Like Tree2Likes
Go-Tech Engines Thread
Old 03-16-2009 | 04:58 AM
  #5986
rearviewmirror's Avatar
Do you Go owners completely dismantle your brand new engine and clean them out before their first run? A lot of local guys are recommending it, or at least removing the back plate and washing out as much of the engine as possible then leaving the piston at TDC for a few days after sealing the back plate again.
rearviewmirror is offline
Old 03-16-2009 | 05:00 AM
  #5987
GNS Racing 86's Avatar
hi
sorry about posting this here BUT
ive been trying to post a new thread for about a week now. and i keep getting a message that the site is having problems.
is anyone else having this problem?
it says at the bottom of the page that i may post a new thread.
tried to send email to the site, but i cant email through outlook express
if someone could help or forward this to administator would be apprietiat it
steve
GNS Racing 86 is offline
Old 03-16-2009 | 05:37 AM
  #5988
i have never done that to a new engine, i have sealed the back plate and carb before thats about it, i dont think it would be a good idea to put the piston at top dead center and leave it there, what is the reason for leaving it at top dead center for a few days for? to loosen the pinch?
cjm1126 is offline
Old 03-16-2009 | 06:16 AM
  #5989
Don't know the reason for it, it was just recommended by one of our Xray sponsored drivers who used to run Go engines. I'll have to ask him why leaving it at TDC for a few days is good. I would guess that it allows them metal to conform at ambient temperatures.
Old 03-16-2009 | 06:41 AM
  #5990
i personally wouldnt give that a shot, if you are worried about the air leaks i would seal the back plate and the carb neck with some lucky 7 sealent and break it in, use a heat gun on the head to loosen the pinch up on start up during the break in process
cjm1126 is offline
Old 03-16-2009 | 07:10 AM
  #5991
mfrosty's Avatar
So I'm ordering an engine from Massive Mods today and I can't decide which one I want, the MM5 5 or 7 port. Anyone here run them? Help me decide! I have an O.S. Speed carb that's going on it and a Dyn 086 pipe. My LHS carries the 0801 for a decent price too so that might be an option next week. Be running on larger outdoor tracks.
Thanks!
@ MarK (MM) do these come with ceramics installed?
mfrosty is offline
Old 03-16-2009 | 07:16 AM
  #5992
check out the ebmod race prepped it comes with tko ceramic rear bearing,the carb is flow tested, they tin coated carb slide, coated crank, its fully broken in and ready to go,they make really good power and get great fuel economy
cjm1126 is offline
Old 03-16-2009 | 07:19 AM
  #5993
mfrosty's Avatar
That's all good and everything but I've got only $240 to spend on a new mill, I'm definately getting one from MM, so please don't say "well you should buy this brand"
Thanks though.
mfrosty is offline
Old 03-16-2009 | 07:26 AM
  #5994
Thanks though.
didnt say "well you should buy this brand" seemed like you wanted a ceramic bearing and i figured i would mention the ebmod motor, you can get it for 255.00 from carolinas rc if you use the coupon code and take advantage of the free shipping, was just mentioning another option
cjm1126 is offline
Old 03-16-2009 | 07:32 AM
  #5995
mfrosty's Avatar
That's cool man, I wasn't busting your balls. Sometimes these threads get carried away with peoples opinions and I just want to keep the conversation related to the MM engines is all. And with the currency exchange rate I'm getting the engine for $210 shipped so if it doesn't have ceramics I'm sure I can add them and still come in under the $240 mark
mfrosty is offline
Old 03-16-2009 | 07:46 AM
  #5996
Mr. Twister's Avatar
The MM 7 port turbo, this motor will have plenty of bottom end for buggy, smooth and rev's out real nice, I'm sure his engine will be all you need in terms of power, it should also be better for laptimes, and the 801 is very good on the 7 port, wakes the bottom end up and pull's like a mac truck, this should shine on your style track bud. Just my 2 cent's
Mr. Twister is offline
Old 03-16-2009 | 07:52 AM
  #5997
The stock bearings I would leave in till around 2-2.5 gallons then go with the Tko's or what ever ceramics you want and at the same time put a new rod in it and you shouldnt have to open that thing up for a long time after that. I just did that to mine, break in is hard on bearings and the rod so thats why I dont recommend scraping a new set.
malik is offline
Old 03-16-2009 | 08:02 AM
  #5998
bigmatt's Avatar
Originally Posted by malik
7x19x6 front and 14x25.4x6 for the rear. I just put a set in my 5 port . Smooth as butter.
where did you buy the bearings at?
bigmatt is offline
Old 03-16-2009 | 08:06 AM
  #5999
A-main has them in stock and good price or go directly to TKO. I had to get a bunch of other stuff thats why I got them from Amain.
malik is offline
Old 03-16-2009 | 08:37 AM
  #6000
mfrosty's Avatar
Thanks Brian!
Once my job situation is straight this 5 port is coming back to you for a complete overhaul and mod
mfrosty is offline
