretty good on these motors but not the best gas mileage and as for the jp1 i have never ran it so i dont know?
i set mine with it in, also run a 6mm restrictor, IMO. from 6mm to 7mm doesent make much differnce that i can really tell, on performance and milage, about the same, tuning not much differnt either
with the venturi out! lol
2Likes
