Like Tree2Likes
Go-Tech Engines Thread
Old 07-25-2009 | 05:58 AM
  #7951
2fst2c's Avatar
Originally Posted by mattwoodcraft
i spoke with mark the other day i think you will find he is really busy
Thanks.
2fst2c is offline
Old 07-25-2009 | 09:26 AM
  #7952
Gizmatron's Avatar
Originally Posted by 2fst2c
Has anyone heard from Mark at Massive? Sent in a motor and have been trying to get in touch with him. Has not responded to emails or PM's. Just wondering if he's out of town or just really busy.
Yeh his email has gone nuts because of the delay in the arrival of the MG66 on top of his normal workload..he will reply just might take a while at the moment...I waited a week for a reply..don't worry he's alive and well
Gizmatron is offline
Old 07-25-2009 | 11:24 AM
  #7953
2fst2c's Avatar
Good to hear he's doing better than my motor. I'm not in a hurry just wasn't sure how long I'd have to wait to hear from him. Thanks!
2fst2c is offline
Old 07-25-2009 | 07:31 PM
  #7954
hey guys,
just did a bearing replacement and replaced the rod and noticed the little shaft the rod connects to on the crank is way worn down. Anyone by chance have a used, good cond. crank they want to sale cheap, or should i just go buy one online??
racer6888 is offline
Old 07-25-2009 | 08:53 PM
  #7955
racer-007's Avatar
Default my 5 port go motor
well my motor has about 30 tanks in it now. Went down to the track for a meet today. But i COULDN"T get any smoke at top end? i richend it so much it was missing u could say at the middle to end of the stright. down low was great lost of smoke but nothing up high. Temps were good allways came in at 100 deg.
racer-007 is offline
Old 07-25-2009 | 09:51 PM
  #7956
bigmatt's Avatar
set hsn so it runs good from start to end. then do all adjustments with lsn, just make sure your idle gap is set correctly. 100 degrees is way to rich and way to cold.you need temps up around 200 degree's plus. mine hangs around 225-240ish. also I can assume you have a completely broken in engine? at least 1 gallon-1.5 gallons. and did you take out the break in shim?
bigmatt is offline
Old 07-25-2009 | 11:11 PM
  #7957
Rampokker's Avatar
I think he meant 100°C. Which is 212 F.
Rampokker is offline
Old 07-25-2009 | 11:53 PM
  #7958
ok i have a question. which is the best GO TECH motor to run in a buggy (mugen mbx6) on a small to medium size track. unfortuanatley we dont have any large tracks out here in my area but we do have some mid size tracks with good size jumps. i used to run the GO tech 3 port race and never had a problem with that motor clearing anything. what advantage is the 5 port or the 7 port gonna give me
quicklosi is offline
Old 07-26-2009 | 12:09 AM
  #7959
racer-007's Avatar
Hi no its coming up to the 1 gallon mark and the brake in shim is still in and it was coming in at 100°C. Which is 212 F. dont know if its good or bad i was just worried that i couldn't get any somke out ot it at top end like i say i riched it so much it was mising at the mid to end of the stright. But still no somke????
Old 07-26-2009 | 12:24 AM
  #7960
Gizmatron's Avatar
If your running it flat out and it's coming in at 100ºC then I shouldn't worry about it..mine doesn't smoke much at all at top speed..depends on fuel oil content and type as much as anything..120-130ºC is more normal temps after a tank or two and full speed runs..If it's choking at full revs lean it back where it was..
Old 07-26-2009 | 02:30 AM
  #7961
racer-007's Avatar
yeah ill lean it up abit in a few more tanks as im still running it in.
Old 07-26-2009 | 03:56 AM
  #7962
mattwoodcraft's Avatar
both the 3 and 7 port will be good for the buggy modded 3 port has good bottem end and top end even if you end racing at a track with large jumps out of corner no problems at all , the 7 port in the buggy is also a very good motor heaps of top end if its a fast flowing track i would use a 7 port but t eather of these with a 2072 pipe is a awsome combo
mattwoodcraft is offline
Old 07-26-2009 | 04:00 AM
  #7963
if your engine is not for stroking at the end of the straight it will be okey you shouldnt see alot of smoke at high rpm if you do it way to rich from start to end there should be a trail it normal not to see any smoke flat
Old 07-26-2009 | 01:41 PM
  #7964
grizz1's Avatar
Hi guys, I have been off the air for few days due to internet server problems plus our computers at work have been down too, so I have been completely cut off from the outside world (actually not a bad thing for a short while).
Got some racing in yesterday - YAHHHHHHOOOOOO. Gorgeous day and nice track conditions. Used the 2072 on my MM5 5 Port in anger for the first time - WOW covers it nicely. What a sweet combination I thought the MM5 went well with the 0801, but the 2072 was way ahead in power and performance right through the rev range. I am thinking as the new MG66 motors are highly moded 5 Ports (thats putting it very basically) that this pipe on the new motors will RIP !!!
I am still going to use the 2047/0801 combo on the 7 Port though. It just seems to have more response on my 7 for some reason.
Gonna be off the air for 8 days or so from next Wed. Taking a well earned holiday, so I will catch up with all you nitro heads in a week or so. I might drop in for a look at what's happening if I can find an internet cafe in my travels
grizz1 is offline
  #7965
Originally Posted by racer6888
hey guys,
mate i have a spare crank that i removed from my old 5 port if you would like it
