Like Tree2Likes
Go-Tech Engines Thread
Old 12-15-2008 | 08:44 AM
  #5056
ok thanks will g.....guess i wont buy that button then ....so what go plug would work best for the .25 engine then? or other plug.....
ShootinBlanks is offline
Old 12-15-2008 | 08:58 AM
  #5057
will g's Avatar
i use odonnell 77 plugs
will g is offline
Old 12-15-2008 | 09:17 AM
  #5058
Will G, on your .21 5 port which of the OD plugs do you use? I asked this before but forgot which it was. I run the P3 and lik them alot but they are getting pricey. I found the OD turbo plugs for like 1/2 the price of the OS. But I will say that I have got 4 weekends out of 1 P3 before, I am hoping the OD plugs are similar in quality and I will be a happy guy.
malik is offline
Old 12-15-2008 | 09:50 AM
  #5059
will g's Avatar
i run the odonnell 77 standard plugs and odonnell 77t turbos in all me engines
will g is offline
Old 12-15-2008 | 11:52 AM
  #5060
Rocket42's Avatar
The hotter plugs will make the engine easier to tune and that is more important for the average racer then squeezing every bit of performance out if the engine.
I have found that the .25 and .28 engine prefer a colder plug, like the Go #6 or the O.S. A3, the o'donnel 99 would also be a good choice just be sure to get the O.S. specific plug for the engine.
Rocket42 is offline
Old 12-15-2008 | 12:34 PM
  #5061
LMB
Does anyone know how fast my Ray will go with my 5 port Go!! my mates keep asking.
By the way I am LickMyBalls, just changed my name to not upset the fairies in here!!!
LMB is offline
Old 12-15-2008 | 01:28 PM
  #5062
grizz1's Avatar
Ahh - that would be BLOODY FAST !!! That's all they need to know
Originally Posted by jnc011994
I also thought that was "flush" thanks for the clarification. We have a club race this coming Saturday, will do this modification. I have always tuned the engine with the LHS technician (since i bought it from them), but since yesterday race (Futaba Cup) i can't bother him cause he also joined the race. That was my bad since i did not even learned by myself to tune this engine. I'm a complete noob with engine tuning. I already have around 4 gallons on this engine.
Ok so after setting .7mm to 1mm in the idle gap, flushing the HSN and LSN. Turn .5 in HSN and 2.5 in LSN. Engine running, what's the worst that could possibly go wrong? will inform here once i had it tested.
Thanks,
Just go in 1.5 turns on the LSN to start. It will be a bit rich on the bottom at that setting. Then just slowly turn the LSN in bit by bit until you have the tune spot on. Leave the HSN at .5 in and only tune with the LSN from here.
IMPORTANT: I should have mentioned earlier - make sure you have your idle gap set correctly at .7 - 1mm max. If the idle gap is too wide you will struggle to get a good tune for sure.
Check LSN tune with pinch test (see tuning tip on page 132 from Massive Mods on how to do this).
Cheers
grizz1 is offline
Old 12-15-2008 | 02:23 PM
  #5063
22Racer's Avatar
I raced my 3 port sport I modded last weekend! Wow this thing is awesome. I ran it only 220 deg. because it would have been too much power for the indoor track we were at.
Like Russell said, use Os style short plugs on any non turbo Go motor. The thread is shorter, you can use 2 washers also. We are using a Go #6 in Kendall's .25 and have 4 weekends on it, they seem to hold up pretty good.
Rex
22Racer is offline
Old 12-15-2008 | 03:35 PM
  #5064
I've had good results with McCoy MC-8 plugs in my .25 GO, just have you use 2 washers. These plugs are cheap too.
herb99 is offline
Old 12-15-2008 | 06:15 PM
  #5065
nazprerunner's Avatar
22racer
i ran the 3port motor you pinched and its like new. love that power in the losi 2.0
i just need to get off my ass and replace the high /low speed needle orings
thanks
nazprerunner is offline
Old 12-15-2008 | 10:09 PM
  #5066
losi_racer's Avatar
what glow plug is good for the 6 port .28 go????
btw i live in az where its 110 in summer and 50 in winter
and btw if your a go tech dealer and your in az can you contact me thanks
losi_racer is offline
Old 12-16-2008 | 05:32 AM
  #5067
slakr's Avatar
Is there a roto start backplate that fits the GO engines?
slakr is offline
Old 12-16-2008 | 05:37 AM
  #5068
will g's Avatar
they make them
see below link shows one in pic
http://cgi.ebay.com/Go-Engine-28-Car...QQcmdZViewItem
try getting ahold of racefactor industries and see if they can get them thnx will g
will g is offline
Old 12-16-2008 | 06:19 AM
  #5069
slakr's Avatar
Originally Posted by will g
they make them
Looks like a Sullivan Tiger Drive http://www.sullivanproducts.com/TigerDriveMainFrame.htm
slakr is offline
Old 12-16-2008 | 10:13 AM
  #5070
zJatoRad's Avatar
maybe one of these?
http://www.amainhobbies.com/product_...ducts_id/25538
http://www.amainhobbies.com/product_...ducts_id/16322
http://www.amainhobbies.com/product_...ducts_id/22312
zJatoRad is offline
