Like Tree2Likes
Go-Tech Engines Thread
Old 01-20-2009 | 10:33 AM
  #5431
zJatoRad's Avatar
Originally Posted by DRRC
Raced my 7 port last weekend and did well with it
I have it as grizz advised .75 HSN and 2-2.5 LSN
But I haved noticed that it is slow to respond at the start of the throttle and then it just screams after 1/6 throttle
Am I too rich or too lean
20 min mains and had fueled only 2x and still have 1/3 a tank after 7mins
I love this engine it is just so difficult to be consistent with it when the climate changes in the same raceday
thanks
Doc, I suggest you use aluminum shoes with 1.1 springs, I believe you told me you are using some carbon shoes with unknown springs.
zJatoRad is offline
Old 01-20-2009 | 10:42 AM
  #5432
slaytanic's Avatar
Man those pics make me wish outdoor season was here!
And NICE Hooters!!!
slaytanic is offline
Old 01-20-2009 | 03:50 PM
  #5433
lmao ,, I want to get all my stuff out, new everything, With 3 feet of snow and 11 deg f out side. Only 3 more months to go and then some fun.
phoenix357 is offline
Old 01-20-2009 | 05:16 PM
  #5434
rearviewmirror's Avatar
My new GO 3-port ate a Losi starter box yesterday. It was the first time we tried to fire it, even after pre-heating it. It was the only starter box we had so unfortunately there isn't much more to do. Are these GO engines usually so tight? Even after loosening the plug it still didn't want to turn to freely.
rearviewmirror is offline
Old 01-20-2009 | 05:50 PM
  #5435
RETRO RC's Avatar
yep they are notorious for being tight. what I usually do before trying to turn it over for the first time is to remove the plug and put a fair amount of afterrun oil in to the engine through the carb and in the combustion chamber.
allow the oil to sit in the engine for about 1/2 hour at least before replacing the plug. leave the plug loose, heat up the engine with foil around the cooling head(at least 200F),make sure the engine is at BDC, prime it by blowing through the pressure feed line until there is fuel into the carb and you should be good to go.
Adrian
RETRO RC is offline
Old 01-20-2009 | 06:10 PM
  #5436
DRRC's Avatar
YUP
I'm using the stock D8 clutch and set up
I just have to find the right setting for a smoother initial 1/4 of the throttle
DRRC is offline
Old 01-20-2009 | 06:12 PM
  #5437
Adrian
Thanks! I should have ran it on the box without the plug for a while, I'll try that next time I get some box time. Lesson learned for sure.
Old 01-20-2009 | 06:41 PM
  #5438
Jaz240's Avatar
Come to Arizona dude, we race 365 days a year..wait sorry, we do get rain about 4 times
Jaz240 is offline
Old 01-20-2009 | 06:43 PM
  #5439
We're racing year round in Austin too, we've had a couple of colder races in the 40-50's but still not a problem at all.
Old 01-20-2009 | 07:34 PM
  #5440
22Racer's Avatar
From what I've heard the Losi box isn't the most powerful box out there. The Ofna Truggy box will turn over anything. The 3 port isn't as tight as the 5 and 7, people claim the Go's are so tight but I've never thought they were much tighter than a Nova or Rb.
When trying to start a motor blow into the pressure line and get the fuel right up to the carb. Then barely push down on the car to get the starter box spinning up to speed before you push down on the car.
Rex
22Racer is offline
Old 01-20-2009 | 09:15 PM
  #5441
Jaz240's Avatar
Hell yea! Everythings better in Texas! Love dem Cowboys too, bad season, but we still get to race, and I got more race time with the Boys out of the playoffs
Jaz240 is offline
Old 01-21-2009 | 01:02 AM
  #5442
alexzone007's Avatar
Default eb mods GO ENGINE
SAW THE NEW EB MODS GO .21 ENGINE
SOMEBODY HAVE IT POST YOUR COMENTS THANKS
WWW.EBMODS.COM
alexzone007 is offline
Old 01-21-2009 | 01:57 AM
  #5443
grizz1's Avatar
YUP
You are probably just a hair out on the bottom end. The GO's are very touchy on the needles. Just a tiny adjustment will make a big difference. Just tweak the bottom until you get a steady idle with no drop in revs after you come in from a run. Check with pinch test. Engine should rev up only slightly and die around 4 - 5 seconds after pinching off the fuel line (about 1" from the carb).
grizz1 is offline
Old 01-21-2009 | 06:00 AM
  #5444
I have the ofna truggy box and with those 2 775 motors in there it will bump start a chevy big block. But I always heat my engines before starting them even in the summer.
I only turn left
Old 01-21-2009 | 11:56 PM
  #5445
Gizmatron's Avatar
Originally Posted by Poinas2
Hmmm... pretty nice bumps you have there. Must be due to the climate or something
I was about to say what a fine pair of buggies ...
Gizmatron is offline
