Like Tree2Likes
Go-Tech Engines Thread
Old 03-16-2010 | 04:24 PM
  #10276
as a go tech fan the new competition heat heater is awesome for tight pinched motor's.........
rkhess is offline
Old 03-16-2010 | 07:39 PM
  #10277
MassiveMods's Avatar
Originally Posted by vmlopes
Can I ask how you or others pre-heat a tight engine out in the field, or do your pit areas over there in the USA have mains power??
I like fire myself , being a self confessed Pyro ..
MassiveMods is offline
Old 03-16-2010 | 07:43 PM
  #10278
I JUST BOUGHT A GO TECH STARTER BOX AND IT SAYS THAT IT NEEDS 2 NIMH 4600MAH 7.2V BATTERYS. WHAT IM WANTING TO KNOW IS ISNT THERE A BETTER BATTERY LIKE MAYBE A GEL CELL OR SOMETHING THAT I CAN PUT IN IT INSTEAD OF THOSE STICK BATTERYS. I WANT SOMETHING THAT WILL LAST NOT SOMETHING THAT IM GOING TO HAVE TO WORRY ABOUT CHARGING. JUST PM ME IF YOU HAVE ANY FIX TO THIS PROBLEM OR ANY SUGESTIONS
grubby is offline
Old 03-16-2010 | 10:25 PM
  #10279
Ruune's Avatar
2x or 4x 4600mAh NiMH packs will last longer than a gel cell battery. They'll also be lighter. You may also want to try a LiFe or Lipo battery pack. The Losi starter box lipo will work: http://www.losi.com/Products/Feature...rodId=LOSB9821
Ruune is offline
Old 03-16-2010 | 10:49 PM
  #10280
grizz1's Avatar
It does say on the box that it will take either the stick packs or a 12v 7A gel cell or sealed lead acid battery (your typical burglar alarm battery will work fine). I run a 12v 7A gel cell in my starter box and it lasts for weeks on end between charges. Give it a nice slow .3 amp charge overnight and you will be good for several meetings before needing a recharge, and their a lot cheaper too
Either set up will work well.
grizz1 is offline
Old 03-17-2010 | 03:01 AM
  #10281
Originally Posted by bigmatt
I wish you would have said all this when I called you. This is the first I heard of the bent crank. I do not have a machine shop or access to the equipment I would think you have, to check engine parts. I never once attacked your work, I love this engine. So Rick has done a partial refund and I must say he stands behind his product. After what has been said here I would say we have had one hell of a communication problem.
So with that said, Rick I do apologize and hope that you do except it. MATT
No worries Matt, I talk to so many people it gets confusing sometimes and I forget to say things. That's the reason I prefer the phone. At my age that still doesn't help. It's not a problem and you can call me anytime you wish. Let me know if you have anymore problems. AS always I'm here for you and anyone else anytime you or they need me.
Rick B is offline
Old 03-17-2010 | 10:17 PM
  #10282
Rampokker's Avatar
The gel cell batteries work great. Like grizz said, they last a long time. Only thing I don't like about them is the weight. I've got a gel cell battery in my truggy starter box, and a 4s lipo in my buggy box. My buggy box spins even the tightest engine without any issue, and its heaps lighter than the truggy box.
Rampokker is offline
Old 03-18-2010 | 06:54 AM
  #10283
Will the new GX piston/sleeve/conrod and crankshaft fit in previous generation go engines?
Frode
Tigergutt is offline
Old 03-18-2010 | 08:48 AM
  #10284
Ruune's Avatar
Frode
Yes- it is the same R21 case.
Ruune is offline
Old 03-18-2010 | 09:13 AM
  #10285
Old 03-18-2010 | 01:43 PM
  #10286
Flanno's Avatar
I'll be running sticks or Lipo in mine. as the whole reason for wanting the new box is for away meets and to save weight in my plane luggage and also gell cells aren't allowed on the plane.
Flanno is offline
Old 03-19-2010 | 08:44 AM
  #10287
Ruune's Avatar
That's great. I just received a limited number of them last night. I'm keeping one for myself and offering the others to dealers. I'm running 2x 2S 2500mAh life packs in a series. I believe they're rated at 20C, but more than enough for this application. Honestly, I feel that LiFe batteries are the best solution for starter boxes. They have sufficient voltage: 3.3v*4= 13.2v, which is greater than a 12v gel cell, so you'll get greater RPMs than with a 12v. Additionally, you get higher discharge rates (in AMPERES) with LiFe than both lipo and gel cell. Then there's the safety aspect. 12v gel batteries are acidic and lipos will BBQ your box if you run them all the way down. With a LiFe pack, you get the best of both worlds.
Ruune is offline
Old 03-19-2010 | 08:51 AM
  #10288
Ruune's Avatar
Wanted to give you guys an update. I just received a large supply of parts- seals, glow plugs, cases, GX crankshafts, front and rear bearings, head shims, head buttons, STARTER BOXES, FUEL COOLERS, TOOLS, FUEL BOTTLES, etc. If you're looking for parts, chances are that I've got it in stock. Next order arrives in 2 weeks, which will be my bi-weekly GX engine inventory refresh.
For those of you that are waiting on parts from amain, they should be well-stocked next week.
Also, if any of you are looking for break-in services, ask any of the dealers on here send me an inquiry and I'll point you to the right people.
Thanks!
Trey
Ruune is offline
Old 03-19-2010 | 01:40 PM
  #10289
motomatt's Avatar
Any new info on the GO flywheels?
motomatt is offline
Old 03-19-2010 | 02:13 PM
  #10290
Ruune's Avatar
Oh... you mean THESE?
Should have them in a couple of weeks, and have pricing figured out by Sunday.
Ruune is offline
