Like Tree2Likes
Go-Tech Engines Thread
Old 07-22-2009 | 02:04 PM
  #7921
mattwoodcraft's Avatar
if you buy the the carb restricter kit you get all 4 them alloy ones and they all come with the orings check the web site MM
mattwoodcraft is offline
Old 07-22-2009 | 03:35 PM
  #7922
will g's Avatar
mattwoodcraft yes all 4 are alloy and they have the orings on the outside already
will g is offline
Old 07-22-2009 | 05:12 PM
  #7923
22Racer's Avatar
I have a couple 4 pc. sets of restrictors, $14.00.
Rex
22Racer is offline
Old 07-22-2009 | 08:43 PM
  #7924
sickpuppy1's Avatar
Rex
He ships fast too!
sickpuppy1 is offline
Old 07-23-2009 | 03:21 AM
  #7925
Rex
pm'd
keit29 is offline
Old 07-23-2009 | 04:25 AM
  #7926
Gizmatron's Avatar
I also bought the set of 4 GO restrictors probably 2 years ago and mine came with O rings but they were too fat...Had to rob the thinner rings from various RB and other plastic inserts I had lying around..Otherwise I couldn't get the inserts to fit in the carb mouths..
Gizmatron is offline
Old 07-23-2009 | 04:41 AM
  #7927
i have 4 sets of the alloy carb inserts some of the i rob the bottom oring and use it as an extra around the carby neck but i havent had any troubles with them pushing in .... abit tight at times but they do go in
Old 07-23-2009 | 05:12 AM
  #7928
Gizmatron's Avatar
Nah mine were definitely the wrong size..the O-rings fitted to the original plastic insert worked fine..hardly a catastrophe at any rate although I remember being less than impressed at the time..
Old 07-23-2009 | 05:36 AM
  #7929
here is my losi with 7 port engine
i raced last weekend in welden an was 10 th in the finale because after a jump my engine damaged at teh motormount
last week i tried the RB 2045 on my go, it was the best thing i ever do. try the rb 245 on your go and you will see what the engine can.
1 day before the race began i have the RB WS7 II 3X in my losi but the go was more powerfull from bottom to top
mihaelbencek is offline
Old 07-23-2009 | 06:09 AM
  #7930
triplesix's Avatar
another victim of "obi's mega wahnsinnssprung" at the welden track
triplesix is offline
Old 07-23-2009 | 08:39 PM
  #7931
first time trying the 3ptR ....man im impressed ...loved my5 but i think this is an awesome buggy mill supersmooth powerband good top 2 bottom really impressed with the top also i didnt think it would pull that hard w/ 7mm res and DYN 086 i was wrong
rkhess is offline
Old 07-23-2009 | 08:43 PM
  #7932
heres a pic or her mounted
rkhess is offline
Old 07-23-2009 | 08:54 PM
  #7933
fievel's Avatar
could i get away with running a Go 3R engine with an 053 in a D8T? I realize this wont be the best setup but its what i have at the moment. thank you for your time
fievel is offline
Old 07-23-2009 | 09:50 PM
  #7934
Default MG66
LISTEN UP EVERYONE................
If were thinking of getting one on the new MG66's............ order now.
We have just run in one of these engines (3 x 5 min runs @ 90% race tune) and on the 4th tank we got a run time of 11.30 PLUS ANOTHER 3 MINS AT IDLE IN A BUGGY
The performance was awesome. We have always been happy with Mark's modded Go-Techs, but these engines are on another level again
On top of this the above run times were achieved on MM HB444 fuel and we about to switch to the MM A MAIN BLUE DOT, which should improve run time even more..........
Truly an awesome engine guys............
Wild Thing is offline
Old 07-23-2009 | 09:55 PM
  #7935
d8racer's Avatar
i run the 3 port in my buggy with the dyn. 053 and love it. i am way impressed with the 3 port . it has more power all around than my os speed. great job to go engines!! i am sold. i did end up changing the carb right after break in to a +21 novarossi carb no lean bog at the bottom and cooler temps. my carb was weeping from the casting where the main gose in, but at the price i didnt mind swaping the carb.. it should be fine in your truggy..
d8racer is offline
