Like Tree2Likes
Go-Tech Engines Thread
Old 06-08-2009 | 06:27 PM
  #7126
22Racer's Avatar
Originally Posted by rossoh10
22racer
I race buggy and truggy..Most likely it will will be mounted in a buggy most of the time and mounted in a truggy on occasion.........I race on tracks all over california so a specified track surface can`t be said....I can say that most pf the tracks are in the medium size range..Nothing here big like The Farm or Nitro Pit...I am a fast intermediate/slow pro driver..I know how to use everything a motor has to offer...Right now I`m running a JP mod OS v spec.....
Mike
You would like the 5 port, some people have trouble with it having too much low end power. I still like it with the timing change for a buggy.
Rex
22Racer is offline
Old 06-08-2009 | 06:54 PM
  #7127
rossoh10's Avatar
racer22
what does the timing change do..I assuming it makes it smoother and less like a light switch......With out having to purchase another pipe which one of these would run best with it..TT2035,OS 2060,JP3 I think maybe the os 2060 will smoothen it out even more and give better run time while the others will make it be even more torqy than it already is
Mike
rossoh10 is offline
Old 06-08-2009 | 08:00 PM
  #7128
22Racer's Avatar
racer22
Mike
Yes the timing change makes it smoother on the bottom and makes it almost like a 7 port on top.
Probably the 2060 but I have never ran any of the pipes listed, the Jp3 might work good too. We have been using the Nova 9901, the 086 was good but fuel mileage is better with the 9901.
Rex
22Racer is offline
Old 06-08-2009 | 08:29 PM
  #7129
RETRO RC's Avatar
racer22
Mike
Hey rossoh10,
I wouldn't recomend the jp3 on any of the Go engines as they don't tend to get the full potential out of them and your runtimes will also suffer.
the TT2035 is a pretty good pipe on the 5 port and if you use a shorter header you'll get the less aggressive feel down low your after and some more top end to boot.
It would be hard to tell the performance difference between the TT2035 with the shorter header and the OS2060 and run times are about the same.
Hope this helps
Adrian
RETRO RC is offline
Old 06-09-2009 | 02:13 AM
  #7130
mattwoodcraft's Avatar
if you cant get the new go 2072 i used the jp4 pipe on the weekend in a 7 port excellent power with about 11-12 min run time that was the only pipe i had left over i was running in my truggy
mattwoodcraft is offline
Old 06-09-2009 | 02:22 AM
  #7131
lowcountrytj's Avatar
Originally Posted by lowcountrytj
Will this carb work on my GO 3 Sport.
Will help by any many means if it fits.Just wondering.
http://www.massivemods.com.au/produc...roducts_id=107
Just FYI-I got a response back from Massive Mods and this carb will work and will make a difference.Guess we will see.
lowcountrytj is offline
Old 06-09-2009 | 02:26 AM
  #7132
you will not have an issue with that carby i run them on my motors excellent fuel economy .... easy to tune .....
Old 06-10-2009 | 04:32 AM
  #7133
sickpuppy1's Avatar
I want a life size poster of lowcountrytj's avatar...
Sorry,that wasnt thread related, but......
sickpuppy1 is offline
Old 06-10-2009 | 11:59 AM
  #7134
Thanks Matt.
Sickpuppy----
Old 06-10-2009 | 12:36 PM
  #7135
Originally Posted by bigmatt
Well I just got done changing over the con rod in my ebmodded 5 port. also did the wrist pin and snap rings. I also put on a gen 5 or 5.5 carb, has the red go in the front.Talk about a monkey fk'n a football! I am surprised the thing runs. Grizz thanks for the instructions on how to do this. Thank god I did not erase your email message. The biggest thing I fk'd up was taking the sleeve out. I put the zip tie through the back of the exhaust port, instead of down the cylinder to catch the lip of the cylinder. Got it all done and the engine did not want to run. I put in 20% nitro,this one likes 30%. still no go, switched carbs put in an os p-4 plug 20% nitro thing rips. This engine now that it is fully broken in and tuned is way to much for me let alone a buggy. I may put it in my wife's x1x jammin as it is heavier then the hyper 8.5 that the engine is in now.I am going to have to think about it. I may try it in my x-2 jammin and see how it makes that buggy react. I'm going to reseal the old carb with the seals I got from massive mods make sure it runs good and holds a tune then sell it. I am thinking 165.00 shipped lower 48 only. This really belongs in a truggy.
Don't sell it Matt. You'll want to keep it around for a good back-up engine.
NewOne is offline
Old 06-10-2009 | 03:51 PM
  #7136
you couls always try and smooth the engine out through setting up your clutch different .....
Old 06-10-2009 | 05:23 PM
  #7137
grizz1's Avatar
Yeah Matt. Thats too good a motor to let go of. I am sure you can tame it for the buggy with a suitable restrictor and clutch adjustments etc. Try a 14 tooth bell. That smooths out the 5 Ports quite a bit. Would be a shame to say goodbye to such a work of art
grizz1 is offline
Old 06-10-2009 | 05:55 PM
  #7138
sickpuppy1's Avatar
You can set the throttle with EPA, but I'm sure you know that. And then there is the one I can never get the hang of.....dont floor it!(until conditions permit) LOL
Old 06-10-2009 | 05:56 PM
  #7139
bigmatt's Avatar
I will try with it in the x-2 jammin with stock jammin clutch set up. already have 6.5 restrictor with throttle epa set at 60%. I do the idle for 10 seconds or more then punch it. all 4 tires balloon up like they are on the back of a drag car. with the 7 ports it's smother down low about same on top. I also went composite clutch shoes with 90 mugan springs. did not like that[springs] so went to 95's much better. with the 90's the shoes were way to loose.Grizz knows my story. I started racing this year and was thrown in with the intermediates not beginner. no class for beginner in series. I some how have managed to be in 5th place so far. now I am going to use the 8.5 for practice, breaking in engines and race my x-2 only. the jammin is not as squirrelly as the hyper 8.5. and I have tried all different gear fluids to settle it down. Hell when I had my axial 28rr in it it was easier to control.Now that this 5 port is broken in it screams. I will say that coming up on a short run jump it will triple with ease. I am not some super pro but have yet to have anything pull me down on a straight. It's quite the opposite, some one can be 1/4-1/2 ahead of me on a medium-long straight and this engine will be on top of them buy the next corner. Now if I could keep it from doing 360's in the corner I might win a race or two.-LOL
bigmatt is offline
Old 06-10-2009 | 06:00 PM
  #7140
sickpuppy1's Avatar
That throttle control is a bis-nitch to get a handle on when the adrenalin gets a-goin, isnt it?
