Like Tree2Likes
Go-Tech Engines Thread
Old 02-28-2010 | 02:05 AM
  #10096
grizz1's Avatar
Originally Posted by vmlopes
Hey fellas I am looking for some running in tips for the Go GX5R as I have seen now 3 different suggestions, we have the manufacturers recommendation that came with the engine, the MassiveMods one and then "The Tuning Bible Thread" from this forum.......[
So any help/recommendations would be most appreciated
You have PM.
grizz1 is offline
Old 02-28-2010 | 08:16 AM
  #10097
Originally Posted by Paperman 90
I did it did not work well for me it seem like it was holding the motor back and it got poor fuel mileage . i when with a ofna 086 much better power and about 10-11 mins on a tank.
thanks, iam currently using the dynamite 086,ill stick with it.
meno222 is offline
Old 03-01-2010 | 12:02 AM
  #10098
MassiveMods's Avatar
Originally Posted by Taekyn
Just wondering if anyone knows if the Grenade motors crank is the same/compatible with the GX motors, think my pin is worn as ive changed the conrod and still have a lot of slop on the bottom of the stroke.
If you have Rod Part number 21-0600 and crank part number 21-0907T-03 yes it will work.
MassiveMods is offline
Old 03-01-2010 | 12:15 AM
  #10099
You would want the MM Run in or the Run in Bible method from HES . Both are good. Please steer away from old school run in techniques , idle on the box etc .. its the worst thing you can do to an engine.
http://www.massivemods.com.au/produc...e4cd77604e44ce
Cheers MM
Old 03-01-2010 | 04:14 PM
  #10100
bigmatt's Avatar
I think I posted a while back about assuming when it comes to the go-tec/mg66 line of engines. Was out running in some new clutch shoes when the engine started lean bogging. First thought? What's wrong with my engine? Turns out nothing. When I got it back inside found the the pressure hose from the pipe had rubbed up against the new clutch bell, producing a hole in it. So again to all those that cry that the engines are unreliable it's most likely the nut behind the wheel.
bigmatt is offline
Old 03-01-2010 | 05:18 PM
  #10101
LOL Nice one BM !
Old 03-01-2010 | 07:38 PM
  #10102
grizz1's Avatar
Yep, spot on there Matt. If you look after your motor it's pretty unlikely to play up too much. It's normally something external from the motor itself that's causing the problem. The nut behind the wheel being a very common fault
Hey Massive - pretty flash avatar and signature big fella. You going all up market on us
grizz1 is offline
Old 03-01-2010 | 10:02 PM
  #10103
Nah i got bored and had too much coffee .. its a bit long isnt it ... what a wanker
Old 03-01-2010 | 10:40 PM
  #10104
grizz1's Avatar
grizz1 is offline
Old 03-02-2010 | 06:36 AM
  #10105
Good post Matt and I agree. I ran one of my old gen 5 7 ports for a club race 2 weeks ago. We are talking an 8 gallon motor with rear ceramic and 3 gallon old con rod. Anyway it lost power in the middle of a qualifier so I pulled it off the track. I temped it and it was at 432 degree farenheight . It turned out that the glow plug came loose and it was sucking air so without ever killing the thing I tightened the plug back up and fattened the high needle 2 hours and put it back on the track. I finished the qualifier and the motor came of at 289. When I got home I took the motor apart and discovered the only things wasted were a $4.00 front bearing and the plug. It was crazy because I fully expected the motor to have no pinch left at all but it was perfectly fine.
matrixmike28 is offline
Old 03-02-2010 | 12:56 PM
  #10106
grizz1's Avatar
They don't mind a bit of heat - but 432 is a little excessive
Yep, the Go's are hard to kill. Value for money out there, they gotta be close to #1
grizz1 is offline
Old 03-02-2010 | 01:02 PM
  #10107
Hey fellas, need a little advice, got a new GO GX5R in my Losi 8ight T, looks a beast.........have heated it up etc. but the pinch on this thing is extrodinary, my starter box cant even turn the thing over, not even spinning the flywheel.
At the moment piston is at TDC, how much heat do you guys put on a new engine for first time starting? I got it pretty hot, too hot to touch?
vmlopes is offline
Old 03-02-2010 | 01:09 PM
  #10108
markr04's Avatar
Be sure to heat the case, not the cooling head.
markr04 is offline
Old 03-02-2010 | 01:15 PM
  #10109
Yeah I was, with a heat gun not a hair dryer so it lays down some heat pretty quick
vmlopes is offline
Old 03-02-2010 | 01:41 PM
  #10110
Try this
Pre heat the engine
Prime it excessively so that its almost flooded
Take the plug out
Pre heat it again
Bump it on the box so the fuel makes a fine mist out of the plug hole
Pre heat again
Put the carb slide at just above idle
Put plug in
Start it
Should start straight away !
