Go-Tech Engines Thread
gallons on motor are unknown..the piston is super clean and the looks pretty new, the rod has no play at all on the crank. I am talking to a local guy deadmancourt on here regarding changing the PSR and crank over to the Gx 5r.
the case, head, everything outside the engine is brand new.
the engine he will give it to me for 20$ bucks ..
It need a new crankcase and carburetor pinch bolts
maybe i will make it from gx7r to gx5r with changing the piston-sleeve ...
the crankshaft at the crankshaft pin has loose the tin coating ... i must change also the crankshaft ?
Also which is the best pipe?i have a pipe set from my nova 9901 with 41021 header it will be good to use the same?i dont want to buy new GO pipe because i have not the money . I want just to fix this engine cheap.
I have found cheap the parts...
pinch bolts from Precirotate engines 6$
crankcase from ebay with bearings and backplate from gx5r 40$
also if i will make it GX5R i will need 80$ for p/r/s
so i will give 126$ for parts+20$ for the engine =146$ and i will have a new gx5r engine ...
Which cheap pipe set will be better? a dynamite 053 or a dynamite 086? or my novarossi pipeset that i have it already?
hey winner!...you should contact Shane @ Go-Racing.co.nz .....he can hook you up!...his name is Grizz1 on here!...he is in New Zealand which i think would be easier to get parts from,then the U.S!
Just got back home from our 3 day National Champs event. What a great weekend. Wicked track and very fast close racing.
GO Racing NZ was the principal event sponsor and we couldn't have asked for a better result. GO GX-5R won the Truggy A-Main 1 hour final (by 4 laps), and Massive Mods MG66 won the Buggy A-Main 1 hour final (by just on a lap).
The track was fast, with a wicked long straight that had the motors peaked out for a long time on every lap.
All the GO and MG66 motors performed flawlessly over all three days. At crunch time on finals day, not one flame out or glitch in either class right through an hour and a halfs racing of semi's and finals
Lots of happy racers getting great value for money out of their motors, which is what it's all about
Our 2 dayer was postponed (proline) due to poor weather , I did 1 lap on Saturday and then the heavens opened up
and today was a total wash out too
typical for a long weekend.
Bummer mate. I hate it when that happens
That's great news on the video too. It will really help people with the tuning. A picture paints a thousand words - so a picture with sound must be totally awesome
Great to hear all went well at NZ for the GO drivers
From what I could see on the net, GO engines made up near 1/3rd of the entrys in buggy
enough said hey
enough said hey
As for swapping the P/S/R over the the Gx. There is no difference in those parts from the older models to the Gx except for the new style rod and the wrist pin being coated. (Gen 5.5 came with coated pins) The Gx has the coated crank, new style head, 2 o-ring hsn, different looking case.
Rex
2Likes
....hey how did you like those LOSI tires and wheels?...do they work for you @ your track?...
