Go-Tech Engines Thread
do you guys know if the low end needle they sell at amains is the long or short version.iam already used to the long needle and i would like to get another long needle for 3pr that came with the short one, thanks
here is the link for amain needle
http://www.amainhobbies.com/product_...hrottle-Needle
posted in this thread recently. Please add your location
under nickname. Why, because if I knew that you were
located in the lower 48, I would have gladly sent you a
long ls needle for free. I don't mind helping someone here
in the states out if I have an extra to spare. If the one you
ordered turns out to be a short one, PM me and I will trade
ya, IF you live in the states.
Hang on .. What type of plug are you using ? what sort of fuel are you using ? what pipe are you using ? Is the engien rich ? is there a bit of fuel coming out the pipe un burned ?
If the engine is fluffly and rich then just lean the LSN about 1/4 turn , chances are you wont get it to run till it gets a chance to burn the fuel properly , the other problem is with new engine you are fighting a war on 2 fronts.IF The engine is tight and its rich .. This is a shitty combo to keep running , rich settings will constrict the sleeve ie it wont expand through heat.
SO
recommendation is
Run a med to hot plug
about 20 % nitro
SO
recommendation is
about 20 % nitro
Will have a another go today and get another plug...........the leaflet that come with the engine states HSN 1-2 turns out? thats a hell of a variable one whole turn?
Anyways will try again with both needles flush and go from there, thanks for your help and anything else you can think of is appreciated
Hey Mike, I am running the EFRA 2072 that came with the engine as a combo and a T3 plug, fuel is Byrons 25% I also have fitted the extra shim......no fuel coming out the pipe, which surprises me!! it does have smoke.
1-2 turns out from all the way in.........yeah have checked the gap with a drill blank and its 1mm
Hey guys I have 2 Go motors 2 /21's They both have the red head and they are both 3 port engines. one of them has a silver crank case and the other is black. The serial numbers are US0000470 silver case and the other is US0000566. Any idea why they changed colors??? Which of these 2 motor's would benifit best with some mod work done to it. Or should I sell these 2 and get a new one.
Thanks Jim
Thanks Jim
well apart from the crank,gudgeon pin and carb slide being TiNi coated,the new lighter con rod,carb completely revamped, and I guess port timings changed (not an expert on this) it also depends on which gen the silver head is....there were some differences between gen 3,4,and 5 engines too..
Thanks Jim
Thanks Jim
Ummmm somewhere in this forum there was a list of the changes to identify different gen motors..best way is to post a couple of pics here..make sure to get both the crancase and the carb clear in the pics and one of the GO specialists will tell you what you have for sure..
To be honest IMO - if it is a Gen 3 or earlier you would be better off with a new GX. The difference in technology and performance is huge.
2Likes
