Go-Tech Engines Thread
#7486
Well I am going to find out if mine lasts. since I just put in new wrist pin con rod c clips. My 5 port is a gen 4 because of the crank. It has a circle cut in the end on it. MOstly you can tell by the heads. The first ones said go and 21. then they came with pretty engraving on it. and they changed the carb. I am sure grizz, 22racer[anyone heard from him lately?] or mark from massive mods can give out the info. Also there are a lot of variables here. 1; how are the bearings? are they a little loose causing vibration? are you putting the new conrod in facing the right direction? whats the shim pack? and are you running to lean on the hsn? how many gallons through the engine? and last but not least is the crank pin worn? I think a while back it was 22 racer or grizz that mentioned some thing about that problem.
#7487
Hi Juzza,
i find the 5 port to be the best performer out of the Go's in terms of consistent power throughout the whole range it just seems to have heaps of power when ever i need it. a lot more noticable to me since switching pipes from the 0801 to the 2072.
i think for our track the 5 is what you want to go with as the 3 loses a little on the straights and the seven's top end just doesn't get to open up fully IMO.
im running for sure bro and it will be great to see Ari's truggy in action, if it goes like his buggy then god help us.....lol
im running the 5 port as well so check it out and let me know your thoughts bud.
Mike
Mike
due to the jconcepts 808 body and the rear tower looks similar also.
I've heard a lot of people say that the 7 port doesn't get to fully open up on their track and I think thats a shame as it puts a lot of people off what I beleive is probably the pick of the bunch.The main thing I put this down to is most nitro racers have never raced electric and don't think about gearing changes to suit their track as the only thing everyone really discusses is engine tuning or pipe changes for more top or bottom end. heres a small example on my home track if I run.....
5 port I use a 16 tooth pinion and the 0801 pipe with a medium header(2047 header)
but on my 7port I run either a 14 or 15 tooth bell and the 2047 with a long header( 0801 header)
Getting the true potential out of an engine can be something as simple as a gear change. just my thoughts
Adrian
#7488
Interesting with the wrist pins. I have never heard of any problems before.
I always slop lots of after run oil on anything new going into the motor. It takes a little time for the oil/fuel to fully penetrate something like the fine space between the pin and the rod bushing. If it's running dry for that initial period until the oil gets in there, you could be putting 5 hours wear on it in 30 sec when you fire it up for the first time. Same reason I strip down a new motor and lube everything then re-assemble before firing it up for the first time. Otherwise it's like starting up a brand new full sized car engine, waiting till it's running and then filling it with oil !!! (not quite the same, but you get the point).
BigMatt - let us know how those new pins and clips go mate.
#7489
Grizz, here's some pics. The pin that is worn came out of the P/S/R set that blew the clip and has under a Gallon on it. I mistakenly said it was a TIN pin but it is not. The other one that blew was but I think I pitched it. I'll look for it and hopefully I can find it. The other pics show a TIN Pin I just took out of my 7 Port that I just finished breaking in. It has about a gallon on it. Changed it out with an OS pin and clips to try and change my luck. It is worn a little but not like the first one. Also the coating comes off as you can see.
I really can't understand how they're wearing so quickly I've just measured the wrist pin out of a 3 year old 50+ ltr 7port i just had rebuilt and it only varies by .03 of a mm from 1 side to the other (3.99 to 3.96)there must be a problem somewhere in the building of the engine or 1 other thing that hasn't been mentioned is the fuel you run.
Also I'm not a hugh fan of ceramic bearings due to the different components having different expansion rates Ie the steel casings expand more that the ceramic balls ...end result a sloppy bearing right from the start
Like I've said before maybe you need to send it to someone to look at for you
Adrian
#7490
adrian
#7491
Hey 2fst2c,
Adrian
Adrian
#7492
Why haven't my other motors failed? Also, I don't recall seeing anything in the instruction book that said I need to take my new motor apart and oil the pin and other parts and assemble before breaking it in. Seems like it just said to idle a couple tanks through it, then run it at light varying throttle not to exceed 1/2 throttle for another 5 tanks and then start leaning it out over then next 5 tanks or something along them lines. Not trying to start a piss'n match here. Just trying to find a scientific explanation to the Pin wear and ruined P/S/R sets. It's all good. Live and learn for me.
#7493
this is what a gen4 or ealier crankcase looks like
http://www.amainhobbies.com/product_...5P-or-7P-Black
and heres a gen5
http://go-engine.com/in-products/R217PT-P320SG.htm
#7495
I'm running Sidewinder fuel. The ceramic was put in after the 1st set failed. Just because I thought it might help. Not the first motor I've built. Been through a lot of them over time. Each time I take it all down, clean the case and clean it again. Clean the crank and even the carb. Oil the inside and the bearings. Apply light machine oil to the crank, rod, piston and sleeve and assemble. It's not really rocket science to get one together. As long as it's clean. And again, all my other motors run great and have over 2 gallons on them. Except for the new ones that is. I just got some bad parts and that's ok. Like I said, I was a believer and still think they are a great motor when they stay together. But I'm done putting money into them. Maybe I'll wait for the new Gen to come out and try my luck again. Until then, I've got plenty of power in my P5 and C6.
all I can say is I hope you do give them another chance as any manufaturer can make a bad engine as not every one can be perfect.... I know I've had Novas give up their rear bearings at under 2 gallons and take the whole engine out Ps keep an eye on the 14.5 mm rear bearing in your p5x
just to really get you paranoid. I hope you get some trouble free running as it sounds like your due for it
Adrian
#7496
I think your right you just got a bad engine . I would have put it to rest the first time it went as like you've said for what you've spent on it now you could have brought a new 1.
Adrian
Adrian
#7497
there are a few people I wish I could meet on this thread,mostly when a problem like yours comes up. It would be nice to come over and check the mill out. Then there is grizz, mark massive mods god I would love to work for him for a month just to learn. and racer 22[he's from my home state]. Any way I put together one of my 7 ports off of ebay. And what I noticed was it felt sloopy. and it is the one engine that I noticed the pinch was going away a little faster then the others. I may have done the massive mods run in oil a little to much? If thats possible. Not enough heat?It went together hard,meaning the sleeve did not want to slide down into the block easy. This was the engine that made the wisp,wisp noise. come to find out it was the clutch springs[to lite,90's] I'm wondering if your onto some thing here when the engines get rebuilt. This engine has about a gallon on it so I have another one to go until I tear apart and rebuild. Or I may let this one go a little longer. If you stumble across what the problem is please share. I would like to know.
#7498
Hey mike nice buggy first of all I thought it was a 808 when I first looked
Adrian
Adrian
its the JC illuzion II body (it said rc8 on the packet and all the aerial motor body mount holes all lined up for the rc8 but i originally thought the rc8 body was lower too) im running the truggy rear tower and BB shocks so its a little confusing at 1st......
i agree 100% with you on the gearing issue both pinion and spur gear wise! its also something i want to play with a bit more to achieve the best performance!
don't get me wrong on the 7 port cos its a AWESOME engine its just i've ran the 5 the hole time except one meet so thats what i formed my opinion on.
Mike
#7500
Adrian
Adrian
Good point !
I myself run (stock 13/46) with my 5 p, and run (13/48) with my 7 p in my trug.
I also use different clutch spring tentions to tune for the track !
2Likes
