Like Tree2Likes
Go-Tech Engines Thread
Old 05-05-2009 | 08:25 PM
  #6646
I know its been said before, but who are the few people that sell Go Tech parts on here. Im in need of a rod and front bearing for a 3PortRace. Please PM me if you are that person.
Thank You,
James
racer6888 is offline
Old 05-05-2009 | 08:39 PM
  #6647
grizz1's Avatar
Originally Posted by malik
That track is awesome and bigger than my local track for shure. If I drive a bit I can get to a similar sized 1. That 7 port will pull all the way down that straight so hard, watch and see.
Nice track guys.
Hey Malik, don't be put off from running a 7 Port on a tighter track. They have big bottom end and can handle it no problems.
Run 1.1 springs, alloy shoes and a 7 mm restrictor and you can pull wheelies with the 7
I run on a fairly short and tight track with mine occasionally and it's awesome.
Just finished some TLC on my 7 Port actually. Now it has a new MMods Gen 5.5 crank, new bearings and rod. I had forgotten how angry the 7 sounds until I fired it up this avo. Hmmm - love that motor
grizz1 is offline
Old 05-05-2009 | 10:09 PM
  #6648
The only thing is that I like to run 1.0's and carbons LOL. I put my D8 on a 5 oz diet and alittle more to come. I am just tired of maintaining alloy shoes. I hope my new 3p is up to it. Even if I did go back to alum I still wouldnt run 1.1's in buggy, I would go with the Dynamite last for evers LOL with 1.0s or Mugen light shoes. I will get 1 eventually, another reason is every guy with a GO around here is running a 7.
malik is offline
Old 05-06-2009 | 06:41 AM
  #6649
im running 1.1's and answer alloys on my MM5 7 port and its like a shotgun blast out of the hole.
Jasonguy is offline
Old 05-06-2009 | 08:59 AM
  #6650
tagalong_74's Avatar
Well at my local track there is only one guy that runs there consistently with a Go 7pt turbo and that would be me. I have also seen one 5pt that the person ran way too rich and was getting stomped by os motors only because it was too rich. It was a sad sight to see such a great motor not being used to its full ability. As for the track we finally get to practice next week and it is technical for the most part. I love my seven pt and wouldn t change it for the world. Now what I'm excited to run is that Go-28 6pt I just picked up to run in my truggy.
tagalong_74 is offline
Old 05-06-2009 | 12:11 PM
  #6651
grizz1's Avatar
Ohh yeah
I have tried all sorts of spring/shoe combos on the 7 Port and have found that it needs the heavier springs. With the extra ports the motor needs to spool up a little more then the other GO's before the clutch hits, or it can be a little boggy off the mark and out of the corners, regardless of tune. You can get away with 1.0's, but the 1.1's are nice on any track surface with this motor. Either 3 x alloy shoes or 2 x alloy with a carbon to soften it a little and prolong shoe life.
I use the X-Ray 1.71 shoes and they last extremely well.
He he - "shotgun blast out of the hole" sums it up nicely Jasonguy
grizz1 is offline
Old 05-06-2009 | 03:42 PM
  #6652
MassiveMods's Avatar
Yeah i use the same set up on my MG66 and its got TOO much take off ... But im addicted to the Shot Gun effect ( good analogy Jason ) I cant stop , its taking me over aahaah !
MassiveMods is offline
Old 05-06-2009 | 03:43 PM
  #6653
Thank You,
James
Hey James there are several , where are you from ?
Old 05-06-2009 | 05:09 PM
  #6654
Default 3 port sport
What can you guys tell me about the 3 port sport? Looking for a .21 for my matrix buggy to get rid of the .28 gas pig. I plan on entering a couple races at my local track. The track is on the small size so top end power isn't really needed. I'm just looking for some opinions on the 3 port sport.
Trail Bruizer is offline
Old 05-06-2009 | 05:30 PM
  #6655
looper's Avatar
having seen them run around here i liked them enough to buy two from a guy in austin, (one used and one new) the used one was DOA and i am about to break in the new one, i would say go for it. go ahead and get the restrictors for it as well (they are not included with the sport one) Im thinking the 7mm one would be a good choice for it, although the pack of them has four sizes to choose from.
looper is offline
Old 05-06-2009 | 07:22 PM
  #6656
22Racer's Avatar
The .21 sport is a really good motor for the price. It has most the same internals as the race motors with more basic ports. The one I'm running I modded and it runs right with any 5 port and most high end engines.
Rex
22Racer is offline
Old 05-06-2009 | 10:04 PM
  #6657
My GO 3PR is running well in the quallys but everytime I pit it dies while being filled up.. any ideas? Its a HB D8 if that matters. Just confused why it dies then, runs strong during qual and before i pit.
Old 05-06-2009 | 10:23 PM
  #6658
bigmatt's Avatar
If I rremember right you need to richen hsn 1/8th turn till it stops. there was a post in here just about that problem. I am sure if mark from massive mods or grizz see this they will point you in the right direction.
bigmatt is offline
Old 05-06-2009 | 10:40 PM
  #6659
I'm running a GO 3 Port in my truggy and people cannot believe I only paid $99 for it at the local hobby shop. I'm able to run the same pace as everyone else with power to spare (my limiting factor being my skill level).
Go 3 Port Sport - $99
Dynamite 086 - $40
Seeing the looks on peoples faces who paid 400+ dollars after I tell them what I'm running and the cost. Priceless.
cLaWz is offline
Old 05-07-2009 | 12:04 AM
  #6660
Gizmatron's Avatar
Same here I run a RMV speed 2.5 clutch setup..1.1 springs and either 3 alloy or 2 alloy and 1 carbon on looser tracks..I agree with grizz1 it bogs just a fraction out of the corners using 1.0 springs..spent a futile afternoon 2 years ago when I first started with the GO 7 port trying to adjust the tune to lose the bogging..Then just as the day was ending I thought "hmmmm CLUTCH" swopped the springs and promptly lapped everyone who'd been catching me out of the corners all day...Muahahhahah!
Gizmatron is offline
