Like Tree2Likes
Go-Tech Engines Thread
Old 11-24-2008 | 04:39 PM
  #4786
MassiveMods's Avatar
Originally Posted by RETRO RC
only his modded engines.
try Russel (rocket42)at race factor industries for a list of us dealers and he'll let you know of their avaliablity.
Also looks like GO are starting to producing quite a few engines for other companies this sure looks like a GO in discise
http://it.babelfish.yahoo.com/transl...news/&lp=it_en
Adrian
Thats right i only export modified engines. Best to find a dealer in your area to enjoy local support.
Cheers MM
MassiveMods is offline
Old 11-24-2008 | 06:26 PM
  #4787
Pauly6401's Avatar
Other than culling info from this very long thread, has anyone put together a Go-specific tuning guide on the net anywhere? I'm about to break my 3-port in, and it's the first "race" motor I've ever broken in (and only my 2nd nitro, the first one was my Nitro Hawk 14 years ago, which doesn't really count). I'm using Brian's method from Pro-Twister Mods, but the documentation that came with my motor is a little, um, "lacking" (as is their website).
Just wondering, since I am paranoid about grenading a perfectly good, new motor that I've spent hours getting ready to start (double checking the settings, getting the starter box lined up perfectly, etc).
Pauly6401 is offline
Old 11-24-2008 | 10:08 PM
  #4788
yaright's Avatar
Pauly
Just give Brian a call, I am sure he will help you any way he can. They are still working on the web site... Its only been up for a couple of days.
yaright is offline
Old 11-24-2008 | 11:33 PM
  #4789
RETRO RC's Avatar
Brians run in method is really good it's almost exactly what I do. Once run in one thing I will say is tune for performance not temp as there is so many differences in temp guns they're not worth the headaches they provide.
if your engine has a Long LSN then tune for bottom end first once your happy with that then tune the HSN it won't need much (depending on fuel plug pipe atmostphere etc) any where from a couple of hours to 1 turn.
If it's got a short LSN then it'll tune pretty much like any other nitro engine.
if your worried about temps then the spit test is always good, put a small amount of spit on your finger and transfer it to the head of the engine
If it doesn't bubble it's to cold
if it bubbles slowly but doesn't evaporate quickly you pretty good
if it bubbles and evaporates quickly your too hot.
There are a lot of things you can do while tuning but it would take me all night to write them in here
If you've got any issues when you get up and running feel free to ask questions as I'm sure you'll get answers pretty quickly on this thread as we all want go users to get the most out of their gear.
Adrian
RETRO RC is offline
Old 11-25-2008 | 12:16 AM
  #4790
grizz1's Avatar
Brians break in method in detail on Page 78 ( toward bottom of page) of this forum. Like retro RC said it works a treat. Be patient with the first gallon or so and you will be rewarded with a powerful and long lasting motor.
Long LSN tuning guide about 1/3 down page 131 on this thread, from Massive Mods. Follow this and you won't / can't go wrong. If you get a short needle carb just tune as per any other motor.
Cheers grizz
grizz1 is offline
Old 11-25-2008 | 03:40 AM
  #4791
Pauly6401's Avatar
Thanks guys - and one clarification: I wasn't talking about Brian's site, I was referring to Go's site! Just so there's no misunderstandings.
But thanks for the tips and I will keep in mind as I try and break this bad boy in over the long weekend coming up.
Old 11-25-2008 | 07:07 AM
  #4792
petevette's Avatar
Just realized I posted my question on the 3 port Go thread. Figured it should be here instead:
Question for the GO guru's. Can you drop in the piston and sleeve of a 5 port into a 7 port with good performance results?
Is it a direct replacement? Will the carb be an issue?
petevette is offline
Old 11-25-2008 | 07:24 AM
  #4793
chim13's Avatar
Does anybody know anything about this new M5 ebmod go engine
chim13 is offline
Old 11-25-2008 | 07:42 AM
  #4794
i would like to know a little more as well. I'm sure it's a modded 5 port but I would like to know how much it's gonna cost.
Here's a link to the new page on neo buggy where thay have some info.
http://http://www.neobuggy.net/modules/news/
x195svt is offline
  #4795
will g's Avatar
chim13 you can go here and read about it. thats about all because its not out yet they are preordering now
http://ebmods.com/EBMods%20Home%20Page.htm
will g is offline
Old 11-25-2008 | 07:43 AM
  #4796
will g's Avatar
Originally Posted by Rocket42
Street price on the race prepped engine will be 289.99+ and the full modded version will be 349.99+ please remember that these engines will be assembled in the U.S. and have a name brand quality ceramic bearing included as well as the other features such as crank coating and such.
see above
will g is offline
Old 11-25-2008 | 07:46 AM
  #4797
will g's Avatar
from my understanding the 5/7 port cases are the same case so you shouldnt have any problems with that even the carb should be no problems no difference in performance besides the ports
will g is offline
Old 11-25-2008 | 08:45 AM
  #4798
that m5 looks sick...wonder how they'll preform as the go 21 5 I had was plenty fast already and all it had was an os 2050(non turbo at that)
NitroLuver is offline
Old 11-25-2008 | 08:54 AM
  #4799
Rocket42's Avatar
you should be able to change the piston and sleeve out between all of the race .21's without a problem.
We are taking pre orders on the ebmods engines, the first 100 will include a free Go restrictor kit. Some of the details are still being worked out on the engine so we don't have them in stock yet. We are gonna try and get them here as soon as possible.
Rocket42 is offline
Old 11-25-2008 | 10:33 AM
  #4800
zJatoRad's Avatar
I know what's going to be my next engine
zJatoRad is offline
