Like Tree2Likes
Go-Tech Engines Thread
Old 03-03-2010 | 08:06 AM
  #10126
Ruune's Avatar
Originally Posted by rageworks
Hey Runne, are you going to be importing the
new GO Engines flywheel and clutch shoe set-ups?
I see the flywheels are annoed the same color as
the GX engine cooling heads.
Link to pics; http://www.neobuggy.net/modules/news...p?storyid=7820
Probably in a month or so. I heard about it the same way you guys did, and everyone in Taiwan was off or their 2 week Chinese new year. So, I dont even have pricing yet.
Ruune is offline
Old 03-04-2010 | 11:09 AM
  #10127
DxD's Avatar
DxD
I've had some good racing with my GO GX-7R, but it broke the front bearing and the piston is pushing 5mm through the sleeve, so it is pretty much a good key ring now. I've bought a new one already. I love these engines.
DxD is offline
Old 03-04-2010 | 11:54 AM
  #10128
Hey guys can you recommend me some initial needle settings for running in, for a GO GX5R have run it up as factory setting and it will only idle for about 15secs before stalling.........
vmlopes is offline
Old 03-04-2010 | 12:09 PM
  #10129
MassiveMods's Avatar
VM decent carb settings will vary from car to car , what you best do is do the pinch tune to get you into the ball park. That way you have a setting thats good for your set up.
http://www.massivemods.com.au/produc...e1445a349cc90e
this is a basic tuning GUIDE , to help you get the engine into the ball park , you can fine tune from there for your specific set up .
Hope this helps
MassiveMods is offline
Old 03-04-2010 | 12:27 PM
  #10130
Hope this helps
MM............nice one mate...........I just needed a ball park to get it running to warm up on the box for more than 15secs.......lol
vmlopes is offline
Old 03-04-2010 | 12:35 PM
  #10131
OK in that case Lean the LSN 1/2 a turn .
rev it up , if its fluffy up top lean the HSN 1/16 at a time till just before you get a clean rev all the way
put it on the ground and chase the nearest flock of pigeons that arent too close to any netball posts ...
thats a ball park
Old 03-04-2010 | 01:15 PM
  #10132
Default PISTON STICKING WHEN LOCKED UNDER COMPRESSION
Hi guys this is my first time on rc tech so please bear with me here goes.
I bought a revo last week has a picco 26 max engine nova cooling head the guy bought the engine last summer and has had a 1/4 gallon throgh it. I've had the engine running about and it cut out on me. The engine wouldn't turn so put some afteroil in still no joy. I then took the engine off the mount taken the cooling head to reveal the piston i then tried my roto start on it the piston was moving freely i sprayed with wd40 to clean for best measure and put the engine back connected the exhaust,air filter and glow plug and engine still wont turn i had to push the fly wheel with my hand hard to unlock. tried loosening the glow still no joy. the engine will turn with the glow plug out though. but as soon as i make the slightest turn it stops.
PLEASE HELP IM OUT OF IDEAS I KNOW NEW ENGINES ARE TIGHT IVE TRIED PRIMING, USING HEAT GUN ETC
speed demon2011 is offline
Old 03-04-2010 | 01:52 PM
  #10133
thats a ball park
Your too kind mate..........just to confirm that this engine is the same as my lads Nitro's........clockwise to lean, anti-clockwise to richen
vmlopes is offline
Old 03-04-2010 | 02:23 PM
  #10134
Flanno's Avatar
Yes bud, correct !
Flanno is offline
Old 03-04-2010 | 02:55 PM
  #10135
Try this
Pre heat the engine
Prime it excessively so that its almost flooded
Take the plug out
Pre heat it again
Bump it on the box so the fuel makes a fine mist out of the plug hole
Pre heat again
Put the carb slide at just above idle
Put plug in
Start it
Old 03-04-2010 | 04:05 PM
  #10136
do you guys know if the low end needle they sell at amains is the long or short version.iam already used to the long needle and i would like to get another long needle for 3pr that came with the short one, thanks
here is the link for amain needle
http://www.amainhobbies.com/product_...hrottle-Needle
meno222 is offline
Old 03-04-2010 | 06:56 PM
  #10137
motomatt's Avatar
Go Parts List:
21-2003 Throttle Needle (Slide)
21-2003A Short Throttle Needle (Slide)
That would mean the 21-2003 (the one listed at A Main) is the long one.
Moto
motomatt is offline
Old 03-04-2010 | 07:48 PM
  #10138
grizz1's Avatar
Originally Posted by motomatt
Go Parts List:
Moto
Looks like A-Main are a little confused.
The part number (21-2003) is correct, but the picture is of a short needle
GO motors in the US run the short needle, so A-Main may think this parts number for the low speed needle is correct (they may be unaware a long needle even exists for these motors). If you use that part number you will probably get the short needle shown.
The long needle is standard issue from the factory, unless the importer/distributor for your country requests otherwise - which is the case in the US I believe.
Yes, once you have the tuning of the long needle carb sorted the performance is great. A little smoother performance and slightly better economy IMO.
Here is a pic of the long taper LSN - quite different to the short needle shown on A-Main.
grizz1 is offline
Old 03-04-2010 | 08:04 PM
  #10139
thanks for this info,now i dont khow if i should place the order.
meno222 is offline
Old 03-04-2010 | 08:11 PM
  #10140
kael's Avatar
I bought a 5 port race from A main a year ago and it has the long needle.
kael is offline
